Programming $10 Event Radio
Old August 24th 06, 04:36 PM posted to rec.aviation.piloting
B A R R Y[_1_]
Default Programming $10 Event Radio
Paul Dow (Remove Caps in mail address) wrote:
I'm leaning toward John's idea that they use a low power transmitter to
rebroadcast certain channels.
I agree.
Old August 24th 06, 05:49 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 24 Aug 2006 10:02:20 -0400, "Paul Dow (Remove Caps in mail
address)" wrote in
IjiHg.5888$SZ3.2587@dukeread04:
It's all analog circuits except for a CD9088CB integrated circuit. I
haven't had much luck finding a data sheet for it.
Some clues he
http://translate.google.com/translat...3Doff%26sa%3DG
Experiments with some euro expensive UKW - radio - scanner (only
for mini headphones) In these cheap devices is high-quality (phase
Locked loop), PLL - chip (e.g. “CD9088CB”), which one can adapt
also for other frequencies, approximately as detector for FE -
resonances (narrow-band Rauschspektren etc.)
Particularly favourably even if the radio still another LCD -
frequency announcement has.
Data sheet and circuit for “TDA7088T” (identically constructed
with “CD9088CB” and “SC1088”) (pdf - 100 KB)
http://www.chipdocs.com/pndecoder/da...AN/SC1088.html
Partname: SC1088
Description: FM receiver circuit for battery supply
Manufacturer:
Package: SOP
Pins: 16
Oper. temp.: -10 to 70
Datasheet: PDF (184K).
Click here to download
Download SC1088 data sheet he
http://rds.yahoo.com/_ylt=A0geutsq1O1E._0AP45XNyoA;_ylu=X3oDMTE3YXQzN2w 1BGNvbG8DZQRsA1dTMQRwb3MDNARzZWMDc3IEdnRpZANGNzU1X zExMQ--/SIG=12f22f4sr/EXP=1156523434/**http%3a//matthieu.benoit.free.fr/sc1088.pdf%23search='SC1088'
http://rds.yahoo.com/_ylt=A0geuuZS1....actDS=Start s
Old August 24th 06, 11:20 PM posted to rec.aviation.piloting
Paul,
Can you take a picture of the chip? It'd be easier to identify that
way...
girmann
The thing is easier to open than I thought. Just 2 small philips
screws. I thought the case was glued. The only switches are the
volume/power rotary switch/pot, and the two up/down/mode changing micro
switches.
haven't had much luck finding a data sheet for it. Only wholesale sites
that want to sell me 100,000 units. The manufacturer's logo is a
triangle with
_____
|___|___|
inside.
B A R R Y wrote:
Are there any "DIP" switches inside? These look like plastic blocks
with a row of tiny rocker or slide switches.
New Zealand Gliding Grand Prix 2006 Mal Soaring 10 May 8th 06 06:48 PM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
