#11
Now THERE'S a hell of a thought. Consider a "bar" three inches long with
sensors at 1 and 2 inches. Betcha the temperature at the head (zero inches) is (temp 1) plus delta (temp 1 minus temp 2). Jim how about two temp sensors at measured intervals along the insulated bar, then assuming the temperature gradient is constant along the bar, you can work out the temp at the cylinder head. Colin =^.^= |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message ... "RST Engineering" wrote in message news ![]() Think of a series voltage divider with two known resistors in the middle and an unknown resistor attached to each end. What does the votage measured at the junction between the two known resistors tell you about the source voltage? Absolutely nothing. An equation in one unknown with two degrees of freedom is insoluble. There are an infinite number of correct answers and an infinite number of incorrect answers. HOWEVER, if you let me measure the voltage ACROSS one of those known resistors and THEN the voltage at the junction, I've got a fighting chance if you know what the bottom end resistor is tied to. Think of heat flow as current, temperature as voltage, the actual connecton between your divider and the heat source / sink like unknown resistors (area, contact, material all make a difference as in a high current circuit) your bar with the sensor in the middle is like the voltage drop in a transmission line - flow is a function of area, material, potential. Heat loss from the bar is a little harder - I guess in a high tension transmission line there is some leakage to ground across the insulators? And you thought you didn't know thermodynamics... fwiw, I think I would just buy a different sensor, eh? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Maybe use two sensors, one way out at the cold end, and the other 'half way out'. Use some sort of logic to sort out the cold end and adjust from there... |
![]() "RST Engineering (jw)" wrote in message ... Now THERE'S a hell of a thought. Consider a "bar" three inches long with sensors at 1 and 2 inches. Betcha the temperature at the head (zero inches) is (temp 1) plus delta (temp 1 minus temp 2). Jim how about two temp sensors at measured intervals along the insulated bar, then assuming the temperature gradient is constant along the bar, you can work out the temp at the cylinder head. Colin =^.^= Hmmm, just posted that...must be a fairly good way. Think cold junction compensation.... |
On Mon, 29 May 2006 17:48:07 -0700, the renowned "RST Engineering
\(jw\)" wrote: Now THERE'S a hell of a thought. Consider a "bar" three inches long with sensors at 1 and 2 inches. Betcha the temperature at the head (zero inches) is (temp 1) plus delta (temp 1 minus temp 2). Jim Are you assuming negligible heat loss from the bar itself? Best regards, Spehro Pefhany -- "it's the network..." "The Journey is the reward" Info for manufacturers: http://www.trexon.com Embedded software/hardware/analog Info for designers: http://www.speff.com |
![]() "Spehro Pefhany" wrote in message ... On Mon, 29 May 2006 17:48:07 -0700, the renowned "RST Engineering \(jw\)" wrote: Now THERE'S a hell of a thought. Consider a "bar" three inches long with sensors at 1 and 2 inches. Betcha the temperature at the head (zero inches) is (temp 1) plus delta (temp 1 minus temp 2). Jim Are you assuming negligible heat loss from the bar itself? yes if the bar is insulated well enough between the sensors and the head, maybe with 3 sensors you could comepnsate for the heat loss through the insulation wich would make for a curved temperature profile along the bar. Colin =^.^= |
On Mon, 29 May 2006 09:51:40 -0700, "RST Engineering \(jw\)"
wrote: I have a thermometer that reads from 0 to 200°F. I'm trying to measure a cylinder head on an aircooled engine where my range of interest goes from, say, 200 to 400°F. The classic way of measuring this temperature is with a thermocouple mounted on a copper washer underneath the spark plug of the cylinder that you determine (by trial and error) to be the hottest. I can think of several ways of measuring a cooler spot on the cylinder that will probably be in rough proportion to the actual temperature at the plug seat, but most of them are dependent on the airflow over the cylinder(s) remaining constant from day to day. With the baffling on the engine being rather thin and wobbly, I can't count on this airflow being truly constant. The sensor on my thermometer is a plain old silicon diode that won't directly take the heat that I'm trying to measure. Anybody got a clever way of making a thermal divider that won't be subject to the day to day shuffle of the airflow over the cylinders? Jim Jim would it be possible to tackle the problem another way and use one of the off contact laser aimed temperature sensors? |
Jim.................
This might be fun to play with: http://www2.towerhobbies.com/cgi-bin...?&I=LXHEM4&P=0 I have one of these: http://www2.towerhobbies.com/cgi-bin...&I=LXEMG5&P=ML I use it for all sorts of things, BBQ, smoker, engines, electronic equipment, et cetera. Rich S. |
"Rich S." wrote in message
... Jim................. This might be fun to play with: http://www2.towerhobbies.com/cgi-bin...?&I=LXHEM4&P=0 Now you just need to figure out how to connect all these sensors to a bluetooth transceiver so's you don't have to string any wires. . . Rich S. |
Themi thermal locator | John Jones | Soaring | 5 | April 30th 04 04:16 AM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Home Built | 0 | April 29th 04 06:43 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
