#11
Jose wrote:
I think one involved an SR-22 (which we had an extensive thread about recenty) that landed on wet grass, skidded, and then attempted a take-off and hit trees. However, it then mentioned that the person had touched down with only 1200' left on a 2700' or so long strip. I'd hardly blame such an accident on the grass. :-) Had it been concrete, would the skid had occured? Would braking action been sufficient to stop in the remaning runway? These are some of the differences that might be attributable to grass. Hard to say. Pilots who land that long are also typically landing pretty hot. Anyone's guess if he'd have gotten stopped on concrete. Certainly, the braking action is better on concrete than even the best grass strip, although I've not found stopping on grass to ever be a problem. If you land where you are supposed to, the additional drag from grass will stop you just fine with no need for braking. Then again, I almost never use the brakes when landing in any event. Only if at a controlled field and the controller asks me to make the first turn-off. The biggest airplane I've flown in the 182 and I could land and stop without brakes in less than 2,000' in calm conditions and much less than that with any significant headwind. I've only landed on one runway where I felt I had to use significant braking (Marlboro, MA) and even then, I probably used a lot more than I needed as I got stopped with a good 500' of runway left. But the visual picture on final at that airport was simply freaky the first time in. I guess I should have taken my CFI along. :-) Matt |
Orval Fairbairn wrote: In article , Hamish Reid wrote: In article , Matt Whiting wrote: Orval Fairbairn wrote: [...] Yesterday I witnessed a Baron pilot land nosewheel first, porpoise a couple of times and eventually get control. Several of us there expected to see the nosewheel fold and the Baron slide down the runway. Talk about poor technique! Your accounts got me to wondering ... how many of you all have actually seen an airplane nose-over on a grass strip? I've been flying since 1978 at two airports that had grass strips (one had only grass until just last year). I've NEVER seen an incident on a grass strip period, let alone one that occurred because of failure to use short-field technique. [...] I've seen a grass strip nose-over -- in fact, it occured at Frazier Lake, the grass strip Orval mentioned early in his post (about the only conveniently-located trustworthy grass strip around here in the Bay Area). Not sure what caused it, but I saw it happen from the air, which was quite a sobering sight, despite the fact that the plane didn't look too damaged from 2000' up. It doesn't appear to have been put into the NTSB database, so I guess it was considered a fairly minor incident. Hamish We used to "X" out the runway during winter (rainy season) at Frazier Lake. This did not stop some boneheads from attempting to use the sod, however. I can remember a number of times that some nonmember left furrows in the runway. I don't recall, however, very many noseovers, however. I always used to wonder if anyone ever landed in the seaplane "ditch" there by mistake... under certain conditions it certainly looked like a runway :-). Hamish |
In article
, Hamish Reid wrote: In article , Orval Fairbairn wrote: We used to "X" out the runway during winter (rainy season) at Frazier Lake. This did not stop some boneheads from attempting to use the sod, however. I can remember a number of times that some nonmember left furrows in the runway. I don't recall, however, very many noseovers, however. I always used to wonder if anyone ever landed in the seaplane "ditch" there by mistake... under certain conditions it certainly looked like a runway :-). When I was there we had a pool going as to when somebody would try that! On a grey day, the seaplane lane looked like a wet concrete runway -- except for the ducks that lived there! |
Matt Whiting wrote:
Dave S wrote: Matt Whiting wrote: Your accounts got me to wondering ... how many of you all have actually seen an airplane nose-over on a grass strip? Matt For what its worth, I am actually in agreement with you.. in that simply being a turf strip does not a soft field make. My first solo flight and quite a few initial flight training hours were done on grass. On a dry, well maintained field, its a non-event.. and more forgiving than a paved strip. Dave |
