Cigarette Lighter Adapter- Cessna 172
Old August 4th 06, 12:34 PM posted to rec.aviation.piloting
Dan Luke
Default Cigarette Lighter Adapter- Cessna 172
"RST Engineering" wrote:
I don't mean to be pedantic...
LOL
Old August 4th 06, 01:07 PM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
B A R R Y wrote:
On Fri, 04 Aug 2006 07:15:03 GMT, Grumman-581
Even though I've never smoked, I don't want to give up my
lighter plug in my aircraft or any of my cars... I use them for too
many other gadgets that I don't want to do without...
Many new cars include multiple outlets.
It would make a lot more sense to include a 110V ac outlet (using an
inverter) instead of the 12V/24V plug. That way you can use the
standard wall connector and not have to worry about carrying special
adaptors.
Old August 4th 06, 01:16 PM posted to rec.aviation.piloting
Ron Natalie
RST Engineering wrote:
I don't mean to be pedantic, but you can't "transform" a DC voltage;
transformers only work on AC. Do they use a center tap on the battery or a
regulator? If they use a regulator, it had damned well better be a hefty
one to take the slug of current that a cigarette lighter draws.
Only if it is indeed a cigarette lighter and not just a cylindrical 12V
power outlet. My plane has the latter (it just has a plastic cap on
it). I would blow the breaker if I tried to stick a cigarette lighter
in there.
Old August 4th 06, 01:17 PM posted to rec.aviation.piloting
Ron Natalie
Andrew Sarangan wrote:
Do people really smoke cigarettes while flying?
The DE who gave me my private checkride smoked a pipe
while flying. The ashtrays in the planes pretty much
showed that someone else in the right seat used to smoke
(my flight instructor was a smoker, but he never smoked
while instructing to my knowledge).
Old August 4th 06, 02:29 PM posted to rec.aviation.piloting
Morgans[_3_]
adaptors.
Do you have any idea how much power that would require, and the cost of the
inverter for a good sized, powerful laptop computer?
With the inefficiency of most inverters, at least 1000 watt, and the price
goes into hundreds of dollars.
Old August 4th 06, 03:24 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 3 Aug 2006 20:05:39 -0700, "RST Engineering"
wrote in
That would be about 10 amps if it's similar to an automobile.
Old August 4th 06, 05:38 PM posted to rec.aviation.piloting
adaptors.
I have an inverter that I bought for $19.99. It has a 150W contunuos
power rating. It runs my laptop just fine. Why do you need 1000W?
Old August 4th 06, 05:52 PM posted to rec.aviation.piloting
Morgans[_3_]
My Toyota has both! G
How many watts, or amps?
Old August 4th 06, 06:04 PM posted to rec.aviation.piloting
Jim Logajan
"Andrew Sarangan" wrote:
of the inverter for a good sized, powerful laptop computer?
price goes into hundreds of dollars.
If the expectation is that the inverter is terribly inefficient (say ~10%)
I could see it needing to draw 1000 W DC to produce 100 W AC. But I believe
they are generally 80% efficient or better - otherwise they'd fry
themselves. Laptops aren't supposed to be very power hungry - even my floor
standing "tower" computer (excluding my CRT monitor) typically draws under
100 W AC (I used a portable power meter to measure the power draw of my
computer equipment to size the UPS I needed for my home office).
Old August 4th 06, 07:09 PM posted to rec.aviation.piloting
Newps
adaptors.
What? I have a 150 watt inverter that works just fine for
recharging/running laptops, PDA's, cell phones, etc. It's an all in one
unit, no separate cord and device. About $20 at Walmart.
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
Cigarette Lighter Adapter- Cessna 172 TF Piloting 6 April 13th 05 01:01 AM
