On Wed, 31 May 2006 17:51:14 -0500, "Dan Luke"
wrote: "180pilot" wrote: The bottom line is that at the moment producing Ethanol from corn wastes more energy than it makes according to experts. I ain't got a dog in this fight, but any time I read a sentence like that, my bs meter starts to twitch. What experts? Employed by whom? What are their qualifications? What peer-reviewed studies did they publish? Well, you can do a search and find a good many studies by legit? universities and corporations. Unfortunately the results for "Net energy Gain" for alcohol production vary from a negative 50% to an outlandish positive of several hundred percent (by a university). IOW if you hunt you will be able to find a study that will support just about any position. Some of these studies are commissioned and come with criteria. You some times really have to dig to find said criteria and often it's not available. Without knowing the criteria under which the study was undertaken leaves the study pretty much meaningless to me. That is unless you place complete blind faith in both who ever did the study and who ever commissioned it. "Department of Energy" should be a good starting point for the feds and states although they have a way of cataloging docs that could be considered camouflage.sigh The validity of Wipi is often questioned, but it's a good starting place to find the referenced studies and then hunt for the studies. The good articles will have references back to specific studies. I've been following/studying alternative energy sources for some time and have had to devote far more time digging than I would have liked, or planed. I've also worked with some researchers with both passive and active solar as well although it was some time back. As near as I can discover the "general consensus" is a small "net energy gain" when producing alcohol. This took into account using the byproducts as well and came up with about a 50% net energy gain. That is not a lot and the real price of alcohol when subsidies for both growing the corn and producing the alcohol is around $3.50 a gallon. "They" are going to be building a large Ethyl Alcohol plant about 30 miles from here in an industrial park at Alma Michigan. Probably close to the site where one failed back in the 70s energy crisis. "Currently" there is no large scale, "wide spread", economical alternative energy source, but there are several areas where large farms of wind generators are proving to be viable. They are running into environmental concerns as far as locations particularly here in Michigan. We have few areas within the state that would work well, but we have several "off shore" that would work very well. However the "shore dwellers" in both Wisconsin and Michigan are basically saying "Not in the middle of our tourist industry!". Nor are these farms cheap with a price tag some times passing several billion. (That was with a "B".) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
The bottom line is that at the moment producing Ethanol from corn wastes more energy than it makes according to experts. Well, use some rational thinking... We grow corn to make alcohol... What does the tractor that plowed and planted the field burn? diesel mostly What do the fertilizer and pesticides put on the field come from? petroleum base What does the combine that harvests the field burn? gas or diesel What does the truck that takes the corn to the local elevator burn? diesel or gas What does the train that moves the corn to market burn? diesel What does the electric motor(s) at the alcohol plant get the current from - and ditto the lights, air conditioners, furnaces, etc? (natural gas mostly) What do the employees at the alcohol plant burn to get there for work each day? gas mostly Where does the heat to distill the mash come from? natural gas What does the truck burn to take the alcohol to the gasoline terminal? diesel ************************************************** *********************************************** Where the oil company cheerfully puts 5% of that 70 cents a gallon alcohol at their cost into the gasoline and charges you three bucks or so for each gallon of alcohol they sell you - a vastly bigger profit margin than they get on the gasoline... Plus, the alcohol decreases your gas mileage so you have to buy fuel more often... Jeez, if you are an oil executive on a pay plus bonus salary, what's not to like ?????? ************************************************** ************************************************** Anyway, those of you who favor alcohol explain to me how burning alcohol reduces oil imports... denny |
"Denny" wrote: The bottom line is that at the moment producing Ethanol from corn wastes more energy than it makes according to experts. Well, use some rational thinking... We grow corn to make alcohol... What does the tractor that plowed and planted the field burn? diesel mostly What do the fertilizer and pesticides put on the field come from? petroleum base What does the combine that harvests the field burn? gas or diesel What does the truck that takes the corn to the local elevator burn? diesel or gas What does the train that moves the corn to market burn? diesel What does the electric motor(s) at the alcohol plant get the current from - and ditto the lights, air conditioners, furnaces, etc? (natural gas mostly) What do the employees at the alcohol plant burn to get there for work each day? gas mostly Where does the heat to distill the mash come from? natural gas What does the truck burn to take the alcohol to the gasoline terminal? diesel Those kinds of questions also apply to the exploration for and extraction of oil, the transportation and refining of crude, and the transportaton of gasoline. It takes energy to make energy; this is not news. Also, gasoline has enormous hidden costs related to our (U. S.) international efforts, military and otherwise, to maintain the security of imported oil sources. The question is: what are the real figures on energy margin recovery for ethanol? I can find a lot of hand-waving pro and con, but I'm having trouble locating any scientific/economic study that seems objective and trustworthy. [snip] Anyway, those of you who favor alcohol explain to me how burning alcohol reduces oil imports... Amen. -- Dan 'Gut feeling' Intestinologists concur that the human gut does not contain any rational thoughts. What the human gut *is* full of is moderately well known. |
"Dan Luke" wrote: Those kinds of questions also apply to the exploration for and extraction of oil, the transportation and refining of crude, and the transportaton of gasoline. It takes energy to make energy; this is not news. Also, gasoline has enormous hidden costs related to our (U. S.) international efforts, military and otherwise, to maintain the security of imported oil sources. The same military is used to protect the land and people who would grow corn for ethanol. -- Bob Noel Looking for a sig the lawyers will hate |
Exactly. But it makes dumb people *feel* good so lets do it.
