Garmin GpsMap 396 - Flight Test
Old July 4th 06, 04:17 AM posted to rec.aviation.owning
Jonathan Goodish
Default Garmin GpsMap 396 - Flight Test
In article
john smith wrote:
You know, with the reception problems I am reading about here, I think I
will stick with my GPS 195 a while longer. I always get a lock with a
minimum of six to eight sats.
I don't have reception problems, and am puzzled as to why some users are
experiencing them. I am using the GA26 remote antenna, but this is
supposedly a "low power" antenna, so I'm not sure if that is a factor or
not (Garmin uses active antennas.) I have an unused GA56 on top of the
airplane, and that does seem to result in stronger signals, but part of
that could be the more ideal placement, with an unobstructed view of the
sky.
JKG
Old July 4th 06, 12:27 PM posted to rec.aviation.owning
Dan Luke
I don't have reception problems...
Nor I. I get the same reception performance--or better--with the 396 as I
have with all my previous Garmins.
I do remember that my 195 had trouble locking if activated while in motion.
The 396 is not bothered.
Dan
C172RG at BFM
Old July 4th 06, 01:26 PM posted to rec.aviation.owning
Mike Spera
Funny you should mention this. My 396 GPS reception has been flaky
lately too.
I went out again and tried a few things. I noticed on both days that I
would get 8-10 sats pinned at the top while stationary. Once I started
rolling, most would come down a bit and jump up and down some. After
rotation and climbing, all sats were lost and the thing lost its lock. I
landed and tried again. Same result. O.K. So I cannot depend on it
during a climb?
Next, I tried moving the antenna around and switching to the stub. It
seemed a little better placing the antenna on the right side of the
glareshield opposite the XM. Turning in some directions made for better
or worse reception. However, WAAS was lost going some ways and regained
randomly along that path or by turning. This seems flaky.
Then I tried something I never really tried with my other GPS units. I
watched the sat page while transmitting. All sat bars marched down to
the bottom and disappeared in about 5-7 seconds. Release the transmit
button and they immediately came back up to where they were. So, now I
cannot trust this thing while transmitting?
I will bring along my Lowrance Airmap 1000 and monitor the sat page
during the various aspects of flight and compare it to the Garmin.
Perhaps the Lowrance is just as weak and I did not notice (because it
never lost a lock so I had no reason to look). For laughs, I may also
bring along one of my several Apollo 920 units and watch its
performance. The Apollo never lost its lock in 7 years of use.
Old July 4th 06, 02:57 PM posted to rec.aviation.owning
Dan Luke
watched the sat page while transmitting. All sat bars marched down to the
bottom and disappeared in about 5-7 seconds. Release the transmit button
and they immediately came back up to where they were. So, now I cannot
It could still be you have a faulty 396, but it sounds like it's you have a
radio/electrical problem. I had a Cessna NAV/COM that did the same thing to
my old 295. Swapping the radio with another one solved the problem. You may
also have a leaky antenna cable shield.
Is that the only COM radio you have? What happens when you power it off and
use another transmitter? If the same thing happens, you may have a
grounding problem in the airplane.
Trying the other portable GPS is a good test. If you're lucky, the Lowrance
will work ok and prove you have a bad Garmin. If not, I still recommend
that you turn off EVERYTHING electrical in the airplane and see how the 396
receives satellites. Then, add stuff back in one at a time until you
observe any loss of signal.
Good luck with your gremlin.
Dan
C172RG at BFM
Old July 4th 06, 03:56 PM posted to rec.aviation.owning
Jonathan Goodish
In article t,
COM will interfere with GPS signal. Try relocating the antenna, or
re-routing the antenna cable. You could probably temporarily suction
the antenna to a rear window, or do some tests on the ground with the
antenna on top of the cabin.
JKG
Old July 4th 06, 03:57 PM posted to rec.aviation.owning
Jonathan Goodish
In Mike's case, it sounds like an interference issue to me.
JKG
Old July 4th 06, 05:20 PM posted to rec.aviation.owning
Denny
Very possible... He needs to get out of the airport area and turn off
thenav/com radios and the transponder and see what happens... If that
is no good, then turn off the master switch and the alternator... If
still no good, then it is the 396...
denny
Old July 4th 06, 05:44 PM posted to rec.aviation.owning
Mike Spera
Actually, I did try a few tests. When switching to my second com and
transmitting, it did the same thing. Down to zero on every sat.
Relocating the GPS antenna to the back seats near the window or anywhere
else made no difference when transmitting. It did seem a little better
for reception on the right side of the glareshield (opposite side from
the XM antenna). Turning off all the radios and the complete electrical
system had no effect. I still had flaky reception.
Once I have my other GPS units side by side with this one, I should be
able to isolate whether it is a plane/radio or specific GPS problem.
Thanks to all for suggestions,
denny
Old July 4th 06, 05:52 PM posted to rec.aviation.owning
Dan Luke
"Mike Spera" wrote:
Turning off all the radios and the complete electrical system had no
Now it really sounds like you have a bad 396.
That will be interesting.
Dan
C172RG at BFM
Old July 4th 06, 06:34 PM posted to rec.aviation.owning
Mike Spera wrote:
30 seconds after take off, lost
the GPS sat lock. Took about 15 seconds to regain it. In the next 5
minutes, it lost lock several more times. I'm thinking, external antenna
is loopy.
Mike,
For what its worth...
I just flew my Arrow around the country and experienced the same
problem (with my brand spank'n new 396) that you described. Most of the
occurrences were in the takeoff or landing phase of the flight. I had
my old Lowrance airmap 100 on the copilot yoke and it never lost lock
once during the flight. The 396 was connected to the remote antenna
which was sitting on the glare shield, the airmap 100 was using it's
built in antenna.
-Bernie
My fly-about http://www.iperformax.com/flyabout/flyabout.html
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
