Protected airspace at O'Hare (for instrument approach and MAPs')
Al "TMcDonald" wrote in message news:ybWdnVGLQd3jERbZnZ2dnUVZ_vqdnZ2d@wideopenwest .com... This may be moot by now but don't worry, you're most likely to get the MDW 4 DP I've been flying out of MDW for six years and have never been assigned the Cicero departure procedure. I always get the MDW 4 and an assigned heading depending on direction of flight -- they don't want you wandering into ORD's airspace. Interestingly you'll probably never get the ILS to 13C either - although you may get the ILS4R circle to 13C. The only approach you'll get to a RW22 is a visual or ILS 31C circle to 22. Tom McDonald ATP/A&P/IA www.aviatortom.com "akiley" wrote in message oups.com... Hi all. I might attempt a flight from Ann Arbor KARB, to Chicago Midway KMDW in a few days. I have a question about the Midway Cicero two departure. There is an "obstacle" and a "vectors" version of this DP. Lets say I get that DP as part of my clearance, with a departure on runway 4R. The obstacle DP say "North bound departures assigned headings 360 degrees clockwise thru 080 degrees fly runway heading to 1.2 DME, turn right, climb on heading 100 degrees until leaving 2400, thence via tower assigned hdg/vector to assigned route." The victors DP say the same except no mention of the DME. I'm curious how this works and how tower would likely issue my takeoff clearance. But what if my assigned heading is 150 degrees. I guess I ignore the part of the DP that wants a turn to 100 degrees. But for obstacle clearance I do runway heading till 1.2 DME before tuning to 150 degrees. If my assigned heading is 040 degrees, I would fly rwy hdg till 1.2 DME, turn right to 100 degrees until leaving 2400, then turn back to 040 unless I get to 2400 feet before 1.2 DME?? Lastly, how would tower likely phrase my initial instruction? Seems this would be a good candidate for putting NO DP in the comments section of my flight plan! ... Aaron |
![]() TMcDonald wrote: I've been flying out of MDW for six years and have never been assigned the Cicero departure procedure. I always get the MDW 4 and an assigned heading depending on direction of flight But even the MDW 4 SID has the dogleg if the takeoff is from runways 4 and the assigned heading is northbound. Are you saying that they never assign northbound headings, or never assign runways 4L/R for takeoff? The bit about ORD in your message implies one of those. |
Midway Airport in Chicago Briefly Closed Today... | Jay Honeck | Piloting | 0 | February 24th 06 07:00 PM |
New Flight School At Chicago Midway Airport | AIR ADVENTURE82 | Piloting | 1 | January 16th 04 12:24 AM |
New Flight School At Chicago Midway Airport | AIR ADVENTURE82 | Aviation Marketplace | 0 | January 15th 04 11:53 PM |
New Flight School At Chicago Midway Airport | AIR ADVENTURE82 | Naval Aviation | 0 | January 15th 04 11:52 PM |
New Flight School At Chicago Midway Airport | AIR ADVENTURE82 | General Aviation | 0 | January 15th 04 11:52 PM |
