Ellison throttle body
Old June 21st 06, 11:20 AM posted to rec.aviation.homebuilt
Default Ellison throttle body
ADK wrote:
I would like to hear from anyone with experience with this unit, good or
bad. I would also like to know if their sizing as it is printed on their
website, is accurate. I don't know if engine efficiency is a factor in the
sizing, for instance, does a 180 hp Lycoming require the same size throttle
body as a 180 hp Subaru engine. They are both producing 180 hp, but with
grossly different displacements. I have written the company but they don't
seem to be interested in returning email.
Ours has worked great... we have the mixture stops adjusted so that
pulling full lean leaves enough power for taxi and clearing the plugs
after a flight, instead of cutting the engine off. Never had any
problems at all, though we do run into cylinder 3 running leaner than
the others.
Also (and putting flame-proof suit on), we have never used carb heat
with it--the system is installed (and IIRC we had to sign a waiver
saying we would install such a system) but I think we've turned it on
twice in 450 hours, just to see if there was a noticable difference.
Don't take my advice though. This should not be interpreted in any way
as an endorsement of not using carb heat.
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Another body in a wheel well..... John Gaquin Piloting 13 January 2nd 04 09:16 PM
Is possible to pair a Saitek X35 throttle and a MS Sidewinder Pro? Riccardo Simulators 3 December 24th 03 06:07 PM
Ellison TBI and ROTAX 582 Bill Elliott Home Built 0 December 22nd 03 05:58 PM
Rotax 912 Full Throttle Springs Mark Callahan Home Built 0 July 5th 03 01:31 PM
