Doors popping open in flight
Old May 19th 06, 03:50 PM posted to rec.aviation.piloting
Default Doors popping open in flight
I learned to fly in the summer so we always took off with the doors
open. It really helped keep us cooler. I was surprised teh first time I
found out that most pilots close the doors before flight, even when its
not cold.
-Robert
Old May 19th 06, 03:56 PM posted to rec.aviation.piloting
Bob
Some excellent replies here and it sounds like some, by pilots who have
experienced various doors opening, without disastrous result.
I've had a number of doors come open on quite a variety of aircraft
(does that say something about how really fragile they are?) and not
much more than a fright to either me, or the PAX. As part of my own
training regimine, I cause a door to open for many of the flights I
give with students to show them the non-existent danger or proper
procedures to close said door again.
Have had baggage doors pop open on several aircraft and had to land to
close them again. No big deal but certainly annoying. Open doors on
some aricraft that disrupted the airflow, like the Pipers, and
Beechcraft with the cabin doors that curved up on the fuselage. It is
more of a fright factor than anything. Vertical cabin doors are nearly
impossible to open more than a handspan in flight with airflow pushing
them shut.... Cabin windows, like the emergency exit on Barons, cause
nothing more than a loud roar and scare crap out of whoever is sitting
there....especially over the Sierras at night out of Tahoeggg
I participated in an accident investigation years ago on a Beech Queen
Air A65/80 that crashed after a baggage door opened in flight shortly
after takeoff at ABQ. It turned out the baggage was spilling out of the
compartment into the left propellor causing an engine failure. It was
not an aircraft design problem causing the crash, but one of pilot
error. I got involved simply because the aircraft that crashed was one
digit away from the one I was flying at the time and we used it to
attempt duplication of the crash scenario to see if it was aircraft
design or pilot error.
Bottom line is, I don't think an unexpected door opening on any
aircraft is cause for crash or panic. Structural integrity may be at
risk in some high speed exotic aircraft, but I don't know of any that
are that critically affected aerodynamically.
Same can be said of instrument failure and a pilot doing the panic
routine just because they didn't have the airspeed, or altimeter, or
compass, or ????
If you are still concerned, go up in the aircraft you normally fly with
an instructor or experienced pilot, and crack a door to see what it
does. If nothing else it will prove
how difficult it is to open the door enough to cause danger.
I remember the time whan I tried to make a parachute jump from the
backseat of a Piper TriPacer back in the early 60's and ......well
thats a story for another time after we have a San Pablo.....ggg
Ol Shy & Bashful
Old May 19th 06, 04:14 PM posted to rec.aviation.piloting
Having a door pop open should be a non-event. Air pressure will keep it from
opening more than an inch or two, the noise is distracting, papers fly
around the cockpit, and passengers freak out. IMHO it is a waste of time and
energy to attempt closure in flight...land and do it right.
There will be disturbed airflow over the horizontal stabilizer on the
open-door side, but nothing that the pilot cannot deal with.
Bob Gardner
"bob" wrote in message
How serious is it on small twin engines with only one door? Or with 2
doors, for that matter?
A friend of mine tells me that he once had a twin engine Piper crash to
investigate due to ditching. It was later learned upon the conclusion of
the investigation that a passenger in the back seat was trying to switch
places with someone in the front and the door inadvertently popped open.
At that point the investigator determined, from his own similar
experience, that the plane sunk like a rock due to critical disruption of
the airflow to that could not be corrected in flight.
--The door could not be closed again!---
As for my friend with his similar experience, his friend's hand was all
bloody from trying to hold it closed as much as he could. Fortunately,
they made a safe emergency landing at an island the just happened to be
nearby.
I've only flow small single engines and had NO IDEA how serious this
could be. They don't teach you that in flight school. Or is it because
single engines with only one door do not react the same as the twins.
Tell me the straight skinny so I know next time I go flying.
Thanks
Old May 19th 06, 04:49 PM posted to rec.aviation.piloting
There was a Mooney crash a few years back caused by the baggage door
opening in flight. Apparently the airflow over the tail was disrupted
on final and caused the crash. If the baggage door opens in flight the
recommendation in the Mooney community now is to keep your speed up on
final (which in a Mooney means find a really long runway).
