#11
Last year my wife and I replaced the vinyl trim on my Cobra trailer. It took some muscle to pull the strips through. First, we soaked the trim in a bucket filled with warm water and dishwashing liquid to add some slick. The warm water made the vinyl more pliable. When we started pulling, the first ten feet went easily. Then, the lubrication wore off. We started over with Pam spray. That worked well. To pull the vinyl, I used locking pliers. As I pulled, the wife sprayed. When the pulling was done, all that was needed was to pop-rivet the vinyl ends to the trailer. Then, our arms were tired. Raul Boerner |
I installed Maxxima LED replacement brake/turn/tail lights as well as a
high, fin mounted 3rd brake light on my Cobra. For the fin, it is important to fabricate a wedge of some sort (I used white plastic) to get the LED perpendicular to the ground, as the beam angle is narrower than with incandescent lighting. For the 3rd brake light "logic", I used a relay, with the coil being driven off one brake/turn and the NO contact on the relay being driven by the other brake turn. That way the fin brake light is only on when both L & R brake lights are on. I used all flush mount lights with rubber grommets. Also mounted LED aux turn signals on the side of the trailer on the upper clam just above the existing running lights, amber mid-ship and red at the rear. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." "chipsoars" wrote in message oups.com... Anyone know where I can get the weatherstripping seal on the bottom half of the trailer. This is what the clamshell closes against. Also, has anyone replace lights with LED's and mounted a high center stop light? What bulbs are in the tail lens? Chip F. |
I used a different technique.
I simply aligned the trim and used my thumbs to press it on. Worked well once I got the hang of it. Took maybe 1+- hr per side by myself. You might want to email Agnes Spindelberger to get advice. Ira |
| Thread Tools | |
| Display Modes | |
| Help - Cobra Trailer Trim? | WDM | Soaring | 2 | January 12th 05 08:47 PM |
| Cobra Trailer Hookup | [email protected] | Soaring | 12 | January 12th 05 04:08 PM |
| COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 05:38 PM |
| Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 03:06 PM |
| Cobra trailer fittings for different glider makes & models | John W | Soaring | 4 | September 24th 03 04:21 PM |
