#11
cavelamb wrote: wrote: WIth pencils, the issue is the graphite. There is a similar problem if steel wool is used on aluminum. A lot of sandpapers use Aluminum Oxide (Alundum) grit. That is the same oxide that forms naturally on aluminum so that should not be a problem. But most of the wet/dry papers use silicon carbide, (carborundum) which may be a problem. You don't sandpaper the edges - you file them... The trick to good looking parts is finishing the edges. Are they smooth, flat, free of nicks and scratches? Sandpaper alone won't do that... I agree that file would be better. Consider 'draw filing', which is done by holding the file like drawknife which reduces the angle of attack of the teeth and produces a finer finish. Do you load a file with soap or something to keep soft metals like aluminum from sticking in the teeth? Sandpaper on a rigid sanding block would work too. I personally _hate_ sanding so would much rather use files, scrapers, stones, or burnishing tools. Would you ever use sandpaper to prepare Aluminum for epoxy, or rely entirely on chemical pre-treatment? -- FF |
metals like aluminum from sticking in the teeth? You could, but unless you want to work yorself to death, get a vixen file, 10 or 12 inches long. Aluminum won't clog a vixen, and it removes material quickly. Dan |
In article .com,
"Dan Horton" wrote: You could, but unless you want to work yorself to death, get a vixen Whoa! Just a quick glance at that first line will get ones attention! I go to read the next line... 10 or 12 inches long. Makes ones heart bounce again. Then I start to wonder if I missed a Hangar Queen thread? Please think about carefully wording your sentences to reduce the risk of heart attack to the speed readers. |
Peter Dohm wrote:
To deburr use a deburring tool which will take the sharp edge off the inside of the tubing and the edges of sheet, finish with scotchbrite pads. Use the 6061-T6. Bob There is also a rotary version of the scotchbrite pad(s) that is really slick. Peter And of what use is slick sandpaper, my good man 8*) -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
john smith wrote:
Makes ones heart bounce again. Then I start to wonder if I missed a Hangar Queen thread? Please think about carefully wording your sentences to reduce the risk of heart attack to the speed readers. I dunno, a hanger queen sounds like something to be avoided. ;o) Tony |
Ernest Christley wrote:
Peter Dohm wrote: To deburr use a deburring tool which will take the sharp edge off the inside of the tubing and the edges of sheet, finish with scotchbrite pads. Use the 6061-T6. Bob There is also a rotary version of the scotchbrite pad(s) that is really slick. Peter And of what use is slick sandpaper, my good man 8*) Polishing! |
"cavelamb" wrote in message ink.net... Ernest Christley wrote: Peter Dohm wrote: To deburr use a deburring tool which will take the sharp edge off the inside of the tubing and the edges of sheet, finish with scotchbrite pads. Use the 6061-T6. Bob There is also a rotary version of the scotchbrite pad(s) that is really slick. Peter And of what use is slick sandpaper, my good man 8*) Polishing! A better answer that I had when I got back to the computer. Scotchbrite will definitely polish aluminum. |
"Peter Dohm" wrote in message ... "cavelamb" wrote in message ink.net... Ernest Christley wrote: Peter Dohm wrote: To deburr use a deburring tool which will take the sharp edge off the inside of the tubing and the edges of sheet, finish with scotchbrite pads. Use the 6061-T6. Bob There is also a rotary version of the scotchbrite pad(s) that is really slick. Peter And of what use is slick sandpaper, my good man 8*) Polishing! A better answer that I had when I got back to the computer. Scotchbrite will definitely polish aluminum. Grrr! I used to have a little 4 line poem with 12 errors, and a spelling checker wouldn't catch any of them! I was trying to say that Rchard gave a better answer THAN mine. Peter |
Peter Dohm wrote:
"Peter Dohm" wrote in message ... "cavelamb" wrote in message hlink.net... Ernest Christley wrote: Peter Dohm wrote: To deburr use a deburring tool which will take the sharp edge off the inside of the tubing and the edges of sheet, finish with scotchbrite pads. Use the 6061-T6. Bob There is also a rotary version of the scotchbrite pad(s) that is really slick. Peter And of what use is slick sandpaper, my good man 8*) Polishing! A better answer that I had when I got back to the computer. Scotchbrite will definitely polish aluminum. Grrr! I used to have a little 4 line poem with 12 errors, and a spelling checker wouldn't catch any of them! I was trying to say that Rchard gave a better answer THAN mine. Peter S'ok Peter. |
| Thread Tools | |
| Display Modes | |
| Question about Alodine 1201 | Andrew Sarangan | Home Built | 20 | April 11th 06 02:31 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| FA: Book - Aircraft Materials and Processes by Titterton Pub 1937 | Brad | Aviation Marketplace | 0 | November 21st 05 02:59 AM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
