#11
Thanks, everyone. I will work diligently this weekend to "fly it on"
for a wheel-type landing. On 5/30/2006 8:26 PM, Mitty wrote the following: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! |
I agree with your instructor, Let it land on the main wheel then gently
set the tailwheel on the groud. I find the best way to arrest the descent it to reduce the spoilers just as I start the Flair. This will just about stop your descent and you should be floating down the runway a foot or so off of the runway. It will eventually settle on the runway or you can hurry up the process by adding the spoilers back. Works really well for spot landings. Brian CFIIG/ASEL |
Mitty wrote:
I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. In a discussion at Owl Canyon Gliderport (Colorado), I stated that I expect a pilot to fly a stabilized approach to the round out, and then fly in level attitude, and push off "a little" (to me means "about an inch") of spoiler, to stop the sink, in order to settle to the ground in level flight attitude and not land tail first, nor land in "two point" attitude. Yes, the above states that I expect a small spoiler adjustment near the ground. My written reference sources a The "Joy of Soaring", (1969 version), on page 47, says to fly level (parallel) to the ground, "round out": "..., the pilot smoothly rounds out the glide so that the flight path becomes parallel to the ground at an altitude of a foot or two." The "Joy of Soaring", (1969 version), on page 47, says to adjust the spoilers near the ground: ".... he (the pilot) regulates deceleration with the spoilers, closing them to extend the float, and opening them wider to shorten it." In the "American Soaring Handbook", Book 2: Training, paragraph 7c4, page 40 states: "Unless a sailplane is to be landed in a minimum distance, it is best to land it at a speed above stall by rolling the wheel on he runway and holding it down in a manner similar to the procedure for a wheel landing in a light-plane. ... it is important ... to apply a slight forward force on the wheel or stick to prevent ballooning." Further, in the "American Soaring Handbook", Book 2: Training, paragraph 8e4, page 66 states: "In making a landing, the student should be taught to hold a nearly constant air speed on the final approach until within about 25 feet of the ground. At this point the nose is gradually raised by constant back pressure on the stick to produce a level-off at about six inches above the ground. If one tries to maintain an altitude of six inches without pulling the stick all the way back, the main wheel will eventually touch the ground. When this happens, the student should be taught to ease forward on the stick with just enough force to hold the wheel on the ground ... as the airspeed decreases the stick should be gradually brought to the full aft position to hold the tail down without having the sailplane take to the air". Please note that I teach a stabilized approach, with constant airspeed, to round out, and I do not teach a flare. I believe that airplanes are flared to a landing to arrive in a nose up attitude at stall, while gliders are flown onto the ground above stall, in level flight attitude, and landed on the main wheel only. "Pushing off a little spoiler during the round out will slow the descent rate, and is intended to result in a roll-it-on landing." Note that as a pilot progresses to higher performance ships, (33:1 L/D), there is less (to NO) need to reduce the spoilers. Of course, spelling errors are mine. Is my explanation sufficient, or would something be better explained differently? Best regards, Jer/ "Flight instruction and mountain flying are my vocations!" -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jeratfrii.com http://users.frii.com/jer/ C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 240 Young Eagles! |
![]() "Pete Brown" wrote in message ... Mitty wrote: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. Listen to the instructor. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. Well learn a new technique...Its easy and fun. The normal landing is similar to a wheel landing in a conventional (tail wheel) airplane. One thing to consider is that the main wheels of gliders often barely peek out from the fuze (to reduce drag) while an airplane's main wheels may stick out three or four feet. A hefty flair in some gliders (they vary) will bang the hell out the the tailwheel long before the main wheel can make contact with the ground. The learning problem works both ways. I flew gliders long before I flew airplanes and CFIs still complain that my touchdowns are "kinda flat". I also have a terrible time remembering that it is perfectly OK to land an airplane in a crosswind without first leveling the wings. Vaughn |
![]() One thing to consider is that the main wheels of gliders often barely peek out from the fuze (to reduce drag) while an airplane's main wheels may stick out three or four feet. A hefty flair in some gliders (they vary) will bang the hell out the the tailwheel long before the main wheel can make contact with the ground. I have watched an L23 landed this way, Tailwheel touches while the main wheel is still 3 to 4 feet off of the ground. The main wheel will slam down pretty hard when this is done. Doesn't look like a good landing practice to me. Brian CFIIG/ASEL |
Landing the Blanik L-23. Some thoughts for your consideration:
Look at the cover of your MARCH 2006 SOARING magazine to see a proper "round-out" attitude when landing a Blanik L-23. Nice photo. I made copies for my Blanik briefing handouts. Note the positive wing angle of attack and incidence in that photo. Fly the wing. Read your Blanik flight manual about landing technique. Chapter / para. 4.4.4. It says to land the L-23 on the main. For other gliders, read their flight manuals! Think "round-out" rather than "flare" or "wheel landing". "Round-out" is probably British, so read Derek Piggott. He's British and a brilliant instructor. Mentor to us all. Also try a little less than full airbrake - just a bit - to make a nice landing in an L-23. Note that the handle travel in the cockpit "slot" does not correspond to the amount of airbrake out. Just bring it forward an inch or so, to go from full airbrake to half airbrake. If flying an older Blanik L-13, make darn sure you've got the airbrake handle in hand and not the flap handle! If you are a light pilot, apply full airbrake after touchdown to stick it on the ground. If you bounce or "balloon", reduce airbrake to zero, pitch nose down a bit and try it again! However, when landing off-airport consider using full airbrake and two-point for low energy, less roll out. Heavy wheel braking will put a Blanik up on its nose, followed by a hard bang down onto the tailwheel. Never push a Blanik backwards especially in grass or rough ground. Pull it by a shoulder harness strap, never by the wingtips. Never pull ANY glider by the wingtips. (See flight manual.) At Marfa in west Texas, I train pilots of all skill levels in my two Blanik L-23's. They are quite stout. They are NOT fragile, nor is anything wrong with the tailwheel design. IF you bang the tail down hard many times or allow it to land tailwheel first, over time, after many, many hard tailwheel landings, you might break something. Fly it as recommended by the manufacturer. Read the instructions! This concept works well with most flying machines, and when assembling furniture from IKEA. Maintain your glider. Check the tailwheel area often and replace the three rubber donuts as required. Blanik America has them in stock. Get some spare donuts. Drop the tailwheel out and grease the tailwheel "post". Change the centering spring if needed. Grease the main gear strut fittings often and especially when changing the tire - it's easier without the tire in there! Blanik America can supply the special grease gun fitting adaptor thingy. Keep the main gear shock strut serviced with nitrogen. Again, read the service manual that came with your glider. Vitek at Blanik America is very good about obtaining the Czech parts and giving advice. As for "wheel landings", I once suggested to a transition (Cub) pilot that he try landing my Blanik like he would wheel-land a Cub. Geez, at 3 feet above the runway he shoved the stick forward hard and fast. Banged us down so hard I was sure we broke something, but the mighty Blanik took the punishment without damage. As I said, stout aircraft. It wasn't good Cub wheel-landing technique either. (As an instructor, one learns to be careful about what you suggest. Best to take the stick and demonstrate it as many times as needed rather than risk damage by the heavy-handed student who is guessing at the proper site picture / technique.) So think "round-out". Get the site picture right. Smile. Relax. Broaden out your peripheral vision. See it all. Be one with the glider. Listen to your Instructor, and when you go solo in the Blanik L-23, don't try it any other way. Have fun! Burt Compton, Master CFIG, FAA Designated Pilot Examiner Marfa Gliders, west Texas www.flygliders.com |
![]() Here is the cover photo that Burt is referencing. http://www.ssa.org/test/Covers/Cover200603_large.jpg 'Yey Adrian Soaring!!' At 04:06 01 June 2006, Burt Compton - Marfa wrote: Landing the Blanik L-23. Some thoughts for your consideration: Look at the cover of your MARCH 2006 SOARING magazine to see a proper 'round-out' attitude when landing a Blanik L-23. Nice photo. I made copies for my Blanik briefing handouts. Note the positive wing angle of attack and incidence in that photo. Fly the wing. |
"There is an improved
tailwheel on the new L-23's that is fixed and does not caster" Yep. The new L23 we just bought has. It's a goddamn pain in the back lifting the tail up to turn the glider around. Having someone sit in the front seat helps. The CuNim club in Alberta has an L-13 with a fixed tailwheel and a Grob type removable taildolly which was all properly engineered as a Limited Supplemental Type Certificate. It would be nice to have something like that on our L-23. Probably a little expensive though. The funny thing is we never had any trouble with the tailwheels on the L-13's we've had but one of our L-23 with a castoring tailwheel had it's tailwheel broken. The tail slammed into the ground after the glider came to a stop, nose down, with the wheelbrake full on. |
I think the castering tailwheel makes landing rollout much easier for new
students. It makes it possible to steer the ship after a less-than-straight touchdown. That's one of the things to learn when graduading to a more advanced ship: that you may not have much freedom to turn. Landing perfectly straight is an extra demand on a new student. We have a couple of L-13's and have never had a problem with breaking the tailwheels. Earlier someone said that you should not push them backwards, but we do it all the time. We are just careful when pushing up onto a runway or road: take it slow as you get the wheel up. wrote in message oups.com... "There is an improved tailwheel on the new L-23's that is fixed and does not caster" Yep. The new L23 we just bought has. It's a goddamn pain in the back lifting the tail up to turn the glider around. Having someone sit in the front seat helps. The CuNim club in Alberta has an L-13 with a fixed tailwheel and a Grob type removable taildolly which was all properly engineered as a Limited Supplemental Type Certificate. It would be nice to have something like that on our L-23. Probably a little expensive though. The funny thing is we never had any trouble with the tailwheels on the L-13's we've had but one of our L-23 with a castoring tailwheel had it's tailwheel broken. The tail slammed into the ground after the glider came to a stop, nose down, with the wheelbrake full on. |
On Tuesday, May 30, 2006 at 9:26:13 PM UTC-4, Mitty wrote:
I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! The flare required is minuscule ( to barely any) in the Blanik in comparison to a powered aircraft. Flaring will cause you to land on the tail wheel , followed by a hard nose wheel landing.It is Pretty much desirable to be in a straight and level attitude and settle in to a touch down. Landing the Blank in a controlled, straight and virtually level attitude will make the nose wheel touch first which is desirable and less stressful on the aircraft. In level attitude, the nose wheel is lower than the tailwheel . Don't know if you've done any helicopter flying, but the controls on the gliders are just as sensitive and responsive by comparison. In my experience, when I flare to stall for a landing in ,say a 152 cessna, I lose sight of what's in front of me and have to look out to the side of the aircraft to keep an eye on the runway. When landing the Blanik, the site picture of the runway in front of you should stay constant. Keep flying the glider , even on rollout and keep it level and off the tail wheel as long as possible |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
