Takeoff distance calculations?
Old May 22nd 06, 05:43 PM posted to rec.aviation.piloting
Default Takeoff distance calculations?
Frode Berg wrote:
"Stubby" skrev i melding
Frode Berg wrote:
"Casey Wilson" N2310D @ gmail.com skrev i melding
news:P01cg.5963$ix2.4053@trnddc03...
"Frode Berg" wrote in message
Hi!
I fly a Piper Arrow 180 hp from 1968
Anyone have a spreadsheet or programme to calculate takeoff and landing
distance letting you input weights, pressure alt, temperature?
Frode
I don't, but you do. Check out the POH that came with the aeroplane.
No POH with the 68 Arrow I'm afraid, but only an "Owners handbook"
Piper didn't start making POH's until a few years later, or so I've been
told.
Don't you need a weight and balance to take off? What do you do if you
get ramp checked?
Weight and balance is on a seperate sheet of paper.
Probably recalculated somewhere down the line after mods in panel or other
stuff.
I've never seen an official POH for the 68' Arrow, so I'm guessing they were
delivered with the Owners handbook, and the essential papers (like W&B) in a
binder or something.
Anyone know the facts around these things?
Frode
You need:
- the empty weight and CG location from the weighing certificate,
- the max. gross weight,
- allowed CG limits,
- moment arms of:
- from seats,
- rear seats,
- luggage locker, and
- fuel.
If the system in Norway resembles ours (Finland), you ought to
have a weighing certificate which is not older than 5 years.
The weighing will take care of any actual changes in empty
weight and CG position.
The rest of information should be obtainable from the manual.
Tauno Voipio
tauno voipio (at) iki fi
Old May 22nd 06, 04:19 AM posted to rec.aviation.piloting
What ever number you get from a calculation, a table or a
graph is only as accurate as your skill at reading the data.
A digital computer, whether a PDA or a desktop PC may return
results to 9 decimal places, but the answer is still just a
guess. Add 50% of the stuff that helps and 150% of the
stuff that hurts and then add 10-25% to take-off distance
and reduce climb by 50% and you'll live a lot longer.
James H. Macklin
ATP,CFI,A&P
some support
| Hi!
takeoff and landing
temperature?
| Frode
with the aeroplane.
handbook"
or so I've been
| told.
| Anyway, I'm all for paper, eraser and all that analogue
stuff of yesteryear
| and next year, but it would be fun to be able to calculate
light the Boeing
| drivers do the excact "estimated" runway distance needed.
| (excact estimated, can I say that??)
| Anyway, the Owners handbook has a few diagrams, but the
resolution for all
| the graphs I've ever seen in various other POH's aren't
too good.
| They give you a general idea, and there's lot's of
interpolation going down.
| Now, I'd never base a take off down to cm (or inches for
you yanks) of
| available runway, but putting in a couple of figures into
the PDA and
| getting a figure back out is an interesting idea to me.
| I can always grab the paper version and try to make a more
or less straight
| pencil line down the graph, but what the hey, the PDA is
sitting there, so
| an axact figure is possible, and I'm not scared by excact
calculations.
| Just another thing to put into my PDA and fiddle with
while waiting for the
| weather to clear up....
| Frode
Old May 22nd 06, 04:41 PM posted to rec.aviation.piloting
Excellent point. Especially when calculators were first commonly
available, I would see people report results to all eight digits, when
the input numbers would maybe support two digits of accuracy.
Another huge variable is pilot technique.
tom
Old May 23rd 06, 12:19 AM posted to rec.aviation.piloting
GiGo, garbage in, garbage out.
"tom" wrote in message
commonly
digits, when
accuracy.
| tom
Old May 22nd 06, 08:28 PM posted to rec.aviation.piloting
Hi,
3 things spring to mind, in no particular order;
1. Jepp Flitestar has a TO perf calculator,
2. There is a program for the Palm, DSSTOP that seems to work quite
well, &
3. I have "standard" TO and landing distances worked out based on 1000'
alt, 20 deg, max wt, 0 wind and a paved, level, dry runway. Any
deviation from these factors in a 'negative' direction will make me
reevaluate using the POH - ie higher temp or a wet grass strip. For the
Archer the distances to/from 50' are 700m for TO and 450m for landing.
HTH
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
15 M Time Management Nationals Kilo Charlie Soaring 12 August 15th 03 03:09 AM
