#11
I fully understood that we were talking IFR Flight.
The only additional requirement I can find for IFR flight in Class G airspace is that the pilot be instrument rated and Current. Note: that an airplane instrument rating is valid in a glider. I was recently flying with a group of 15 glider pilots I believe at least 3 of these pilots also had instrument ratings. In Class D & E airspace a Clearance is a also required. In Class ABC Airspace a Transponder is required with the current inspections. I am looking forward to seeing his book on cloud flying, This is defiently a topic that does not get much attention in the US and as result there seems to be a lot of misinformation about it as evidenced by this thread. Brian CFIIG/ASEL snoop wrote: Son, we're talking IFR flight here. Try reading the first post. |
Jacek,
I'm anxiously awaiting the article as well! Until it is, though, here are some tasty morsels: There aren't any FAR's that clearly say: "To fly a glider under IFR, you must..." But there are some regs that we can correlate together to find that, yes, flying a glider under IFR is completely legal. Such as: There is no instrument rating available for gliders, as is specified by CFAR § 61.5(b)(8): § 61.5 Certificates and ratings issued under this part. b) The following ratings are placed on a pilot certificate (other than student pilot) when an applicant satisfactorily accomplishes the training and certification requirements for the rating sought: (8) Instrument ratings (on private and commercial pilot certificates only)- (i) Instrument-Airplane. (ii) Instrument-Helicopter. (iii) Instrument-Powered-lift. But, CFAR § 61.3(e)(3) states that a pilot can get certified to fly a glider under IFR: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. And, CFAR § 61.57(c)(2) specifies the recent pilot experience needed to act as PIC in a glider under IFR: § 61.57 Recent flight experience: Pilot in command. (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (2) For the purpose of obtaining instrument experience in a glider, performed and logged under actual or simulated instrument conditions- (i) At least 3 hours of instrument time in flight, of which 1 1/2 hours may be acquired in an airplane or a glider if no passengers are to be carried; or (ii) 3 hours of instrument time in flight in a glider if a passenger is to be carried. Furthermore, CFAR § 61.57(d)(1)(iii) specifies how a glider pilot can get an instrument competency check: § 61.57 Recent flight experience: Pilot in command. (d) Instrument proficiency check. Except as provided in paragraph (e) of this section, a person who does not meet the instrument experience requirements of paragraph (c) of this section within the prescribed time, or within 6 calendar months after the prescribed time, may not serve as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR until that person passes an instrument proficiency check consisting of a representative number of tasks required by the instrument rating practical test. (1) The instrument proficiency check must be- (iii) For a glider, in a single-engine airplane or a glider. As far as inspections are concerned, CFAR § 91.413(a) does not exempt gliders from the 24-month transponder inspection requirement: § 91.413 ATC transponder tests and inspections. (a) No persons may use an ATC transponder that is specified in 91.215(a), 121.345(c), or §135.143(c) of this chapter unless, within the preceding 24 calendar months, the ATC transponder has been tested and inspected and found to comply with appendix F of part 43 of this chapter. But the altimeter inspection required by CFAR § 91.411 only applies to airplanes and helicopters: § 91.411 Altimeter system and altitude reporting equipment tests and inspections. (a) No person may operate an airplane, or helicopter, in controlled airspace under IFR unless- snip Equipment requirements to certify your glider for IFR flight are determined by the manufacturer, and the FAA. If you certify your glider with an Experimental Airworthiness Certificate, you will need to comply with your certificate's limitations, just like any other experimantal aircraft. As far as the procedure for receiving your IFR clearance is concerned, you can use any approved method, there aren't any special procedures for gliders. And, FYI, I just visited the Schempp-Hirth factory last week where I saw a beautiful new IFR-certified Ventus with a US registration. Yes, it's legal. Chris Fleming, F2 wrote: Yeah, IFR it is....I am very curious about that article, will you include all the FAR's and AIM's for glider flight in IMC? How about xponder check out every 24 months? How about the instrument rating? Is one available for a glider? And yeah, how about the clearance? Do you get a pop-up clearance or , since you are not flying from controlled airport simply have a void time? I would like to be educated in all of those aspects. Thanks, Jacek Washington State |
Brian, I have my FAR/AIM book open. In part 91, give me the glider
