Can a failed Glide Slope also void the Localizer approach?
Old August 24th 06, 12:29 AM posted to rec.aviation.ifr
Jim Carter[_1_]
Default Can a failed Glide Slope also void the Localizer approach?
Thanks a lot Sam. This is what I needed; a few specific sites that I can
use for reference.
-----Original Message-----
Posted At: Wednesday, August 23, 2006 10:32 AM
Posted To: rec.aviation.ifr
Conversation: Can a failed Glide Slope also void the Localizer
approach?
Subject: Can a failed Glide Slope also void the Localizer
approach?
Quite a few, such as Boeing Field, Arcata, California Reno, Butte,
Montana. All of those have a separate LOC procedure, which cannot be
switched to midsstream. Missula, Montana was an ILS that does not
have
a separate LOC IAP.
Old August 24th 06, 05:20 AM posted to rec.aviation.ifr
Jose[_1_]
All of those have a separate LOC procedure, which cannot be switched to midsstream.
Why could one not switch midstream? Assuming the LOC course is the
same, if the GS goes out, fly level until the next stepdown.
Jose
The monkey turns the crank and thinks he's making the music.
Old August 24th 06, 12:11 PM posted to rec.aviation.ifr
Ron Rosenfeld
Jose
That's not a bad question. But easily answered if you look at the charts. I
didn't look at all of them, but perhaps if you examined the BFI ILS Rwy 13R
approach, or the KMSO ILS RWY 11 approach, you would understand.
Old August 24th 06, 02:15 PM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
Jose
It is fine to switch mid stream. Looking at the BTM approach, I suspect
the only reason the LOC and ILS are published as separate charts is
because several significant differences in IAF, glideslope intercept
altitude and Missed Procedures. The chart would be way too cluttered if
presented on one sheet.
Old August 24th 06, 04:01 PM posted to rec.aviation.ifr
Jose[_1_]
Well, maybe I'm thick, but I don't understand. True, you need to be
prepared to switch (i.e. have the chart handy, have the DME tuned
properly) but I see no reason why a properly prepared pilot could not
switch. True, you may be below the stepdown fix when you lose the GS,
but if you don't go any lower, you won't hit anything (the GS has
already provided obstacle clearance) and you should be able to fly your
present altitude until the next stepdown.
Or... set up for the LOC, but fly the GS if it's available.
I'm looking right now at the BFI ILS 13R and the LOC/DME for the same
runway.
Jose
Old August 24th 06, 07:18 PM posted to rec.aviation.ifr
Michael[_1_]
switch.
runway.
Try looking at the BTM ILS 15 and LOC/DME for the same runway, and it
will be a lot clearer. You can't set up for the LOC and use GS if
available, because the procedures for setting up are not the same. On
the ILS, you intercept the GS at 10,600, at 14+ DME from I-BEY. On the
LOC/DME, you can be down to 9600 at that point. Even if you do pull
that off (and it can certainly be done - at least the intercept is from
below), there is another reason you can't do it. The missed approach
for the ILS has you climbing to 11,000. On the LOC/DME, it's only
9,200. Might be iffy if the controller has someone holding at CPN at
11,000 or something similar.
There certainly are situations (BFI ILS 13 and LOC/DME comes to mind)
where the approaches are sufficiently similar that you could do it
safely, but that's not how the regulations work. If you are cleared
for one approach, you can't just change your mind and do another,
because there is no requirement to design them such that the change is
safe - and BTM is one example where the change is NOT safe. Therefore,
you are cleared for one given approach (unless given a cruise clearance
or explicitly cleared for any approach) and you must obtain an amended
clearance if you want to change your mind.
In those situations where the approaches are on the same plate (say
ILS/LOC or VOR/GPS or some such) the approach clearance covers whatever
is on the plate for which you have the equipment, and thus you can make
the change midstream if you so choose since the design of the approach
is such that the change is safe.
Michael
Old August 24th 06, 08:41 PM posted to rec.aviation.ifr
Sam Spade
to midsstream.
Jose
They are on separate charts with separate titles because they are
sufficiently different to defy making a clear chart.
Old August 24th 06, 09:01 PM posted to rec.aviation.ifr
Ron Rosenfeld
runway.
Jose
What Michael wrote.
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
