With the summer thermals upon us, and not being able to scratch my nose
without having my small homebuilt tossed off course got me to thinking about how to build a low cost wing leveller. A small servo tab mounted out on the aileron, controlled by a jumbo sized R/C servo would probably work fine. If the tab was sized fairly small, even if the servo went nuts, the pilot could easily overpower it. The servo would be controlled by a rate gyro that is also used in model airplanes and helicopters to provide the stabilizing function. The overall system would be controlled by a simple pulse-width modulator using a 555 chip. A small amount of trim adjustment would be provided. Operation would be simple: turn on the system and adjust the pulse width trim knob to get the wings level. Sit back and scratch your nose, take a pee, eat a sandwich. This simple system could be put together for under $300. Any thoughts on how it might work? tom |
| Thread Tools | |
| Display Modes | |
| The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 02:15 AM |
| A New Air Traffic Control System On The Horizon | Larry Dighera | Piloting | 0 | June 17th 05 04:03 PM |
| Air Force Helper 2000 | tomcat | Naval Aviation | 0 | June 10th 04 12:54 AM |
| Canard planes swept wing outer VG's? | Paul Lee | Home Built | 8 | January 4th 04 09:10 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