![]() Dave S wrote: For what its worth, I am actually in agreement with you.. in that simply being a turf strip does not a soft field make. My first solo flight and quite a few initial flight training hours were done on grass. On a dry, well maintained field, its a non-event.. and more forgiving than a paved strip. Dave The local climate and soil conditions, as well as the age of the established sod, has much to do with the firmness of a grass strip. Poor drainage and really tight clay soils can be soft most of the time unless it's dry country. Every grass strip is different. We use a number of them for training, and we know what to expect at various times of the year. Springtime, with frost coming out of the ground, is a good time to leave them alone. I think more accidents involve taking off from a grass strip by pilots who are used to pavement. The takeoff roll can be MUCH longer due to drag of the grass (depending on height, density, type and moisture content of the grass) and the softness of the soil, and the airplane is often slid off the end of the runway when the abort comes too late, or staggers into the air and crashes moments later. Dan |
Dylan Smith wrote:
A firm grass runway for a tailwheel plane is much safer than paved - it's a lot more forgiving of slight crab angles on touchdown. And the drag of the grass helps *a lot* to keep the tail where it belongs. Stefan |
![]() "Matt Whiting" wrote in message ... Orval Fairbairn wrote: Your accounts got me to wondering ... how many of you all have actually seen an airplane nose-over on a grass strip? I've been flying since 1978 at two airports that had grass strips (one had only grass until just last year). I've NEVER seen an incident on a grass strip period, let alone one that occurred because of failure to use short-field technique. I haven't tried to search the NTSB archives yet. I'm sure they have some accounts, but it certainly isn't the type of crash that I've either heard or read about with any frequency. Matt I'm with you. I saw one taxi into a drainage ditch - threatened to sue, but it was a private strip and he did not have permission to land (years ago, nowdays it would be feasible). One overshot the field and nosed over when he hit the cattle fence at the end. Saw another nimrod taxi into a hanger, but that had nothing to do with the grass. |
Todd
I agree with you. I flew PT-19's, AT-6's, P-40's. P-51's, 150's 180's and a few other tail wheel birds (Cub's, Air Knocker's, Luscombe's,Rearwin JR, etc.). Three pointed ALL OF THEM on grass and hard surface with no problems. Have seen a number of so called experts wheel a bird in and loose it. Big John `````````````````````````````````````````````````` ```````````` On 19 Jun 2006 08:59:01 -0500, T o d d P a t t i s t wrote: Matt Whiting wrote: Your accounts got me to wondering ... how many of you all have actually seen an airplane nose-over on a grass strip? I've seen this. The field was definitely soft - extremely soft. A week of spring thaw and rain during the week leaving mud under the grass, then an overnight freeze producing a hard crust allowing morning takeoffs on the weekend. Thawing during the day left a weak crust, plane noses over as wheels sink through into the muck. Fire trucks ran out and sank through too. This was not a failure to use soft field technique. Nothing would have prevented this other than using the hard runway or landing a couple hours earlier. I've got more landings on grass than hard surface - mostly tailwheel. I don't wheel land on grass, (I seldom wheel land on hard either) and certainly would not do it on a grass runway I don't know well. I use soft field technique if it's soft. I don't stop the taxi if the grass is getting long, or at the edge of a bump to the hard surface, but a normal grass runway needs no special technique. |
"birdog" wrote: I'm with you. I saw one taxi into a drainage ditch - threatened to sue, but it was a private strip and he did not have permission to land (years ago, nowdays it would be feasible). One overshot the field and nosed over when he hit the cattle fence at the end. Saw another nimrod taxi into a hanger, but that had nothing to do with the grass. If it is on the Sectional and has an R in a circle, one had better have permission. If it is not on the Sectional, again, you had better have permission. |
T o d d P a t t i s t wrote: john smith wrote: If it is on the Sectional and has an R in a circle, one had better have permission. If it is not on the Sectional, again, you had better have permission. I've landed at lots of those "R in a circle" airports, never with permission (unless it was the second time), and always got a nice reception. Of course, I always landed without an engine, and only because it was land there or land in a farmer's field. There are examples in US case law where aircraft owners who have landed at private airfields without permission have had to pay large sums of money to the property owner to recover their aircraft, disassemble it and truck it out. |
Ejection -v- Forced Landing | Cockpit Colin | Naval Aviation | 27 | April 2nd 05 11:47 PM |
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
Airliner landing technique | Matt Whiting | Instrument Flight Rules | 22 | January 10th 05 02:26 PM |
Slip to landing on PPG practical test | Roger Worden | Soaring | 56 | November 11th 04 09:38 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