ktbr wrote:
Exactly. But it makes dumb people *feel* good so lets do it. Right up there with the "safety" aspects of vehicles with tendencies to roll over and terrible panic maneuver habits? Let the marketeers roll... G |
Roger wrote:
: What experts? Employed by whom? What are their qualifications? What : peer-reviewed studies did they publish? : Well, you can do a search and find a good many studies by legit? : universities and corporations. Unfortunately the results for "Net : energy Gain" for alcohol production vary from a negative 50% to an : outlandish positive of several hundred percent (by a university). IOW : if you hunt you will be able to find a study that will support just : about any position. Well-said. As has been said before, there are "lies, damn lies, and statistics." Depending on which studies you want to read making various assumptions on "environmental costs," "incidental costs," and "byproduct credits," the studies tend to ready anwhere from a 20% on the Joule fossil-fuel energy budget to a 1-4x per Joule fossile-fuel budget. In any event, it is certainly not the magic-bullet that many people tout. In Brazil it works well due to the relative ease of conversion sugar cane as compared to corn. Check out the papers by Pimentel for the last 30 years. He may be at one extreme end of the spectrum (20%), but the other extreme end (1-4x) isn't enough to devote huge resources to encourage. -Cory ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Dan Luke wrote: "180pilot" wrote: The bottom line is that at the moment producing Ethanol from corn wastes more energy than it makes according to experts. I ain't got a dog in this fight, but any time I read a sentence like that, my bs meter starts to twitch. What experts? Employed by whom? What are their qualifications? What peer-reviewed studies did they publish? Coincidently, yesterday the latest Car and Driver arrived in my mailbox with a long article summarizing the case against ethanol pretty succinctly -- it quotes several studies including a meta study done by the University of California. It might be worth picking one up at the newsstand if this issue really interests you. I checked their website, the article isn't up there yet. One thing I learned is that one reason car makers love E85 is that it gives them a bonus on the CAFE standards. Only the gasoline that is burned counts, which means they get to multiply the gas mileage of an E85 car by 7 (1/0.15)when computing its contribution to fleet average MPG. This was estimated be with $200 million a year to GM alone. Damn, everywhere you look with ethanol, there's a subsidy or preference of some sort involved, isn't there? |
("xyzzy" wrote)
One thing I learned is that one reason car makers love E85 is that it gives them a bonus on the CAFE standards. Only the gasoline that is burned counts, which means they get to multiply the gas mileage of an E85 car by 7 (1/0.15)when computing its contribution to fleet average MPG. This was estimated be with $200 million a year to GM alone. Simple enough to correct - call it Fuel Mileage. Montblack |
| Thread Tools | |
| Display Modes | |
| Any good aviation clip-art? | zingzang | Piloting | 2 | August 11th 05 02:32 AM |
| We lost a good one.... | [email protected] | Piloting | 10 | May 28th 05 06:21 AM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| HAVE YOU HEARD THE GOOD NEWS! | [email protected] | Soaring | 0 | January 26th 05 08:08 PM |
| Commander gives Navy airframe plan good review | Otis Willie | Military Aviation | 0 | July 8th 03 10:10 PM |
