PZL compass repair - Tom ?
Old June 4th 06, 07:41 AM posted to rec.aviation.soaring
Default PZL compass repair - Tom ? Bumper ?
The problem with regular epoxy is that when cured it is relatively hard and
brittle. Thermal expansion and contraction of the epoxy may not be the same
as the plastic being glued.
Loctite "Depend 330" when cured remains flexible and bonds well to a variety
of materials. It will, for instance, bond metal directly to fiberglass with
no lay-up of FRP over the metal required. Useful stuff to have around, but
it does have a limited shelf life, so the large "economy" size ain't.
bumper
"5Z" wrote in message
Hi Tom - Two more questions:
Yours was definitely leaking out the threads
in the back ?
Yes. I'd put it on the dash of the car on a paper towel and let the
winter sun heat it up, then look for damp spots. Tried to figure out
some kind of tool to open it up and look for O ring to replace, etc,
but all attempts at opening failed, as I didn't want to break it.
Loctite 330 costs more than our gliders.
From the Loctite product data it looks like
good-ole Loctite 243 is more appropriate
in any case - What am I missing here ?
Probably any decent epoxy stuff will do the trick. Bumper's into
exotic tools & such...
I roughed up the gap with a Moto-Tool first.
-Tom
Old June 4th 06, 02:27 PM posted to rec.aviation.soaring
Not familiar with Loctite 330. How does it compare with Aviation Permatex
for this use?
Hartley Falbaum
"bumper" wrote in message
and brittle. Thermal expansion and contraction of the epoxy may not be the
same as the plastic being glued.
variety of materials. It will, for instance, bond metal directly to
fiberglass with no lay-up of FRP over the metal required. Useful stuff to
have around, but it does have a limited shelf life, so the large "economy"
size ain't.
bumper
in the back ?
-Tom
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
PZL compass repair 5Z Soaring 16 December 1st 05 12:40 AM
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 02:41 PM
Strange compass behavior me Owning 10 February 14th 04 05:24 AM
Bubble Face Compass Repair Gene Hetsel Restoration 1 January 9th 04 05:59 AM
