Cruise clearance
Old May 19th 04, 11:36 PM
Steven P. McNicoll
"Hankal" wrote in message
Would have to request 7000. Flying 090.
Since I am only 40 miles from the destination I just do not want to
climb another 2000 feet.
ATC can assign altitudes that are wrong for direction of flight.
Old May 19th 04, 11:41 PM
Steven P. McNicoll
Another option in your case would have been VFR on top at 5500?
I guess that doesn't quite meet the cloud clearance, though.
No, it doesn't. If the cloud layers are 4000 to 5200 and he's heading east,
he'd have to climb to 7500 to operate VFR-on-top.
Old May 19th 04, 11:45 PM
Steven P. McNicoll
"Stan Gosnell" me@work wrote in message
A cruise clearance won't let you do this. What you want is a
VFR-on-top clearance.
If the clouds are 4000 to 5200 and he's eastbound VFR-on-top would require
him to climb to 7500. If he just wants to get above the clouds a block
altitude of 5000 to 6000 would do the trick.
Old May 20th 04, 12:01 AM
Bill Gamelson
This is true. The "East is least and West is best" only applies to VFR
flight. A good example is when I was flying East at 6000 and ATC instructed
me to climb to 7000. I was IFR at the time. I started picking up ice at
7000 and requested "lower". ATC then cleared me back down to 6000, not 5000
which they could have.
Old May 20th 04, 02:08 AM
Andrew Sarangan
"Bill Gamelson" wrote in
om:
VFR flight. A good example is when I was flying East at 6000 and ATC
instructed me to climb to 7000. I was IFR at the time. I started
picking up ice at 7000 and requested "lower". ATC then cleared me
back down to 6000, not 5000 which they could have.
The hemispheric rule applies to IFR also, but only in uncontrolled airspace
(class G).
Old May 20th 04, 04:55 AM
Teacherjh
A cruise clearance does not allow you to climb above your present altitude.
If you want a higher altitude, ask for a higher altitude.
No? What about I'm assigned 5000, and I'm level at 5000. I request a "cruise
7000" and am granted that request. ("347FB cruise seven thousand").
1: is this an improper request? (never mind whether it will accomplish what
anybody thinks I want to accomplish)
2: Is it improper to give me "347FB cruise seven thousand" when I'm level at
5000?
3: If the answer to the above are "no", then how do I get to 7000 without
climbing? (and without drugs)
Jose
Old May 20th 04, 04:05 PM
Peter R.
om:
(class G).
While perhaps your comment may be technically true, it's been my experience
flying IFR in the Northeast US that ATC very much wants IFR aircraft filing
altitudes that conform to the hemispheric rule.
If I tried to file a nonconforming altitude for the direction of flight
(which has occasionally happened by mistake), the CD controller always
corrected this oversight upon delivering my clearance.
Peter
Old May 20th 04, 05:06 PM
Steven P. McNicoll
"Teacherjh" wrote in message
No?
No.
a "cruise 7000" and am granted that request. ("347FB cruise
seven thousand").
Why would you request a descent and approach clearance if all you wanted was
to climb from 5000 to 7000? If you want a higher altitude, ask for a higher
altitude.
accomplish what anybody thinks I want to accomplish)
Yes.
I'm level at 5000?
Yes.
7000 without climbing? (and without drugs)
Regardless of the answer to the above, you cannot get to 7000 from 5000
without climbing. If you want to get from 5000 to 7000 then request 7000,
don't request a descent and approach clearance.
I advise you to get off the drugs.
Old May 20th 04, 05:28 PM
Steven P. McNicoll
"Peter R." wrote in message
my experience flying IFR in the Northeast US that ATC very
much wants IFR aircraft filing altitudes that conform to the
hemispheric rule.
controller always corrected this oversight upon delivering my
clearance.
FAR 91.179(b) requires IFR aircraft in Class G airspace to conform to the
hemispheric rule, there's no relief from that. FAR 91.179(a) requires IFR
aircraft in controlled airspace to maintain the altitude assigned by ATC, no
mention of any hemispheric rule in the regulation. But FAA Order 7110.65
requires controllers to issue altitudes consistent with the hemispheric
rule, unless one of many exceptions applies.
If you're requesting an altitude that isn't very popular, you'll probably
get it. If you're requesting an altitude that many aircraft going the
proper direction like to use, you probably won't. In a nutshell, aircraft
going the right way have dibs on altitude.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
