Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate?
Old March 30th 04, 12:13 AM
S Narayan
I am not so sure. See LVK ILS 25R (California), why is ADF required here?
Almost exclusively, TRACY is used as the IAF for this approach. Maybe if an
NDB is designated as an IAF, then ADF is required whether or not other IAFs
exist.
"Greg" wrote in message
om...
I'd guess because the only IAF is the NDB.
-greg
"S. Ramirez" wrote in message
om...
Does anyone know why the Mansfield OH MFD ILS RWY 32 approach plate has
ADF
or Radar Required written on it?
Thanks.
Simon Ramirez
Old March 30th 04, 01:28 AM
exist.
The missed approach goes to the LOM. Whenever they do that, ADF is always
required.
Old March 30th 04, 02:24 AM
S Narayan
wrote in message ...
here?
an
IAFs
exist.
required.
Makes perfect sense. Thanks.
Old March 30th 04, 03:04 AM
Max T, CFI
Livermore requires ADF for the missed approach (climbing right turn to 3000 and direct Reiga LOM).
Theoretically you could identify Reiga with the marker beacon receiver, but you wouldn't know for
sure whether you re-intercepted the localizer before or after Reiga.
On the MFD approach, I agree with those who say ADF or radar requirement is to identify the IAF.
Max T, MCFI.
S Narayan wrote in message ...
exist.
om...
-greg
om...
ADF
Thanks.
Simon Ramirez
Old March 30th 04, 06:16 AM
Jim Leedham
It appears to me needed to find the IAF if radar service is not available...
"Ray Andraka" wrote in message
Simon,
It may be for the missed, or it may be required to provide a fix where the
altimeter can be checked. In the case of my home 'drome, DME is required
because there are no VORs positioned sufficiently to provide a crossing
radial
for that identification. You need that ID to fly the localizer only, as
well as
to cross check the altimeter and glideslope when on the ILS. A marker
beacon
will also suffice, but recently the FAA has been changing the ILS
approaches so
that the intercepts are at even thousands of feet, and so the marker
beacons are
no longer in the right place.
ADF
There is speculation on another forum that ADF is required to establish
FAF for the localizer approach, but I argued that it is not required for
ILS approach, since intercept of the glideslope is the "FAF" for the ILS
approach. The approaches we have in FL are similar but do not have ADF
or
Radar Required written on them.
I can understand that without radar vectors, setting up for the ILS
approach
would require ADF so that one overflies the NDB outbound, stays within
ten
miles, and then comes back to intercept the glideslope; therefore, radar
vectors or ADF would be required for this approach. But this is obvious
on
other approach plates without spelling it out. Why is this verbiage
written
on this approach plate?
Thanks.
Simon Ramirez
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old March 31st 04, 01:00 AM
Tim Witt
Another possible reason for requiring the ADF or Radar is the fact
that the min safe altitude is defined off the compass locator. An ADF
(along with your compass/DG) would allow you to determine if you were
north or south of the locator. The localizer and marker would only
tell you when you were at the fix.
Old March 31st 04, 05:28 AM
J Haggerty
The only way to get to the final approach is either via Radar vector to
final (RADAR) or via Procedure Turn over the LOM (ADF), hence the note
"ADF or RADAR required". (FAAO 8260.19 para 214; PT's are not authorized
from 75 MHZ markers, so ADF is required for the PT). Without one of
those entries, there are no other instrument routes to the final approach.
JPH
S. Ramirez wrote:
Does anyone know why the Mansfield OH MFD ILS RWY 32 approach plate has ADF
There is speculation on another forum that ADF is required to establish the
FAF for the localizer approach, but I argued that it is not required for the
approach. The approaches we have in FL are similar but do not have ADF or
I can understand that without radar vectors, setting up for the ILS approach
would require ADF so that one overflies the NDB outbound, stays within ten
vectors or ADF would be required for this approach. But this is obvious on
other approach plates without spelling it out. Why is this verbiage written
Thanks.
Simon Ramirez
Old April 2nd 04, 11:13 AM
No way. The MSAs are not part of the regulatory or operational scheme for
IAPs in the United States.
Victor Airways on Approach Control Radar? Andrew Sarangan Instrument Flight Rules 2 February 26th 04 02:23 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 12:15 AM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 06:56 PM
Why is ADF required on ILS approach? Rich Raine Instrument Flight Rules 27 August 1st 03 05:14 PM
