At one time . . . and perhaps still . . . many GPSs for the civilian
market had a firmware limit on velocity . . . supposedly to prevent the use of such a unit in a weapons system. I recall a number of around 900 knots . . . but do not hold me to that. My old Garmin 45 and 48 had it. Not sure about my newer ones. |
In non aviation GPSs, at least the older ones, there really is a limitation
on speed. These units receive the signals from satellites one at a time. You have to receive 4 satellites in order to calculate a 3 dimensional position. If you are traveling extremely fast, than the signals from each satellite are received at different physical positions. This makes it hard for the GPS to resolve your position. Now here is the clincher : The speed at which the GPS unit can switch between satellites determines the top speed at which the GPS unit will work. Aviation GPS units have simultaneous receive channels so that they can receive up to 7 ( usually ) simultaneous signals. This eliminates the speed restriction ( unless you are traveling close to the speed of light). I think the simultaneous receive channels is starting to be used in higher end non-aviation GPSs, perhaps like the one in the Land Rover. In response to another posters comments about the reception inside the plane: Most auto GPSs do have external antennae ports. It is just as hard to get a signal through the top of a Land rover as it is a C130. My handheld hiking GPS also has an antenna port. "Peter Duniho" wrote in message ... "Jim Macklin" wrote in message news:Wksbg.22187$ZW3.9577@dukeread04... As for the speed limit on the GPS, I presume it is the rate at which the computer can identify new positions and the CPU can calculate, it is just a cheap $125 hand held. That doesn't make any sense. You can measure your position every 30 seconds and still get an accurate speed measurement. Whatever the reason for an upper bound on the displayed speed, it has nothing to do with the rate at which the computer in the GPS can do anything, whether identifying new positions, calculating, etc. Pete |
This is an artificial limit that manufacturers design into their GPS units
to force you to pay a premium for a device that can be used in an aircraft. Mike Schumann "Jim Macklin" wrote in message news:Wksbg.22187$ZW3.9577@dukeread04... I have no doubt that they did drive a car into a C130. I just question whether they went to the trouble to have the GPS in the car actually work while in the cargo bay. As for the speed limit on the GPS, I presume it is the rate at which the computer can identify new positions and the CPU can calculate, it is just a cheap $125 hand held. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Kingfish" wrote in message ups.com... | It is simulated, phony, ... | | I dunno, the documentary of the filming of the commercial seemed legit. | | | My recent hand held non-aviation GPS has a limit of 951 mph. | | What is the limit due to? Is there a refresh rate for a GPS receiver? | Is it a RAIM thing? | |
"Mike Schumann" wrote in message
nk.net... This is an artificial limit that manufacturers design into their GPS units to force you to pay a premium for a device that can be used in an aircraft. That may have been true in the past. I recall marine units that had a very low limit. However, I have a handheld hiking unit that has a plenty high limit (don't know what it is, but it works fine in the plane and even will show me my speed in knots), and that explanation certainly doesn't seem relevant to the 951 mph limit mentioned previously in this thread (unless the market they want to exclude are military and Concorde pilots). |
Kingfish wrote:
After seeing this commercial and viewing the documentary on the Land Rover website, I still can't figure out how they got the GPS unit in the truck to work while inside the plane. The doc. showed a guy sticking something to the plane's windows that might be an antenna, but I doubt a dash-mounted GPS in a car would have an external antenna input? Also they said the speed of the plane might be an issue for the GPS. Can't figure that part out either. Several thoughts: 1 - The display was probably simulated. 2 - HOWEVER! One doesn't need an antenna jack with a re-radiating antenna: http://safetracgps.com/Vortech.htm I have one, and it works great. If the display wasn't simulated, the Vortech could have been re-radiated the GPS signal inside the airplane, making the car's GPS work correctly. 3 - But then again, EVERY dash mounted OEM auto navigation system actually does have an antenna jack, it's wired to the _vehicle's_ external GPS antenna. G |
Kingfish wrote:
After seeing this commercial and viewing the documentary on the Land Rover website, I still can't figure out how they got the GPS unit in the truck to work while inside the plane. The doc. showed a guy sticking something to the plane's windows that might be an antenna, but I doubt a dash-mounted GPS in a car would have an external antenna input? Also they said the speed of the plane might be an issue for the GPS. Can't figure that part out either. I have a very old GPS that has a speed limit of 105 I think.... something in the low 100's ... I know me and a friend exceeded it in his BMW 3 series. However, pretty much any modern GPS has a speed limit in the 900 to 1000 mph range. I would think that an in dash GPS very well may have a remote antenna. Inside the dash could be a much worse location than on top of the dash. I would bet the antenna is directly under the plastic dash cover up as high as it can be in the center of the window or it could be up on the top somewhere. Either way wouldn't surprise me. Except for the Etrex and tiny units like that, I think all the bigger Garmin units all have an external antenna jack. I still think the TV ad is stupid. You can do the same thing with a sub $100 hand held GPS or a 300 year old sextant (they did have sextants back in 1706 didn't they?), a $5 watch and some charts. -- Chris W KE5GIX Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Commercial rating? | Paul Tomblin | Piloting | 43 | March 10th 06 12:19 AM |
Commercial rating: Am I wrong here? | gatt | Piloting | 12 | November 21st 05 12:35 AM |
NEW & UNOPENED: Gleim Commercial Pilot Knowledge Test (book AND Commercial Pilot Test Software) | Cecil Chapman | Products | 2 | November 13th 04 03:56 AM |
What to study for commercial written exam? | Dave | Piloting | 0 | August 9th 04 03:56 PM |
