#11
Funny you should mention that,,, Mine does the exact same thing, but
it only happens at low powers settings like heading out to the active while at taxi speed. Once airborne and making alot of power then the readings are identical. Ben www.haaspowerair.com Stan Prevost wrote: I owned a turbo Saratoga with a Shadin, and have flown a lot in another identical airplane with a Shadin. Work fine. One strange thing in both airplanes is that turning on the electric boost fuel pump causes a decrease in the fuel flow indicated on the Shadin, by anywhere from 0.1 to 1.0 gph. We spent a lot of effort in removing elbows, insulating the transducer and fuel lines, relocating things, never changed it. I always thought it was weird. Stan |
Mine did it at all power settings and altitudes.
wrote in message ups.com... Funny you should mention that,,, Mine does the exact same thing, but it only happens at low powers settings like heading out to the active while at taxi speed. Once airborne and making alot of power then the readings are identical. Ben www.haaspowerair.com Stan Prevost wrote: I owned a turbo Saratoga with a Shadin, and have flown a lot in another identical airplane with a Shadin. Work fine. One strange thing in both airplanes is that turning on the electric boost fuel pump causes a decrease in the fuel flow indicated on the Shadin, by anywhere from 0.1 to 1.0 gph. We spent a lot of effort in removing elbows, insulating the transducer and fuel lines, relocating things, never changed it. I always thought it was weird. Stan |
On Fri, 1 Sep 2006 14:59:08 -0500, "Jim Burns"
wrote: Thanks TC, I've read about the interference issues and will keep that in mind. Looks like 3 wires from the transducer to the indicator... 1 signal wire, 1 power wire, 1 ground, wristlocked and sleeved at the transducer. Running the wires from the firewall through the nacelle and wing won't be a problem as I became vary familiar with that routing last month when we installed copper starter/battery cables. I haven't found any mounting or plumbing instructions for the transducers, so your info is appreciated. What dealers/whose STC's are you looking at? Seem to remember that we bought quite a few of them from EDMO. Not much on their website (EDMO), need to take a peek at somebody's dealer catalog. Copper wires in an Aztec-heh. Some days I guess I don't miss working on them anymore... TC |
I've talked with all the larger avionics houses, I've got an IA already
talking to EDMO and I've talked to a couple guys in sales at Shadin. The copper wire project really wasn't bad. We had everything opened up anyway. Wow... what a difference! Jim wrote in message ... On Fri, 1 Sep 2006 14:59:08 -0500, "Jim Burns" wrote: Thanks TC, I've read about the interference issues and will keep that in mind. Looks like 3 wires from the transducer to the indicator... 1 signal wire, 1 power wire, 1 ground, wristlocked and sleeved at the transducer. Running the wires from the firewall through the nacelle and wing won't be a problem as I became vary familiar with that routing last month when we installed copper starter/battery cables. I haven't found any mounting or plumbing instructions for the transducers, so your info is appreciated. What dealers/whose STC's are you looking at? Seem to remember that we bought quite a few of them from EDMO. Not much on their website (EDMO), need to take a peek at somebody's dealer catalog. Copper wires in an Aztec-heh. Some days I guess I don't miss working on them anymore... TC |
![]() "Jim Burns" writes: [...] My primary reason for choosing the Shadin over other fuel flow meters/systems is that the Shadin is STC'd for primary replacement of our Piper factory original fuel pressure type flow indicators. You realize that you are sacrificing some redundancy with this, right? Having both fuel pressure and flow rate is a useful cross-check. Plugged fuel injectors show up as a drastic mismatch between the pressure-based vs flow-based numbers. Plus the two of them can complete a corss-checking triangle against the EGT gauge(s). The original fuel flow gauges actually have small fuel lines attached. 40 year old copper fuel lines inside the cockpit do not make me especially comfortable. [...] True, though how frequently do such instruments/lines leak near the cockpit? - FChE |
Sorry Frank, I hit the wrong reply button... anyway, my plan includes a twin
engine analyzer and a couple Aerospace Logic electronic fuel pressure/ammeter gauges. Jim "Frank Ch. Eigler" wrote in message ... "Jim Burns" writes: [...] My primary reason for choosing the Shadin over other fuel flow meters/systems is that the Shadin is STC'd for primary replacement of our Piper factory original fuel pressure type flow indicators. You realize that you are sacrificing some redundancy with this, right? Having both fuel pressure and flow rate is a useful cross-check. Plugged fuel injectors show up as a drastic mismatch between the pressure-based vs flow-based numbers. Plus the two of them can complete a corss-checking triangle against the EGT gauge(s). The original fuel flow gauges actually have small fuel lines attached. 40 year old copper fuel lines inside the cockpit do not make me especially comfortable. [...] True, though how frequently do such instruments/lines leak near the cockpit? - FChE |
