#11
I stand corrected. Thanks for that info and the links. Learn
something new every day. As Ms. Goody Two-Shoe Martha Stuart said, It's a good thing. Monk Martin X. Moleski, SJ wrote: On 15 May 2006 19:45:39 -0700, "Flyingmonk" wrote in . com: ... I have heard, seen and read that some radials did have the shaft bolted to the airframe. ... They were called "rotary engines." Very different from the Mazda rotary. I simply could not believe my eyes the first time I saw one in the Curtiss museum. I read the sign several times. I still thought someone must have gotten it wrong. The were used extensively in WW I by both sides. Here is a magnificent page with an animated gif: http://www.keveney.com/gnome.html The only detail left off the page is the effect that the castor oil from the total-loss lubricating system had on the pilots. It is said that some landed off-field to deal with the consequent call of nature. Most of the rotaries had no throttle. Some were on/off only. Others could cut a few cylinders to reduce power. I've seen some fly at Old Rhinebeck: http://www.oldrhinebeck.org/ If I'm not mistaken, they're still flying a few vintage WW I engines, not reconstructions. You can hear the pilots blipping the on/off switch as they come in for a landing. Marty |
![]() David CL Francis wrote: On Mon, 15 May 2006 at 18:20:24 in message .com, wrote: True, however in the context of a radial engine, a rotary is like a radial except that the crank is bolted to the aeroplane/motorcycle and the cylinders to the propeller/whatever. This seemed more exciting in a motorbike and therefore surely more desireable? Not really. All that rotating mass of a rotary engine could have some very nasty gyroscopic effects - might even make the bike too stable! It could matter whether the engine rotated in the same or opposite direction to the wheels. I rest my case. What could be more exciting that that? Sorry, if the joke was not clear:-) |
Wanted 5-cylinder B-75 Lawrence radial | Chris Wertman | Home Built | 5 | April 8th 10 02:11 AM |
HAVE YOU HEARD THE GOOD NEWS! | [email protected] | Soaring | 0 | January 26th 05 07:08 PM |
Good plans-built Light Sport Aircraft | Rob Schneider | Home Built | 15 | August 19th 04 05:50 PM |
Free Volksplane to good home, located in Chino Hills CA | Bryan Zinn | Home Built | 3 | July 18th 04 02:55 AM |
bulding a kitplane maybe Van's RV9A --- a good idea ????? | Flightdeck | Home Built | 10 | September 9th 03 07:20 PM |
