#11
Peter wrote:
Sam Spade wrote Forcing the scaling to 0.3 does not result in approach mode. Approach mode includes approach RAIM and some additional accuracy that is not apparent to the pilot. Can you indicate how this additional accuracy is implemented? No, I have been told this by one of Garmin's 400/500 avionics engineers. I am not an avionics engineer. Those folks live in a different world. ;-) So, if you fly an approach with 0.3 forced, and the approach light/annunicator is not active, you are flying the approach effectively in terminal mode. Yes, I see that. |
On 06/16/06 03:40, Peter wrote:
Mark Hansen wrote: The Garmin series of GPS will move into SUSP mode when you turn outbound for the procedure turn, or when you reach the MAP. Basically, it stops the GPS from auto-sequencing to the next waypoint. The KLN94 (and others?) goes into OBS mode when you get to the MAP (which is essentially the same thing) but requires the pilot to set OBS mode manually when approaching the procedure turn fix (note that it reminds the pilot to do this when approaching an IAF that is in the same location as a FAF, etc.) Thank you very much for this. I'd need to spend some serious time to get my head around these possibilities. Do you Americans go on a GPS training course? I went on a Honeywell one in 2002 but they never covered these "real life" procedures. They just went through what the thing does. I read the Pilot's Guide, but that's a pretty dry read without any real practical experience. However, as I mentioned earlier, I just completed an Instrument Proficiency Check which included heavy use of the KLN-94. This helped all the information 'sink in'. At the MAP (having flown a GPS approach) if going missed then I would climb (of course) and fly the aircraft manually, or perhaps with the AP on HDG mode and with ALT capture set to the missed approach target altitude. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Peter wrote:
I'd need to spend some serious time to get my head around these possibilities. Do you Americans go on a GPS training course? I went on a Honeywell one in 2002 but they never covered these "real life" procedures. They just went through what the thing does. Education is seriously lacking. There are a lot of pilots flying behind these boxes who can't get beyond GO-TO. Good luck finding an instructor who really knows. Of course the knowledge is to a great extent model specific. Knowing how to use a Garmin tells you little about how to use a B-K. It's a mess. There are a few instructors who specialize in this kind of instruction, but you have to look for them. Standby for a series of instructors to post "hire me, I know how to do it". Dave |
Dave Butler wrote:
Standby for a series of instructors to post "hire me, I know how to do it". And, take all of that with a big salt shaker. A friend of mine did a check-out last year in a new G-1000 Cessna 182. The CFI-I was "factory trained," so to speak. He was pretty good, except when he chewed out my friend for not remaining within the Garmin magenta oval for a holding pattern. Simply put, that is a crock. |
On 06/16/06 08:34, Dave Butler wrote:
Peter wrote: I'd need to spend some serious time to get my head around these possibilities. Do you Americans go on a GPS training course? I went on a Honeywell one in 2002 but they never covered these "real life" procedures. They just went through what the thing does. Education is seriously lacking. There are a lot of pilots flying behind these boxes who can't get beyond GO-TO. Good luck finding an instructor who really knows. Of course the knowledge is to a great extent model specific. Knowing how to use a Garmin tells you little about how to use a B-K. It's a mess. There are a few instructors who specialize in this kind of instruction, but you have to look for them. Standby for a series of instructors to post "hire me, I know how to do it". Dave I've been "trained" on both the Garmin GNS-430 and KLN-94. It definitely helps to see more than one box, as you begin to see the items that are GPS related, rather than just Garmin/King related. I've had instructors that seemed to really understand the GPS, and some that knew little more than loading and executing approaches and using Direct-To. Mostly, though, they seemed to have a real good understanding of how to use the thing. Perhaps I've been lucky. I expect having experience with more than one box will make it easier to transition to any new box as well, but only time will tell. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Roy Smith" wrote in message ... In article , Peter wrote: Sam Spade wrote And, suspend may occur more than once with a complex missed approach procedure. What is "suspend"? A flight plan consists of a sequence of waypoints. So, for example, let's say I've got POU CMK HPN programmed in. As I depart POU, it makes CMK the active waypoint and starts navigating to there. Once I reach CMK, it will automatically sequence over to HPN being the active waypoint. Now, before I get to CMK, the controller says, "hold at CMK, blah, blah, blah". If I leave things as normal, once I reach CMK the first time, it'll sequence over to HPN, which is a bad thing. I want it to stay on CMK as I keep going round and round until the guy says, "proceed on course" and *then* I want it to sequence over to HPN. So, what I do is put the GPS into suspend mode (well, in reality, it goes into suspend mode automatically when I program in the hold). When I'm done holding, I take it out of suspend mode, and it sequences over to the next waypoint. How do you switch it into SUSPEND mode ? Regards |
Kyprianos Biris wrote:
How do you switch it into SUSPEND mode ? Regards I can only speak to the Garmin 400/500 series. SUSPEND is built into the nav database by Garmin for an approach. At a minimum, there is SUSPEND for the missed approach point. It is cleared by hitting the OBS button. Other times SUSPEND occurs: 1. At a course reversal hold, SUSPEND lasts for one circuit in the hold. 2. At a published missed approach hold, SUSPEND lasts indefinately until cancelled. 3. SUSPEND can occur more than once for a missed approach, such as where an altitude has to be achieved before a turn can be made (example KJAC ILS 19) |
"Sam Spade" wrote in message news:Tpwmg.34487$AB3.587@fed1read02...
