That's it - no more, no less. On the missed, you either talk to ATC (or you follow lost comm. procedures) or you are uncontrolled and on your own. That is a good point (many people who learned to fly IFR in the lower 48 and southern Canada don't think of it that way, but the airspace system is designed to allow instrument flight from takeoff to touchdown without ever talking to anybody). But I think the discussion was not largely misunderstood, the basic question was what is the clearance limit at the end of an IAP in *controlled* airspace, and besides Frank's reference to the AIP, this has gone unanswered. Is it the MAP, at which point you enter either a published or standard holding pattern, or the alternate airport ? Sorry, not to nit-pick, but this is a real scenario - I just missed an approach, got busy reconfiguring the airplane and I am reaching the "climb-to" altitude 0.5nm from the MAP with its *depicted* racetrack pattern at 120 knots. The frequency is congested and I can't get a word in. What should I do in Canada ? |
*controlled* airspace Martin, good point. Here's my answer: The clearance limit is the Missed Approach Holding Fix, i.e. the last point of the missed approach procedure unless other instructions were received. AIP RAC 9.26 clearly regulates the scenario where you are not in contact with ATC by then. Im writing from memory here, but you're supposed to hold standard on the inbound track to the fix (whatever that may be) or in any depicted holding patterns incl. shuttle holds or some other very specific provisions. There you hold until you talk to someone or you run out of options... All the best, Gerd |
gwengler wrote:
the basic question was what is the clearance limit at the end of an IAP in *controlled* airspace good point. Here's my answer: The clearance limit is the Missed Approach Holding Fix, i.e. the last point of the missed approach procedure unless other instructions were received. AIP RAC 9.26 clearly regulates the scenario where you are not in contact with ATC by then. Here's the actual text, since (sadly) the AIP is not available online. Note that in practice, controllers nearly always give specific missed approach instructions in advance when you're landing in low IMC. RAC 9.26 Missed Approach Procedures Whenever a pilot conducts a published missed approach from an instrument approach procedure, the aircraft must continue along the published final approach course to the published Missed Approach Point (MAP) and follow the published missed approach instructions. The pilot may climb immediately to the altitude specified in the missed approach procedure or assigned by ATC. In the event of a missed approach when no missed approach clearance has been received, the pilot will follow the published missed approach instructions. Should the pilot arrive at the missed approach holding fix prior to receiving further clearance, the pilot will: (a) hold in a standard holding pattern on the inbound track used to arrive at the fix; (b) if there is a published missed approach track to the fix, hold in a standard holding pattern inbound to the fix on this track; (c) if there is a published shuttle or holding pattern at the fix, hold in this pattern regardless of the missed approach track to the fix; or (d) if there are published missed approach holding instructions, hold in accordance with these. If a clearance to another destination has been received, the pilot shall, in the absence of other instructions, carry out the missed approach instructions until at an altitude which will ensure adequate obstacle clearance before proceeding on course. If specific missed approach instructions have been received and acknowledged, the pilot is required to comply with the new missed approach instructions before proceeding on course, e.g., "on missed approach, climb straight ahead to 3 000 feet; right turn, climb on course" or "on missed approach, climb straight ahead to the BRAVO NDB before proceeding on course". Civil and military air traffic control procedures do not require the air traffic controller to provide terrain and obstacle clearance in their missed approach instructions. Terms such as "on missed approach, right turn climb on course" oir "on missed approach, left turn on course" are not to be considered specific missed approach instructions. It remains the pilot's responsibility to ensure terrain and obstacle avoidance and clearance. All the best, David |
![]() the [Canadian] airspace system is designed to allow instrument flight from takeoff to touchdown without ever talking to anybody What besides the big sky principle separates aluminum? Jose -- (for Email, make the obvious changes in my address) |
![]() "gwengler" wrote in message om... (Teacherjh) wrote in message ... the [Canadian] airspace system is designed to allow instrument flight from takeoff to touchdown without ever talking to anybody What besides the big sky principle separates aluminum? Jose ... and announcing every altitude change on a common frequency (126.7 in Canada). ... .... or 5680 kHz domestically or other international HF frequencies for long-distance communication in the more remote areas. |
As another poster said correctly (that's what I kinda meant by lost
comm. procedures) refer to AIP RAC 9.26 where there is a whole list of holding options if you don't get hold of ATC before reaching the missed approach holding fix. But - as in the US - you cannot hold forever and then it's off to the lost comm. procedures. Gerd |
Canadian Aviation Expo - Europa will be attending | Pete | Home Built | 0 | June 17th 04 01:10 PM |
FAA's Instrument Procedures Handbook | Barry | Instrument Flight Rules | 3 | June 5th 04 07:31 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
Requirement to fly departure procedures | [email protected] | Instrument Flight Rules | 77 | October 15th 03 06:39 PM |
Holding Pattern Entries | Dan Luke | Instrument Flight Rules | 17 | July 11th 03 05:18 AM |