Stan Prevost wrote:
I owned a turbo Saratoga with a Shadin, and have flown a lot in another identical airplane with a Shadin. Work fine. One strange thing in both airplanes is that turning on the electric boost fuel pump causes a decrease in the fuel flow indicated on the Shadin, by anywhere from 0.1 to 1.0 gph. We spent a lot of effort in removing elbows, insulating the transducer and fuel lines, relocating things, never changed it. I always thought it was weird. Stan "Jim Burns" wrote in message ... I'm currently in the process of obtaining quotes and researching Shadin's DigiFlo-L fuel flow system. If there are any group members that have had a Shadin installed in their airplane, I'd love to hear from you. My primary reason for choosing the Shadin over other fuel flow meters/systems is that the Shadin is STC'd for primary replacement of our Piper factory original fuel pressure type flow indicators. The original fuel flow gauges actually have small fuel lines attached. 40 year old copper fuel lines inside the cockpit do not make me especially comfortable. Shadin has been impossible to deal with concerning an install manual. They do not post them on their website and do not sell them without the unit. I'd love to get a copy before I spend the money and throw this project into an A&P/AI's lap. If anybody can help me locate an install manual, I'd be grateful. Thanks, Jim Stan, Actually that makes sense. If you are pumping against the metering device you will be initially raising the flow until the down stream plumbing becomes "full". then things will slow down. Michelle P |
![]() "Michelle P" wrote in message ink.net... Stan Prevost wrote: I owned a turbo Saratoga with a Shadin, and have flown a lot in another identical airplane with a Shadin. Work fine. One strange thing in both airplanes is that turning on the electric boost fuel pump causes a decrease in the fuel flow indicated on the Shadin, by anywhere from 0.1 to 1.0 gph. We spent a lot of effort in removing elbows, insulating the transducer and fuel lines, relocating things, never changed it. I always thought it was weird. Stan Stan, Actually that makes sense. If you are pumping against the metering device you will be initially raising the flow until the down stream plumbing becomes "full". then things will slow down. Michelle P No, when I turn on the boost pump, thus increasing the fuel pressure to the sensor and to the engine-driven pump, the flow indication decreases to a new steady-state value until I turn it off, then it increases again to its former steady-state indication. If I turn it on again, it decreases again. Appears to be something unique to that sensor type since it does it in both airplanes I fly that are equipped with the Shadin system. Higher pressure giving lower flow indication is what is wierd. Actually, we would like it to not change. |
![]() "Stan Prevost" wrote: No, when I turn on the boost pump, thus increasing the fuel pressure to the sensor and to the engine-driven pump, the flow indication decreases to a new steady-state value until I turn it off, then it increases again to its former steady-state indication. If I turn it on again, it decreases again. Appears to be something unique to that sensor type since it does it in both airplanes I fly that are equipped with the Shadin system. What kind of sensor is it? It's a turbine type, right? Higher pressure giving lower flow indication is what is wierd. Actually, we would like it to not change. Interesting problem. Perhaps the higher static pressure is putting some kind of friction load on the turbine shaft, maybe by deforming an o-ring seal or some such. -- Dan C172RG at BFM |
![]() "Dan Luke" wrote in message ... What kind of sensor is it? It's a turbine type, right? It is a rotary sensor, but I'm not sure it is a turbine. Some type of positive-displacement paddlewheel design. Higher pressure giving lower flow indication is what is wierd. Actually, we would like it to not change. Interesting problem. Perhaps the higher static pressure is putting some kind of friction load on the turbine shaft, maybe by deforming an o-ring seal or some such. Something like that is all I could theorize, also. We suspected for a while that we had bubbles giving abnormal high readings, and the increaed pressure from the boost pump prevented the vapor bubble formation and thus lowered the readings, but we did about everything that we could think of to eliminate bubble formation, to no avail. I concluded it was the sensor itself. |
Why does fuel flow go UP when leaning on the ground? | Roy Smith | General Aviation | 4 | March 25th 06 01:27 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Arrow II fuel flow | joe | Owning | 3 | June 23rd 05 05:54 AM |
Fuel Flow instrument | Billc851 | Home Built | 18 | March 19th 05 12:49 PM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