Kyprianos Biris wrote: How do you switch it into SUSPEND mode ? Regards I can only speak to the Garmin 400/500 series. SUSPEND is built into the nav database by Garmin for an approach. At a minimum, there is SUSPEND for the missed approach point. It is cleared by hitting the OBS button. Other times SUSPEND occurs: 1. At a course reversal hold, SUSPEND lasts for one circuit in the hold. 2. At a published missed approach hold, SUSPEND lasts indefinately until cancelled. 3. SUSPEND can occur more than once for a missed approach, such as where an altitude has to be achieved before a turn can be made (example KJAC ILS 19) Kyprianos asked how to switch *into* "suspend" mode, not *out* of it. I don't have access to a KLN94, so I can't answer his question, either. But on my CNX80, the "SUSP" button toggles into and out of the "Suspend" mode. Furthermore, the CNX80/GNS480 does not automatically "suspend" at the MAP. If the aircraft doesn't land, the missed approach continues to sequence. |
On 06/22/06 08:02, John R. Copeland wrote:
"Sam Spade" wrote in message news:Tpwmg.34487$AB3.587@fed1read02... Kyprianos Biris wrote: How do you switch it into SUSPEND mode ? Regards I can only speak to the Garmin 400/500 series. SUSPEND is built into the nav database by Garmin for an approach. At a minimum, there is SUSPEND for the missed approach point. It is cleared by hitting the OBS button. Other times SUSPEND occurs: 1. At a course reversal hold, SUSPEND lasts for one circuit in the hold. 2. At a published missed approach hold, SUSPEND lasts indefinately until cancelled. 3. SUSPEND can occur more than once for a missed approach, such as where an altitude has to be achieved before a turn can be made (example KJAC ILS 19) Kyprianos asked how to switch *into* "suspend" mode, not *out* of it. I don't have access to a KLN94, so I can't answer his question, either. But on my CNX80, the "SUSP" button toggles into and out of the "Suspend" mode. Furthermore, the CNX80/GNS480 does not automatically "suspend" at the MAP. If the aircraft doesn't land, the missed approach continues to sequence. The KLN94 doesn't have a SUSP mode. To prevent it from sequencing beyond the procedure turn holding fix, you must manually switch it from LEG mode to OBS mode, using the OBS button. When approaching the fix, the unit is nice enough to remind you to do this ;-) -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
"Sam Spade" wrote in message news:Tpwmg.34487$AB3.587@fed1read02... Kyprianos Biris wrote: How do you switch it into SUSPEND mode ? Regards I can only speak to the Garmin 400/500 series. SUSPEND is built into the nav database by Garmin for an approach. At a minimum, there is SUSPEND for the missed approach point. It is cleared by hitting the OBS button. Other times SUSPEND occurs: 1. At a course reversal hold, SUSPEND lasts for one circuit in the hold. 2. At a published missed approach hold, SUSPEND lasts indefinately until cancelled. 3. SUSPEND can occur more than once for a missed approach, such as where an altitude has to be achieved before a turn can be made (example KJAC ILS 19) Kyprianos asked how to switch *into* "suspend" mode, not *out* of it. I don't have access to a KLN94, so I can't answer his question, either. But on my CNX80, the "SUSP" button toggles into and out of the "Suspend" mode. The pilot cannot switch a Garmin 400/500 series into suspend. He can only invoke OBS mode, which is similar to, but not identical to, suspend. Furthermore, the CNX80/GNS480 does not automatically "suspend" at the MAP. If the aircraft doesn't land, the missed approach continues to sequence. That sounds dicey if you are using autopilot in NAV mode, and there is a turn required before you might be ready. |
