most of eastern Massachussetts airspace closed in July
Old June 17th 04, 04:38 PM
OtisWinslow
"William W. Plummer" wrote in message
news:0VgAc.68849$Sw.11654@attbi_s51...
The terrorist have been successful --
Yeh. Successful because of crappy security at WHICH airport?
Old June 17th 04, 06:04 PM
Jack Cunniff
(Christopher C. Stacy) writes:
The Democratic National Convention is coming to Boston in July.
The Boston Globe today reported that the FAA is going to restrict
all air traffic within 30 nm of Boston: no private aircraft will
be allowed to operate in the airspace. The main thrust of the
story was that this restriction included all the helicopters
used by the traffic reporting services and television news.
Way too much hand-wringing about this. It's not going to be a 30-mile TFR,
it's a 10-mile one with procedures out to 30 miles.
Logan will be closed to all but commercial traffic, yes. No GA, no
"charters". I believe that certain charters (such as travel wholesalers
who charter entire jets for scheduled service) will still operate.
The IMPORTANT INFO that seemed to be missing from other postings, and from
the Globe story was this link from the FAA, talking about how GA IFR
flights were going to operate from airports within the 30-mile ring.
http://www.faa.gov/NTAP/NTAP04JUN10/SP04023.htm
It says:
The Federal Aviation Administration, Air Traffic Control System Command
Center (ATCSCC), will utilize a Special Traffic Management Program (STMP)
for this event. Slot reservations will be required for all domestic,
non-scheduled IFR arrivals to the following airports during the date and
times indicated:
Laurence G. Hanscom Fld.
BED
Beverly Muni
BVY
Lawrence Muni
LWM
Norwood Mem
OWD
My opinion? The process will likely be very similar to what happened
during the G8 Summit in Georgia.
See http://www.faa.gov/Newsroom/Airspace...ntent=Affected
for what the FAA said about operations during the G8.
I imagine VFR ops at these four airports will be much like how things
happened when the Boston airspace opened back up for VFR operations just
after 9/11.
One thing - because GA is excluded from Logan, these four airports are
going to be much more crowded, as they're the new destinations for all the
traffic banned from Logan.
So - don't sweat it TOO MUCH if you're based within the 30-mile ring.
-Jack Cunniff
(at OWD)
Old June 17th 04, 07:22 PM
Jeremy Lew
That FAA link specifically says that the special IFR arrival procedures are
due to the higher than normal anticipated volume of flights, it has nothing
to do with security.
"Jack Cunniff" wrote in message
It says:
times indicated:
BED
Beverly Muni
BVY
Lawrence Muni
LWM
Norwood Mem
OWD
after 9/11.
-Jack Cunniff
(at OWD)
Old June 17th 04, 08:02 PM
On Thu, 17 Jun 2004 17:04:45 +0000 (UTC), Jack Cunniff ("Jack") writes:
Jack Logan will be closed to all but commercial traffic, yes. No GA
I am specifically concerned with the traffic/news helicopter service.
(I'm concerned about the larger issues, but am trying to draw
a boundary around one specific aspect of the restriction that
seems blatantly obviously detrimental to the public interest,
regardless of national security or airman politics or anything.)
On Thu, 17 Jun 2004 14:22:12 -0400, Jeremy Lew ("Jeremy") writes:
Jeremy That FAA link specifically says that the special IFR arrival
Jeremy procedures are due to the higher than normal anticipated
Jeremy volume of flights, it has nothing to do with security.
I think that's almost certainly bull****. I mean, is is that there
are going to be so many more scheduled airliners coming in all week
that they're going to be unable to avoid a couple of helicopters?
Or is it the onrush of zillions of GA planes coming to fly over the
city in order to view... nothing that's outside? And bear in mind
that in order to begin to create the hypothetical problematic situation,
all these mysterious random aircraft inundating the area from parts
unknown would have to be ignoring the permanent class B Boston airspace.
Old June 17th 04, 10:02 PM
Ron Rosenfeld
On Thu, 17 Jun 2004 09:25:42 -0400, Peter R.
This will shut down all Angel Flights into and out of Boston's Logan
Airport, a very common destination for children with severe burns, cancer
survivors, and organ transplant recipients.
How do you know that?
Old June 17th 04, 10:11 PM
Jeremy Lew
I assumed they meant that they expect a lot delegates to be
arriving/departing on GA flights.
"Christopher C. Stacy" wrote in message
writes:
Old June 17th 04, 10:46 PM
On Thu, 17 Jun 2004 17:02:14 -0400, Ron Rosenfeld ("Ron") writes:
Ron On Thu, 17 Jun 2004 09:25:42 -0400, Peter R.
Ron How do you know that?
Because those are GA flights, which will definitely be banned
from BOS, according to the information we have from the Boston
newspapers and what's been posted here from the FAA web site.
The only real question is whether the poster is correct that there
are lots of Angel flights out the affected airports. Boston is in
fact a national destination for medical care and research hospitals,
so that claim seems plausible on the face of it. The remaining detail
would then be about which Boston airport, and how the TFR will treat
the close-in major reliever airports like BED/OWD/LGA, if the flights
would be using those instead.
Do you have some reason to believe that it's not true?
Old June 17th 04, 10:49 PM
On Thu, 17 Jun 2004 17:11:24 -0400, Jeremy Lew ("Jeremy") writes:
Jeremy I assumed they meant that they expect a lot delegates to be
Jeremy arriving/departing on GA flights.
So many that ATC and all the areas airports can't seperate them
from exactly four helicopter aircraft within 30 nm of Boston?
Besides, it seems more likely that most conventioneers will be
arriving on scheduled airliners. (If they were going to use GA
flights, they won't be able to do that now under the proposed TFR,
so that makes no sense in addressing the motivation.)
It's bull****, I tell you.
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