specific regs that tell me how to fly a glider, on an IFR clearance in the US. I just reread the requirements for an instrument rating, and nowhere does the word glider show up in FAR 61.65. Shawn, help us out here. F2, thanks for your input, but were shaking down the US regs here. Brian wrote: I fully understood that we were talking IFR Flight. The only additional requirement I can find for IFR flight in Class G airspace is that the pilot be instrument rated and Current. Note: that an airplane instrument rating is valid in a glider. I was recently flying with a group of 15 glider pilots I believe at least 3 of these pilots also had instrument ratings. In Class D & E airspace a Clearance is a also required. In Class ABC Airspace a Transponder is required with the current inspections. I am looking forward to seeing his book on cloud flying, This is defiently a topic that does not get much attention in the US and as result there seems to be a lot of misinformation about it as evidenced by this thread. Brian CFIIG/ASEL snoop wrote: Son, we're talking IFR flight here. Try reading the first post. |
![]() snoop wrote: Brian, I have my FAR/AIM book open. In part 91, give me the glider specific regs that tell me how to fly a glider, on an IFR clearance in the US. I just reread the requirements for an instrument rating, and nowhere does the word glider show up in FAR 61.65. Shawn, help us out here. F2, thanks for your input, but were shaking down the US regs here. Snoop, those are US regs! What reg are you trying to "shake down?" I quoted the exact regs that clearly legalize IFR flying in gliders in the USA. Chris Fleming, F2 |
It may take me bit to remember where the actual authorization for a
airplane instrument rating to qualify for a glider rating is. As a start though FAR 61.57c2 tells you how to remain or get instrument current for gliders. Brian snoop wrote: Brian, I have my FAR/AIM book open. In part 91, give me the glider specific regs that tell me how to fly a glider, on an IFR clearance in the US. I just reread the requirements for an instrument rating, and nowhere does the word glider show up in FAR 61.65. Shawn, help us out here. F2, thanks for your input, but were shaking down the US regs here. |
![]() Brian wrote: It may take me bit to remember where the actual authorization for a airplane instrument rating to qualify for a glider rating is. As a start though FAR 61.57c2 tells you how to remain or get instrument current for gliders. Brian Brian, CFAR § 61.3(e)(3) states that to fly a glider under IFR, the PIC needs to hold an airplane instrument rating and a glider rating: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. Chris Fleming, F2 |
![]() It didn't take me as long to find at as I thought it might: FAR 61.3e3 (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (1) The appropriate aircraft category, class, type (if required), and instrument rating on that person's pilot certificate for any airplane, helicopter, or powered-lift being flown; (2) An airline transport pilot certificate with the appropriate aircraft category, class, and type rating (if required) for the aircraft being flown; (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating; or Brian |
Good find. That's what I saw, in the same vein, with 61.57, how to stay
current, but the requirements for an instrument rating still leave us hanging out there, as mentioned earlier. Now we need the operational or part 91 end of it. How to do it. Hang in there guys, Shawn, c'mon buddy we need you to help here. Brian wrote: It didn't take me as long to find at as I thought it might: FAR 61.3e3 (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (1) The appropriate aircraft category, class, type (if required), and instrument rating on that person's pilot certificate for any airplane, helicopter, or powered-lift being flown; (2) An airline transport pilot certificate with the appropriate aircraft category, class, and type rating (if required) for the aircraft being flown; (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating; or Brian |
![]() snoop wrote: Good find. That's what I saw, in the same vein, with 61.57, how to stay current, but the requirements for an instrument rating still leave us hanging out there, as mentioned earlier. Now we need the operational or part 91 end of it. How to do it. Hang in there guys, Shawn, c'mon buddy we need you to help here. Snoop- What are you talking about?! Ask a specific question! Flying a glider under IFR is EXACTLY THE SAME as flying an airplane under IFR. That is why an instrument rating in airplanes is required to fly a glider under IFR. Here's how you do it: 1. File the flight plan. 2. Receive the ATC clearance. 3. Fly the glider! If your flight is intended to be local in nature, you request a block clearance both laterally and vertically, and remain within your clearance limits. If you are flying cross country, you receive a route clearance with authorization to deviate up to x miles left and right of course within a block altitude limit. If you already have your instument-airplane rating, and a few hundered hours of instrument experinece, you should already know all of this. If you don't, then you shouldn't consider flying a glider IFR. Chris Fleming, F2 |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
