Jeez, this is so intense?
Old June 30th 06, 03:04 PM posted to rec.aviation.piloting
Default Jeez, this is so intense?
Ramapriya wrote:
1.In westward moving depression the area of heavier ppt is generally
a.SE
b.SW
c.NE
d.NW sector of Depression
Probably SW???
2. If static air temp is -15^C&indicated altitude is 1000feet then true
altitude will be
a.10400ft
b.10600ft
c.9400ft
d.9600ft
10 degrees colder than standard equals 4% lower.....9600'
3.Presence of hard pellets on surface is evidence of
a.thunderstorm in area
b.has been a cold frontal passage
c.temp inversion with freezing rain at higher altitude
Answer "C"...Straight from the Jeppesen Private Pilot Manual 6-27
4.due to friction wind very close to ground
a.only increases in magnitude with height
b.Decreases in magnitude with height
c.backs with height
d.veers with height
Answer "D"...."only" makes A wrong....B Increases with height.....C
backs means to weaken
5.what is the process of adding unsat air to moisture?
Evaporation?????
6. If lightening flash is seen &thunder is not heard
a.cloud is not fully developed
b.CB is dissipating
c.thunder didnt occur at that time of lightening
d.CB is very distant
D is the obvious answer
7. An aircraft must have anti collision lights fitted when
a.carrying passengers
b.flying IFR
c.Whn flying IMC
d.With AUW more than 5700 kg
Don't know what the rule is in India, here it is "at all times,
unless....."
8. An a/c is flying at FL290& oat -30 c.the temp condition is ...
Higher than standard
9. In convective clouds severe icing may be encountered at temp...
Between 0 and -10 degrees C
10. A turn coordinator provides an indication of...
Direction of turn, Rate of roll and Rate of turn
11. When an a/c climbs at constant TAS,RAS shd be
a.Increased
b.maintained
c.decreased
Probably should have been "IAS" and should be decreased
12.parts of country affected by norwesters is
a.bengal& bihar in pre monsoon
b. NW india in winter
c. South india in summer
d. NE india in winter
Don't know...never been to India.
13.TMG is 045,G/S 135,Co(C)045,dev 2W,var 8W,TAS 140kt,wind vel is
a.13025
b.140/22
c.320/24
"A" using my "wizz wheel" :-)
Old June 30th 06, 03:33 PM posted to rec.aviation.piloting
On 2006-06-30, Peter Duniho wrote:
"Backs"? "Veers"? What are those words supposed to mean in this context?
Backing and veering within the context of wind means the direction (on
the compass) the wind direction is changing. If, as you climb, the wind
goes from being 010 degrees to 030 degrees, the wind is veering (a
clockwise change on the compass face is veering). If it goes from 010 to
350 as you climb, then it's backing (the direction is changing in a
counterclockwise direction). It's easy to remember which way round it
should be since backing is a counterclockwise change.
'Backing' and 'veering' are terms not used in the United States (well,
I've never heard them used in the United States). They are generally
commonly used in Britain and some Commonwealth countries (such as India).
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old June 30th 06, 04:16 PM posted to rec.aviation.piloting
Don Tuite wrote:
When answering, remember that India is in the southern hemisphere.
Not unless there's been a major earthquake I didn't hear about.
Regardless, Veer is a windshift to starboard,, Head is a shift to
port. Nautical terms.
Don
Old June 30th 06, 04:43 PM posted to rec.aviation.piloting
Peter Duniho wrote:
"Don Tuite" wrote in message
Ah. I was worried it might be like the "hook" and "slice" from golf, where
they are just using arbitrary words to mean "left" and "right".
Still, what would "back" be?
No idea, but in golf hook and slice are, respectively, left and right
for right-handed players. They would be the opposite for left-handed
players.
Old June 30th 06, 04:48 PM posted to rec.aviation.piloting
"Peter Duniho" wrote in message
If anyone of you can find the time and/or inclination to help with the
Qs themselves, I acknowledge thanks gratefully. Ignore Q12 of course
What a bizarre collection of questions. And poorly worded too. Surely
this isn't a literal transcription from the actual written exam?
And yes, there's a lot to learn before one is granted a pilot certificate.
snip
Bank angle and roll rate.
Rate of turn only. Cross control, and you have bank & roll rate with no
turn.
Al G
Old June 30th 06, 05:08 PM posted to rec.aviation.piloting
Jose[_1_]
turn.
No, the "needle" of "needle and ball" provides rate of turn only. The
turn coordinator provides an initial indication of rate of roll. That's
the difference between the two instruments.
Jose
The monkey turns the crank and thinks he's making the music.
Old June 30th 06, 09:45 PM posted to rec.aviation.piloting
Peter Duniho
"Al" wrote in message
turn.
It's not clear what you're correcting. You are right that I should have
written "turn rate" instead of "bank angle". It was kind of late. But you
do also get roll rate from the turn coordinator. It's not "rate of turn
only".
Pete
Old July 1st 06, 03:50 AM posted to rec.aviation.piloting
Peter Duniho wrote:
Though, now that I consider it, I suppose that only the people who become
well-educated *in spite of* the existing standard of education are likely to
emigrate to the US to be met by me.
This is actually true. From what I've reliably heard, the best of our
lot can be found in the US, with the UK and Aus/NZ in that order.
Most of the dross are in Dubai and thereabouts )
Ramapriya
AIRCRAFT MUNITIONS - THE COBALT BOMB Garrison Hilliard Military Aviation 1 August 29th 03 09:22 AM
