Commercial precision landings
Old August 18th 06, 03:41 AM posted to rec.aviation.piloting
Steven Barnes
Default Commercial precision landings
I've gone up with my CFI for a couple more flights just working the landings
in the Bonanza (A BE33, by the way). They're alot better, but once in a
while I'll still float past where I need to be.
I failed the first short-field because I was way long, and the short
approach was well below best glide with the gear hanging out & a very nose
high attitude at the very last. We would have made the runway, but he called
for a go-around. That apparently, was the final straw that ended the ride. I
agree it was a crappy approach.
Now I've got them more consistent. But once in a while, there's still a
floater I can't seem to get down, or a power off that's setup & safe, but
still short of my desired touchdown point. Ugh.
"Jim Burns" wrote in message
As others have mentioned, speed control and a tight pattern. I'd rather
be
high and tight, guaranteed to make the runway and allowing a slip as an
option, low and wide doesn't leave you that option. Explaining your
reasoning, as long as it's safe and correct, shows commercial knowledge.
My commercial ride was the last ride that I was able to take with our
local
DE. He's a real parrot on checkrides and a great teacher. When we were
about 5ft agl on the 180 degree power off spot landing, he asked if we'd
make the designated touchdown spot. I responded confidently that we would
because if we were short the ride would be over. Then he asked what
options
I had to extend the glide "just in case"... Prop I said, pull the prop and
reduce the disc drag. "Ever done it?" he asks. "Nope" by that time his
hand was already on the prop control and it was coming back. We floated
an
extra distance, I can't remember how far, but he laughed and said "See how
that works? But think before you do it, you need oil pressure in a single"
And with that our ride ended on a fun and informative note.
Old August 18th 06, 03:49 AM posted to rec.aviation.piloting
Peter R.
Morgans wrote:
I don't know what everyone else thinks, but that does not seem like very
much time to transition into a Bo, to me.
I had about 550 hours in a C172 before I moved up to a Bonanza and it took
me about 12 hours with an instructor to get (more or less) comfortable with
the added workload and speed of the aircraft.
Peter
Old August 18th 06, 05:18 AM posted to rec.aviation.piloting
Jose[_1_]
Are you taking wind sufficiently into consideration in your sight picture?
Jose
The monkey turns the crank and thinks he's making the music.
Old August 18th 06, 05:48 AM posted to rec.aviation.piloting
Morgans[_3_]
with
Yeah, I would think. Did you also have to pass a commercial checkride at
the end of the 12 hours? I would think you would want to be more than (in
your words) "more or less comfortable with the added workload and speed"
before you had to pass a checkride, with all of the added pressures and
nervousness that "automatically" comes with a checkride.
Old August 18th 06, 07:05 AM posted to rec.aviation.piloting
Jim Macklin
I like 1.5 Vs until on final, that provides a good margin
for maneuvering with bank angles up to 30 degrees. Yes you
can calculate the proper speed, Beech does have the proper
speeds on their performance charts, adjusted for actual
weight.
"john smith" wrote in message
| In article 4B6Fg.4479$SZ3.926@dukeread04,
| "Jim Macklin"
| Lands are all about controlling speed, the right speed.
1.3
| Vs(x) for the weight you're actually flying.
| Remember that Vsx gear down is about 15-20 mph slower than
Vsx gear up.
| Look it up in the charts.
| You didn't say
| what model Bonanza, but an A36 can be 800 pounds under
| certificated GW, or 25% under. You must reduce your
| approach speed by the proper amount or you will float
| forever. Beech does publish excellent TO and Landing
graphs
| with speed adjustments.
| Landing weight = w2
| Max gross weight =w1
| Stall speed landing weight, landing config = Vs1
| Stall speed at max gross weight, landing config = Vs
| [sqrt (w2/w1)*Vs] = Vs1
| You can fly a few knots, not more than 5, faster which
will
| give you a steeper descent and then you can use the
extra
| speed to slow down to get a better glide. If you are
using
| best glide speed there is nothing you can do to improve
your
| approach without adding power.
| You are likely flying too fast and too wide on downwind.
| You are also probably watching your gauges and airspeed
as
| you configure the Bonanza for the approach, do it by
sound
| and feel and watch the runway for relative motion (drift
and
| glide path) and you should do fine.
| Remember, you will get a landing gear failure and it may
| come in the pattern with a simulated engine failure.
Make
| sure you know the procedure and have checked during the
| pre-flight that the gear handle can be un-stowed
[sometimes
| the spar cover is installed over the handle]. But also
| remember that it take 50 turns to get the gear down and
you
| only have so much time. If he gives you a simulated
engine
| failure and then the gear fails, exercise your judgment,
| tell him that in a real case you'd land gear up rather
than
| risk a crash while trying to crank the gear. Then add
power
| and go-around, crank the gear on downwind to show him
you
| know how. Sometimes an examiner will give you a task to
see
| if you have fixated on the checkride and not the safety
of
| the flight.
| Jim, is there any speed that is best to fly when cranking
the gear down
| by hand?