-Robert
Old May 19th 06, 06:03 PM posted to rec.aviation.piloting
Several years ago, in Plane & Pilot magazine, there was an article on a
six-place Piper (Saratoga?). One of the pictures showed the upper latch of
the cabin door clearly unlatched, with the resulting gap visible. Apparently
they had no problems (except for the noise)
A few years ago, I departed IFR in my Seneca, and the forward door became
unlatched. There was a lot of wind noise, but like other posters here said,
there was no need
to hold the door open. I was flying from Palmer MA, to Islip, NY. (Turning
back to Palmer was out of the question) I made a request for a landing at
Groton, CT.
The controllers put my IFR in suspense, and
after landing I was on my merry (and quieter) way.
At
that point the investigator determined, from his own similar experience,
that the plane sunk like a rock due to critical disruption of the airflow
they
made a safe emergency landing at an island the just happened to be nearby.
could
be. They don't teach you that in flight school. Or is it because single
Thanks
Old May 19th 06, 06:48 PM posted to rec.aviation.piloting
Baggage can also exit the nose and go through the prop.
Beech added a second internal safety latch so the door only
open about an inch. The nose baggage door is streamlined
and does not cause too much air flow disruption.
The 206 forward door should be closed and locked on top of
the rear door of the pair and should not shield the aft
door. But I have seen this after the fact and suspect that
the pilot was trying to open the doors to drop something.
James H. Macklin
ATP,CFI,A&P
some support
"karl gruber" wrote in message
| The real problem with a twin is if the forward baggage
door opens, breaks
| off due to air loads, and goes through the prop.
| There have been several accidents due to this and all the
ones I remember
| were fatal. There was also an R-22 helicopter here in the
NW that just had
| the window come off the door a couple of years ago. That
window went through
| the tail rotor and caused a fatal crash. (This particular
window was an
| unapproved modification)
| Many Cessna 206 and 207 aircraft have had their rear cargo
door open in
| flight. This is a suicide door and hinges the door to the
rear. In this case
| the door slams back against the fuselage and causes
extensive damage, but
| the airplane is controllable.
| Best,
| Karl
| ATP,CFI,ETC
| "Curator" N185KG
door? Or with 2
Piper crash to
the conclusion of
trying to switch
similar
could. Fortunately,
happened to be
| nearby.
serious this
Or is it because
as the twins.
flying.
| Thanks
Old May 19th 06, 06:53 PM posted to rec.aviation.piloting
The critical issue would be Vmca with a door open, it has
not been flight tested and how much Vmca will increase is
just a guess.
James H. Macklin
ATP,CFI,A&P
some support
"Bob Gardner" wrote in message
will keep it from
waste of time and
right.
stabilizer on the
with.
| Bob Gardner
door? Or with 2
Piper crash to
the conclusion of
trying to switch
similar
could. Fortunately,
happened to be
| nearby.
serious this
Or is it because
as the twins.
flying.
| Thanks
Old May 19th 06, 09:15 PM posted to rec.aviation.piloting
ummm. let's change "hold the door open" to "hold the door closed"
"tom418" wrote in message
news:fTmbg.130490$k%3.2538@dukeread12...
Apparently
said,
there was no need
Groton, CT.
of
At
experience,
airflow
they
nearby.
could
single
Thanks
Old May 19th 06, 09:52 PM posted to rec.aviation.piloting
I posted about this a couple of weeks ago when the door on the Arrow II I
was flying unlatched.
A high-wing door -should- close itself enough that it won't disrupt airflow.
A low-wing door, which is what I was flying, is a little trickier, I THINK
because the low pressure over the wing draws the door out slightly, but the
airflow keeps it closed enough that I determined that trying to close it in
solo flight was more of a distraction that landing the airplane at a nearby
strip and resecuring the door.
My windbreaker and sectional vanished, though.
-c
Old May 19th 06, 09:58 PM posted to rec.aviation.piloting
I learned to fly in the summer so we always took off with the doors open.
It really helped keep us cooler. I was surprised teh first time I found
not cold.
Really? It's part of the run-up checklist, isn't it?
See if I ever go for a submarine ride with YOU! :
-c
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 04:17 PM
Dumb Reg question John Gaquin Piloting 67 May 4th 05 04:54 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
