#11
![]() Were you really "talking" to these stations? The 108-136 MHz band(s) is(are) for /air/ mobile operations. Talking to LA Center while driving on I5 would seem to be illegal. What if you're jumping up and down, and only transmit when you're in the air? Jose -- (for Email, make the obvious changes in my address) |
Where are located when you are using this radio. I am 7 miles from the
airport and I can hear aircraft in the pattern, but cannot hear the tower or ATIS. The problem is these frequencies are line of sight. If you have buildings and such in between the antenna and the source, the reception will be poor regardless of antenna. jerry "CHANGE USERNAME TO westes" wrote in message ... I recently purchased an ICOM IC-A23 radio, and I'm disappointed in its pickup. It gets the weather channels fine, but the reception for both the airport and airplane radios is poor. Aside from standing next to the airport or being right under the airplane, do I have any options for improving gain and the quality of reception? Is there some third party antenna that I could attach to this radio? It looks like it takes a standard BNC type connector for the antenna that comes with it. -- Will westes AT earthbroadcast.com |
How tall was that telescoping antenna?
Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? -- Will westes AT earthbroadcast.com "EDR" wrote in message ... In article , CHANGE USERNAME TO westes wrote: If you are on the ground, outside the airplane, you can purchase a metal, 5/8 wave, telescoping antenna to replace the standard rubber duckie. |
westes wrote: How tall was that telescoping antenna? I do not remember how long it extends to. IIRC, the formula is 468/f(MHz) gives the wavelength. Multiply by 5/8 to get the antenna length in feet. For 123.0 MHz (middle of the band), the length is 28.5 inches. Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? Just purchase a standard ham 2m mag mount antenna and cut a piece of stainless steel rod that fits the mag mount to the above calculated length. |
I disagree with the method described below for calculating a 5/8 wavelenth antenna.
As I recall, the formula you have below gives you the length in feet of a half wave length antenna (not the full wavelength as you suggest). So a 5/8 ths wave antenna would be twice as long as you calculated. Also, if you took a 2 meter 5/8's wave antenna, you'd need to lengthen it (not cut it down) to use it as a 5/8 wave antenna on 123 MHz. You probably could take a 5/8 wave 2 meter ham antenna and cut it down to a 1/4 wavelength antenna for use on 123 MHz. The length for that would be somewhere around 22.89 inches. Max T, CFI (and ham radio operator) EDR wrote in message ... In article , CHANGE USERNAME TO westes wrote: How tall was that telescoping antenna? I do not remember how long it extends to. IIRC, the formula is 468/f(MHz) gives the wavelength. Multiply by 5/8 to get the antenna length in feet. For 123.0 MHz (middle of the band), the length is 28.5 inches. Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? Just purchase a standard ham 2m mag mount antenna and cut a piece of stainless steel rod that fits the mag mount to the above calculated length. |
![]() You probably could take a 5/8 wave 2 meter ham antenna and cut it down to a 1/4 wavelength antenna for use on 123 MHz. There's more to it than that. The impedance has to match. For a 1/4 wave antenna, all you need is 1/4 wave worth of metal. But for a 5/8 wave, you need a coil at the bottom too, so that the antenna looks like 1/4 wave to the transmitter, and works like a 5/8 wave to the ether. A ham band (or any other band) 5/8 wave antenna will already have the appropriate coil, but if you change the length significantly, the coil will no longer be the right value. For 123 MHz the difference is probably not all that much, but it might be enough, depending on your transmitter. Jose -- (for Email, make the obvious changes in my address) |
![]() CHANGE USERNAME TO westes wrote: How tall was that telescoping antenna? Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? Whatever 5/8 of an RF wavelength of 128.0 MHz is; somewhere around 3 1/2 feet, or so. No one sells them off the shelf, because they can cut one for you in about two minutes. Any decend ham radio store has all the stuff. |
![]() "Max T, CFI" wrote: I disagree with the method described below for calculating a 5/8 wavelenth antenna. As I recall, the formula you have below gives you the length in feet of a half wave length antenna (not the full wavelength as you suggest). So a 5/8 ths wave antenna would be twice as long as you calculated. Also, if you took a 2 meter 5/8's wave antenna, you'd need to lengthen it (not cut it down) to use it as a 5/8 wave antenna on 123 MHz. You probably could take a 5/8 wave 2 meter ham antenna and cut it down to a 1/4 wavelength antenna for use on 123 MHz. The length for that would be somewhere around 22.89 inches. Max T, CFI (and ham radio operator) EDR wrote in message ... In article , CHANGE USERNAME TO westes wrote: How tall was that telescoping antenna? I do not remember how long it extends to. IIRC, the formula is 468/f(MHz) gives the wavelength. Multiply by 5/8 to get the antenna length in feet. For 123.0 MHz (middle of the band), the length is 28.5 inches. Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? Just purchase a standard ham 2m mag mount antenna and cut a piece of stainless steel rod that fits the mag mount to the above calculated length. I had mine cut for 128.0 MHz to optimize the VHF voice band. The nav frequencies are less important. Ham Radio Specialists in San Diego cut it, and had stock to do 5/8 wave length at that frequency. The whip is much longer than 28.5 inches; somewhere around 40 inches, or so. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Barnyard BOb - | Home Built | 5 | September 8th 04 07:27 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 04:02 PM |
Marine Radio using Aviation Antennae | Jim Weir | Home Built | 13 | August 12th 03 10:05 PM |
