#11
This is just one of those "little extras" that every pilot should include in
that last second look around the pit before opening the throttle. With me; I always made it a point to hestiate for a few seconds for a line up re-check. Yep... lights, camera, action, where the action - check dg / line it up with runway numbers. Before now, I'll admit, all I did was reset the dg to the runway heading, but from now on, I'll be paying much closer attention to the variance. Too much means something ain't right. -- Guy |
![]() wrote in message Plus it was a 0600 flight, which meant awakening at around 0430. With a muggy motel room listening to countless AC units hum, I wonder what their sleep situation was ?? It was clearly reported shortly after the crash that their rest period had been "well in excess of" the required amount. An 0430 wake up should not be problematic for a flight crew - its normal. You just hit the rack by 8 or 9 PM. Same deal for 0200, or 2300 for that matter. As to the picture you paint of shabby, low-grade accommodations, all I can say is that its highly unlikely. Even 25-30 years ago flying regional, we stayed in reasonable places such as Ramada, Hampton, or HI. A simple search showed that within 5 miles or so of the field there are about 11 national name hotels that offer good reasonable quality, and very often free stuff for flight crews, iirc. It would be very easy to ascertain exactly where they stayed. |
Dudley Henriques wrote:
This is just one of those "little extras" that every pilot should include in that last second look around the pit before opening the throttle. With me; I always made it a point to hestiate for a few seconds for a line up re-check. Dudley Henriques "Christopher Brian Colohan" wrote in message . .. "Dudley Henriques" writes: It can happen and has happened and will happen again as long as pilots don't remember to physically check the runway heading by glancing at the DG or HSI, or even the magnetic compass EVERY time they line up for takeoff. This should be an automatic reflex action for a pilot, especially at busy airports where runways are 30 degrees or less apart in direction. All of my training so far has been at an airport with only one runway (KPAO). Thank you for pointing this out -- checking the runway direction has not been on my checklist before now... Chris Be sure you set the DG to the magnetic compass before you turn onto the runway and not do like some pilots I have seen. Line up on the runway and set the compass. -- Regards, Ross C-172F 180HP KSWI |
Guy Elden Jr wrote:
all I did was reset the dg to the runway heading, Guy, I am curious about this. I have flown with other pilots who reset the DG to the runway heading, but when I question them about this, they admit to setting the DG to the runway number (with the trailing zero, of course). As you most likely know, the runway number (with trailing zero) can be off from the actual heading by as much as 10 degrees. This leads me to my question: How do you easily discover the actual runway heading at an unfamiliar airport? Do you, after deciding on the runway you would use once you start the aircraft, pull out instrument charts or airport diagrams and write down the runway heading? I am curious how others integrate this into their post-start, pre-taxi or pre-takeoff checklists. -- Peter |
![]() John Gaquin wrote: wrote in message Plus it was a 0600 flight, which meant awakening at around 0430. With a muggy motel room listening to countless AC units hum, I wonder what their sleep situation was ?? It was clearly reported shortly after the crash that their rest period had been "well in excess of" the required amount. An 0430 wake up should not be problematic for a flight crew - its normal. You just hit the rack by 8 or 9 PM. Same deal for 0200, or 2300 for that matter. They were all out of town based according to news reports: "Bornhorst would not say whether the crew had experience flying into and out of the Blue Grass Airport. The first officer and flight attendant had been based out of New York, the pilot out of Cincinnati/Northern Kentucky International Airport, according to the airline. Bornhorst did say that the crew was well rested and had spent the night in Lexington in preparation for the early-morning takeoff." You can hit the hay at 9pm, but falling asleep with motel noises is another matter...JG As to the picture you paint of shabby, low-grade accommodations, all I can say is that its highly unlikely. Even 25-30 years ago flying regional, we stayed in reasonable places such as Ramada, Hampton, or HI. A simple search showed that within 5 miles or so of the field there are about 11 national name hotels that offer good reasonable quality, and very often free stuff for flight crews, iirc. It would be very easy to ascertain exactly where they stayed. |
This is just one of those "little extras" that every pilot should include in that last second look around the pit before opening the throttle. With me; I always made it a point to hestiate for a few seconds for a line up re-check. Same here. I wait just long enough to let the compass settle, check it against the DG and against the runway I was cleared to, record the takeoff time and turn the transponder from standby to ALT. Only takes a few seconds once you get the procedure down. I also hope everyone is checking their power indications, vacuum, alternator, etc. as they commence the takeoff roll, especially if launching into IMC. Matt |
Peter R. wrote:
Guy Elden Jr wrote: all I did was reset the dg to the runway heading, Guy, I am curious about this. I have flown with other pilots who reset the DG to the runway heading, but when I question them about this, they admit to setting the DG to the runway number (with the trailing zero, of course). As you most likely know, the runway number (with trailing zero) can be off from the actual heading by as much as 10 degrees. This leads me to my question: How do you easily discover the actual runway heading at an unfamiliar airport? Do you, after deciding on the runway you would use once you start the aircraft, pull out instrument charts or airport diagrams and write down the runway heading? I am curious how others integrate this into their post-start, pre-taxi or pre-takeoff checklists. I don't care what the actual runway azimuth is. I care that my DG is set to my compass and that both agree within reason to the runway I'm on. I'm curious: why do you care what it is? Matt |
Ross Richardson wrote:
Dudley Henriques wrote: This is just one of those "little extras" that every pilot should include in that last second look around the pit before opening the throttle. With me; I always made it a point to hestiate for a few seconds for a line up re-check. Dudley Henriques "Christopher Brian Colohan" wrote in message ... "Dudley Henriques" writes: It can happen and has happened and will happen again as long as pilots don't remember to physically check the runway heading by glancing at the DG or HSI, or even the magnetic compass EVERY time they line up for takeoff. This should be an automatic reflex action for a pilot, especially at busy airports where runways are 30 degrees or less apart in direction. All of my training so far has been at an airport with only one runway (KPAO). Thank you for pointing this out -- checking the runway direction has not been on my checklist before now... Chris Be sure you set the DG to the magnetic compass before you turn onto the runway and not do like some pilots I have seen. Line up on the runway and set the compass. I set mine before I begin taxiing and then check it on the runway right before launch. It is very helpful to have a correctly set DG when taxiing, especially at unfamiliar airports. Matt |
![]() wrote in message You can hit the hay at 9pm, but falling asleep with motel noises is another matter...JG Well, I guess for 22 years of flying I was the beneficiary of incredibly coincidental good luck. The only time time I stayed in noisy hotels was long, long ago when I was travelling on the cheap, and it had less to do with the hotel than the surrounding neighborhood.. |
John Gaquin wrote:
The only time time I stayed in noisy hotels was long, long ago when I was travelling on the cheap, and it had less to do with the hotel than the surrounding neighborhood.. For the last 13 years I have traveled just about every business week. Early on I learned to carry with me a Sharper Image travel-sized white noise radio. This device, which omits white noise similar to a waterfall when switched on, has been responsible for many a restful night's sleep, including one week at a very loud Brooklyn, NY, hotel. I would suspect that most experienced travelers, including airline pilots, do something similar. -- Peter |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Pilot claims no blame in July crash | Mortimer Schnerd, RN | Piloting | 48 | March 15th 06 09:00 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Doubts raised in jet crash | Dave Butler | Piloting | 8 | July 26th 05 01:25 AM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
