IPC G1000
Old August 24th 06, 11:14 PM posted to rec.aviation.ifr
Default IPC G1000
I'm in the midst of doing two things....
1)Becoming instrument recurrent. (Steam guage airplanes)
2)Getting checked out in a G1000 182.
I'm planning to do the IPC in the Steam guage airplane with some additional instrument work in the G1000.
My real question is how would you do the partial panel approach part of an IPC in the G1000?
There are several ways I know of to simulate a failure on the G1000,
none of which allows one do do a partial panel approach:
1)Dim the display to the point of not being readable.
This leaves the backup instruments for aircraft control, but no source of nav infomation.
If your IPC partial panel approach is anything other than GPS you have no guidance at all.
If it is GPS then all you have is the moving map.
2)Dim the PFD display then switch to revisonary mode...
Just like flying with no failure only reading the instruments from the
co-pilot side. Good practice, but no where near as hard as flying a
partial panel approach with steam guages.
3)Pull the breakers for AHARS/ADC breakers, this simulates AHARS and ADC failures and leaves nav indicators,
but it kills Mode C so ATC is not happy.
For training purposes it would be real nice if you could articicially fail individual
parts of the G1000 AHRS, NAV1, air data etc...
Paul
G1000 question Robert M. Gary Piloting 0 May 1st 06 10:36 PM
New Garmin G1000 Book - read part online Max T, CFI Aviation Marketplace 0 April 16th 06 03:59 PM
G1000 trainer simulator problems akiley Simulators 2 March 25th 06 07:54 PM
G1000 Check out Michelle Piloting 105 January 7th 06 04:33 AM
G1000 lost GPS for a bit Steven Barnes Piloting 3 July 26th 05 02:56 AM
