Missing flight plans
Old August 3rd 06, 08:57 AM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
Default Missing flight plans
"Wizard of Draws" wrote in
message news:C0F6CE43.89355%jeffbREMOVETHIS@REMOVEALSOwiza rdofdraws.com...
Some time ago on a cross-country that took me near, not into,
Chattanooga's
airspace, I notified them where I was as a courtesy. They gave me a code
to
squawk. After I was well clear of their airspace, they told me to resume
own
navigation. Fat, dumb and happy, I squawked 1200 and went on to land at my
home base. After I hanging out a bit, the airport manager came up to me
and
chewed me out for not closing my flight plan. I guess Chattanooga opened
one
for me.
You were on a cross-country without a flight plan?
Michelle S.
Old August 3rd 06, 11:51 AM posted to rec.aviation.piloting,rec.aviation.owning
Denny
He was ?
Oh mi gawd, doesn't he know that will cause your engine to stall and
then you die !!!!
denny
Old August 3rd 06, 01:25 PM posted to rec.aviation.piloting,rec.aviation.owning
Greg Copeland[_1_]
On Thu, 03 Aug 2006 00:35:09 +0000, Travis Marlatte wrote:
You said that you couldn't raise FSS so I assume that you tried. FSS
probably heard your radio calls even though you never heard their response.
They may have opened your flight plan as a default - or maybe your initial
radio calls included the request.
That's what the guy on the other end of the phone said. That seems pretty
odd to me.
Greg
Old August 3rd 06, 01:58 PM posted to rec.aviation.piloting,rec.aviation.owning
Kyler Laird
"Denny" writes:
He was ?
then you die !!!!
And after you die there will be an even *longer* delay before anyone
comes looking for your wreckage (assuming that you didn't have Following
and your ELT didn't function properly and no one was expecting to hear
from you).
Please, people, think of the aging GA fleet. If people go flying around
without flight plans we're going to lose a lot of parts that are
valuable to those of us flying old planes.
--kyler
Old August 3rd 06, 02:59 PM posted to rec.aviation.piloting,rec.aviation.owning
Dave Butler[_1_]
Paul kgyy wrote:
Twice in 2 days I've filed VFR flight plans only to have FSS unable to
find them when I called on radio after takeoff. One was filed through
Duats at 9PM for noon next day (and left at noon). The other was filed
with a briefer at Terre Haute at 10PM for 8AM next day (and left on
time).
In both cases I had to re-file over the radio.
DUAT should be able to trace back through their logs and find out what happened.
It will help if you have the transaction number from when you filed.
A couple of ways I've had flight plans lost:
- filed with FSS, and the N-number had some digits transposed.
- filed with DUAT, and I miscalculated the zulu departure time.
Dave
Old August 3rd 06, 03:12 PM posted to rec.aviation.piloting,rec.aviation.owning
xyzzy
time).
I've filed withi DUAT planning to use a specific club plane. then I
get to the airport and that one has a squawk so I take a different
plane. I've had good luck when that happens calling up ATC and telling
them that I'd like to open a flight plan that was filed with tail
number x but I need change the tail number to y and open it. I've done
this with VFR palns. So there is some flexibility there. Of course in
that case I knew what the "wrong" tail number was, if I had made a typo
they probably would never have found it.
Old August 3rd 06, 03:35 PM posted to rec.aviation.piloting,rec.aviation.owning
Greg Copeland[_1_]
On Thu, 03 Aug 2006 07:12:44 -0700, xyzzy wrote:
[snip]
Of course in
If you file with a contact, can't they look it up that way too?
Greg
Old August 3rd 06, 04:38 PM posted to rec.aviation.piloting,rec.aviation.owning
Andrew Gideon
I've had good luck when that happens calling up ATC and telling them that
I'd like to open a flight plan that was filed with tail number x but I
I've had last-minute plane switches too, and it never occurred to me to do
as you've done.
Thanks for mentioning it.
- Andrew
Old August 3rd 06, 05:51 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Burns[_1_]
"Kyler Laird" wrote in message
--kyler
Hey Kyler... this will hit home. We just finished the annual on our Aztec.
There is a fellow based at the airport where we had the work done that has
trashed 3... yes THREE Aztec's in less than 6 months. Runway overrun taking
out the gear and nose, groundlooped the second Aztec in a
crosswind/crossrunway/into the ditch maneuver taking out the gear, then hit
a deer with the third but after it was fixed lit the left engine on fire.
Talk about being hard on the used parts inventory!
Old August 3rd 06, 06:15 PM posted to rec.aviation.piloting,rec.aviation.owning
Mark Hansen
--kyler
I wonder what that does to his insurance rates.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
DUATS & Canadian Flight Plans Andrew Sarangan Piloting 2 November 7th 05 08:51 PM
Third Military-Civil MAC Jan. 18, 2005 Larry Dighera Piloting 37 February 14th 05 03:21 PM
Aerial PHotography Flights 'Required' to File Flight Plans C J Campbell Piloting 15 December 6th 04 02:17 PM
