For the past 6 years I've been using an SN10, backed up with a (no
flask) Westerboer electric (with audio), running on two seperate battery systems, either of which can run some or all of the panel. No mechanical - traded in the Winter the glider came with for the Westerboer. Both varios match perfectly, which makes sense since they are plumbed to the same TE probe. The only improvement I would like would be to have one vario use electronic TE (selectable, ideally) and the other the probe, for redundancy in case the probe failed (yes that has happened to me, with both an earlier glider/probe combo and in the TE plumbing in the current glider). Personally, I would prefer to have big digital airspeed, altitude, and angle of attack displays (with some form of analog trend information) in place of the sticky and slow mechanical airspeed indicator and altimeter. Without electrics, I'm going to land anyway, so I design my electrics accordingly. And I know (from experience) that I can fly 500k+ without a working airspeed indicator. I also care more about GPS elevation and height above ground than what the pneumatic altimeter is lying about. Caveat - I wouldn't even think about setting up a 1-26 or a primary trainer this way! This is for serious XC and racing fanatics....be sure not to tell the spousal unit of the cost involved! 66 |
![]() My major concern was that of secondary battery failure due to low temps. It's not like we even get the opportunity to reach such heights where I fly, but, should the opportunity arise to explore some wave, i'd hate to see the little 9V backup battery on the ILEC, decide to have a rest when it was needed most. Does anyone have any clues on the behaviour of lithium batts at lo temps? Fish |
Fish wrote:
My major concern was that of secondary battery failure due to low temps. It's not like we even get the opportunity to reach such heights where I fly, but, should the opportunity arise to explore some wave, i'd hate to see the little 9V backup battery on the ILEC, decide to have a rest when it was needed most. Does anyone have any clues on the behaviour of lithium batts at lo temps? Yes, they show significantly less degradation at cold temperatures than alkaline cells or lead acid batteries. They are used in the Perlan project for precisely this reason... Marc |
Kirk makes an excellent point. There's a lot written about dual
batteries, backup electrical systems, mechanical vs. electronic varios, etc. But the common point of failure for most of us is the TE probe. In my last glider, I had completely independent varios...though both were electric. One used a tail-mounted TE probe and a homemade netto device connected to front statics. The other was driven by a Schuemann TE/netto compensator connected to rear pitot and statics. Nothing short of a lightning strike or water landing was going to take out my panel. ![]() In my current glider, I've got a Winter mechanical backup vario but it's driven by the same tail-mounted TE source as is the LNAV electronic device. I've never done an analysis or survey but I suspect losing the TE signal is not much less likely than losing a battery. Yet this is the first mention I can recall on RAS of this subject. Anyone know of a [relatively] inexpensive vario with electronic TE compensation? I read an article some time ago (Dick Johnson?) about how mounting a TE probe on the fuselage works better and is not nearly as draggy as we once thought. Chip Bearden' ASW 24 "JB" |
I like to use the 302 set up on electronic compensation and the winter or
backup electric on TE probe- no talking between the varios - IM wrote in message oups.com... Kirk makes an excellent point. There's a lot written about dual batteries, backup electrical systems, mechanical vs. electronic varios, etc. But the common point of failure for most of us is the TE probe. In my last glider, I had completely independent varios...though both were electric. One used a tail-mounted TE probe and a homemade netto device connected to front statics. The other was driven by a Schuemann TE/netto compensator connected to rear pitot and statics. Nothing short of a lightning strike or water landing was going to take out my panel. ![]() In my current glider, I've got a Winter mechanical backup vario but it's driven by the same tail-mounted TE source as is the LNAV electronic device. I've never done an analysis or survey but I suspect losing the TE signal is not much less likely than losing a battery. Yet this is the first mention I can recall on RAS of this subject. Anyone know of a [relatively] inexpensive vario with electronic TE compensation? I read an article some time ago (Dick Johnson?) about how mounting a TE probe on the fuselage works better and is not nearly as draggy as we once thought. Chip Bearden' ASW 24 "JB" |
At 22:18 27 June 2006, Fish wrote:
My major concern was that of secondary battery failure due to low temps. It's not like we even get the opportunity to reach such heights where I fly, but, should the opportunity arise to explore some wave, i'd hate to see the little 9V backup battery on the ILEC, decide to have a rest when it was needed most. That is a real problem. I lost my diamond height claim because the new 9v battery in my EW barograph packed in at 16000 ft, because of the cold. When we tested it on the ground after the flight it returned to giving 8.6 volts. A shame I did not fit the clockwork one we had. Does anyone have any clues on the behaviour of lithium batts at lo temps? Fish |
Help finding a Cambridge Vario manual/info | keelstrake | Soaring | 2 | May 18th 06 03:43 AM |
Winter mechanical vario reading high | Alan Meyer | Soaring | 13 | April 13th 06 02:38 AM |
Winter Vario | [email protected] | Soaring | 2 | August 17th 05 08:24 AM |
My first in-flight mechanical failure | Peter R. | Piloting | 52 | October 5th 04 09:05 PM |
Vario time constants | Bill Daniels | Soaring | 3 | January 20th 04 03:18 PM |