Old August 18th 06, 12:55 PM posted to rec.aviation.piloting
Peter R.
Not at all. This was just to move up to the aircraft, not to obtain my
commercial. About half those hours were flying in real IMC to get used to
handling the aircraft in an IFR setting, which I don't believe is part of
the commercial training, is it?
In any regard, I doubt I would have passed the commercial checkride after
those 12 hours/
Agreed.
Peter
Old August 18th 06, 05:18 PM posted to rec.aviation.piloting
Michelle P
I'm taking my 2nd stab at my commercial checkride in a couple days.
Last week, I got through the Oral exam fine. We first flew my
instructor's Bonanza for the complex pattern work. Didn't do too bad on
the soft-field stuff, but I sailed right past my short-field mark by
about 300 feet. We then tried a short approach. Not even the 180 deg
accuracy landing. Just make the runway. Well, after several laps of
dropping the gear abeam the numbers, I did it again & came up well
short of the runway.
Pink slip.
I've gone up with my instructor to work on both accuracy landings, but
can't seem to hit them consistently. Any advice? Any examiners care to
tell how much "fudge" factor they may allow if I'm a little short or
long? If I am, can I request another try at it?
I haven't even had the chance to demonstrate the airwork in my Cherokee
yet (which I think will go much better). I'm hoping the DE will let me
do that stuff first & save the complex for last. But, since the complex
is what I failed the first time, I don't know if we have to complete
that first.
My CFI says I fly just fine, and I'm starting to feel more comfortable
in the Bo (only 7 hours so far). I've got 160+ in the Cherokee & 450
total. I'm just psyching myself out over 2 little landings.
Ugh.
Too little time in the airplane to judge how it will respond to what you do.
Wait a while It takes time. I did not pass my ATP multi partly because
they switched airplanes on me at the last minute.
Michelle P
Old August 19th 06, 05:35 PM posted to rec.aviation.piloting
Darrell S[_1_]
I got my commercial due to being a military pilot so I only had to take a
written test on civilian regulations. Won't the examiner allow you to use
power on final to drag it to the point you wish to land and then throttle to
idle? After I retired from the Air Force some friends let me be a member of
their aero club for free in exchange for flight instruction. This one guy
had the same problem you're having. He couldn't consistently land at the
beginning of an actual short runway. I asked him why he didn't take his
base leg out a little further so he could drag it in with some power and
then chop it at the runway. His eyes got big and he said he didn't think
that was legal. I told him it was silly to purposely enter an uncontrolled
event to avoid the POSSIBILITY of an engine failure and not having enough
glide speed/path to get to the runway. Sure, if you have a normal runway
length you should set up so that with an engine failure in the pattern you
can still make it to the runway.
You try not to deliberately enter a dangerous situation to avoid the
possibility of something else happening. But if the regs for the CHECK RIDE
don't allow it you have to do it that way for the check ride only. But not
in a real very short field situation.
Darrell R. Schmidt
B-58 Hustler History: (see below)
http://members.cox.net/dschmidt1/
Pink slip.
that first.
Ugh.
Old August 19th 06, 08:49 PM posted to rec.aviation.piloting
Steven Barnes
There's 2 accuracy landings for Commercial. A short-field (with power) and a
180 degree power off landing.
I took my re-test today & passed! Got passed the landings I missed in the Bo
& then got to do the airwork stuff in my Cherokee. Whew. Now I can start
reading up on CFI training.
As my CFI & I were putting away the Bonanza, we watched 4 F-16s (based here)
make a tight short approach to land. They make it look easy... ;-)
Thanks for all those who chipped in some advice.
"Darrell S" wrote in message
news:v5HFg.1632$y61.1016@fed1read05...
to
of
uncontrolled
RIDE
not
Darrell R. Schmidt
Old August 19th 06, 09:51 PM posted to rec.aviation.piloting
Jim Macklin
It is a test, with a maneuver described.
http://www.faa.gov/education_researc...S-8081-12B.pdf
had to take a
allow you to use
me be a member of
didn't take his
some power and
he didn't think
not having enough
a normal runway
the pattern you
avoid the
for the CHECK RIDE
ride only. But not
| Darrell R. Schmidt
| wrote in message
couple days.
flew my
short-field mark by
the 180 deg
several laps of
came up well
| Pink slip.
landings, but
examiners care to
little short or
in my Cherokee
DE will let me
since the complex
to complete
| that first.
more comfortable
Cherokee & 450
landings.
| Ugh.
Currency requirements for commercial glider pilot Doug LS4 Soaring 3 August 14th 06 02:02 AM
Commercial rating: Am I wrong here? gatt Piloting 12 November 21st 05 12:35 AM
Precision Landings and practice [email protected] Piloting 34 December 17th 04 02:08 PM
