primary flight instruments on partial panel
Old August 25th 06, 02:43 PM posted to rec.aviation.ifr
Allen[_1_]
Default primary flight instruments on partial panel
"David Cartwright" wrote in message
"Greg" wrote in message
In primary and supporting method of attitude instrument flying, which
do you consider the primary instrument for bank in the partial panel
situation (loss of both attitude indicator and heading indicator)?
Turn coordinator or magnetic compass?
The turn co-ordinator is your primary measure of bank, for a couple of
reasons. First, the compass doesn't measure bank angle - it just shows
what direction you're pointing in - whereas the TC does show the degree to
which you're banked.
The turn coordinator shows direction and rate of turn but no bank angle.
You can do a skidding standard rate turn with the wings level by applying
rudder in one direction and opposite aileron to keep the wings level. In a
coordinated turn it does somewhat show bank angle but the faster your
airspeed the more bank angle is required to achieve standard rate.
I agree with using the TC over the compass if it is avalable. Following is a
quote out of the Wikipedia, for what it's worth:
"Aircraft compass turns are used in an aircraft when other directional
instruments, such as the directional gyro or turn coordinator, have failed."
http://en.wikipedia.org/wiki/Aircraft_compass_turns
Allen
Old August 25th 06, 03:31 PM posted to rec.aviation.ifr
Jose[_1_]
whereas the TC does show the degree to which
you're banked.
The TC does not show bank. It shows rate of turn, and has a temporary
indication of bank intended to "lead" the turn indication. If you slip
or skid, the TC will shortly indicate "straight" (non turning) flight.
Even though you are banked, you are going straight.
Nonetheless, it's what I would use as primary, if I only had that and
the whiskey compass.
Jose
The monkey turns the crank and thinks he's making the music.
Old August 25th 06, 04:58 PM posted to rec.aviation.ifr
Gary Drescher
"Jose" wrote in message
t...
whereas the TC does show the degree to which you're banked.
indication of bank intended to "lead" the turn indication. If you slip or
skid, the TC will shortly indicate "straight" (non turning) flight. Even
Nonetheless, it's what I would use as primary, if I only had that and the
whiskey compass.
Yup. The crucial point is that the inclinometer tells you about slipping or
skidding. So if it's centered, then the TC indeed tells you whether you're
banked or level.
--Gary
Old August 25th 06, 06:36 PM posted to rec.aviation.ifr
Pixel Dent
t...
whiskey compass.
banked or level.
--Gary
Just two weeks ago I had the wonderful experience of a real live vacuum
failure in the middle of clouds over a 200' ceiling. TC with
inclinometer to keep the wings level and GPS for navigation got me
safely down with help from ATC. I'd check the whiskey compass about once
a minute to make sure nothing was lying to me.
I always practice partial panel approaches without the GPS, but when it
happened in real life I was very happy to have it as a workload reducer.
Old August 25th 06, 05:20 PM posted to rec.aviation.ifr
Robert M. Gary
reasons. First, the compass doesn't measure bank angle - it just shows what
direction you're pointing in - whereas the TC does show the degree to which
you're banked. Second, and most importantly, because of the way it's put
together, the compass doesn't turn steadily, and so it'd be wrong to fool
yourself into thinking that the faster the compass was moving, the more
you're banked.
In a full panel your primary bank is, of course, your heading indicator
in straight flight. Yet it also does not indicate bank angle.
Have a go one day and you'll see. Take someone competent with you to look
out of the window, get to a safe place and height, make sure your DI's set
correctly, and do a rate-one turn through 720 degrees or more (go around as
much as you like, in fact). In the northern hemisphere at least, you'll note
that when the DI goes through 090 or 270, the compass stands a fair chance
of agreeing with the DI. As you go through north, though, the compass will
under-read, and as you go through south, it'll over-read. The only time you
can rely on the compass is when going in a straight line - which is why you
always check and adjust your DI when flying in a straight line.
Actually the compass is very predicatable in a standard rate turn and
its effect is well known and commonly taught to students as "compass
turns" as described in the FAA publication I posted earlier.
Hence if you want to do a partial-panel turn in IMC, you fly straight and
check the compass, then do a rate-one turn (the turn co-ordinator shows you
the bank angle) for the required number of seconds - three degrees per
second for a rate-one turn, of course.
You are describing "timed turns". That is a different technique than
"compass turns". Both are commonly taught to instrument students in the
U.S. and both result in very exact heading changes when understood.
Both are very difficult in turb though.
-Robert, CFII
Old August 25th 06, 09:55 PM posted to rec.aviation.ifr
On 25 Aug 2006 09:20:56 -0700, "Robert M. Gary"
you're banked.
Most of you guys are far better qualified as I only have an IMC
rating. This is less demanding and only valid in the UK. Only 15 hours
training are required so to keep things simple I was told to use the
second VOR dial as a reminder of present heading by setting heading at
the top of the dial. When you make a turn you don't need any maths but
look where you need to be on the VOR dial and convert it visually to a
clock face. If for example you need to turn 120° right that's 20 past
on a clock therefore double and time 40 seconds.
Timing is simply bank into a rate one turn and visually add 40 seconds
to the clock hand (or could use a timer). The only calculation needed
is to double the interpreted time. Hopefully I'll only have to use it
when renewing the rating every couple of years.
As has already been mentioned the easier way is to use the ADF needle.
Old August 28th 06, 05:51 PM posted to rec.aviation.ifr
Ronnie
Greg,
From the Instrument Flying Handbook in the primary / supporting
method, the primary instrument is the one that provides a direct
indication of the parameter you are trying to control.
Therefore, compass would be considered the primary heading
instrument in partial panel for straight flight. If you are trying
to maintain a given heading, the compass is the primary instrument.
During a standard rate turn, you are trying to maintain the rate of
the turn. The turn coordiator or turn indicator becomes primary
during the turn.
From a practical point, the compass is difficult to interpret during
anything but straight and level flight. A ground track from a GPS
or Loran provides a good substitute for the DG during partial panel
situations. During partial panel, I tend to use the turn coordinator to
keep the wings level, ground track readout for heading info and timed
turns to make heading changes.
Ronnie
thank you
Greg
greggordon.org/flying
Old August 28th 06, 06:21 PM posted to rec.aviation.ifr
Gary Drescher
"Ronnie" wrote in message
news
Greg,
Right, but Greg asked about the primary instrument for bank, not heading.
--Gary
during the turn.
Ronnie
thank you
Greg
Stupid Question Crash Lander Piloting 35 July 23rd 06 02:39 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
