Can EFIS / EFMS lead to removing basic safety checks?
Old September 2nd 06, 04:03 PM posted to rec.aviation.ifr
Michelle P
Default Can EFIS / EFMS lead to removing basic safety checks?
Jim Carter wrote:
This question is the result of the wrong runway issue at LEX last weekend…
Not having flown an EFIS or EFMS myself, I'm not sure of the "into
position checklist items". For example, in a standard steam-gauge panel
one of the last things we check is to align the directional gyro with
the runway heading and compass. With an EFIS or EFMS, is there any such
last minute check, or is the heading assumed to be correct because it
was aligned by the GPS when the bird came out of the chocks?
If there is no requirement to manually align and verify runway heading,
compass, and EFIS/EFMS then our technological advances have
inadvertently removed one of our heretofore unrecognized safety checks.
I heard some retired commuter pilot on the news last weekend suggesting
that the only way to prevent this in the future is to put traffic lights
(stop / go) on the end of every runway. I absolutely got the impression
that he was there to convince the public that it is almost impossible
for the pilots to get it right and the lack of the traffic signal was
the whole cause of the problem. Sort of the typical "not my fault" attitude.
In the modern jets and many GA airplanes too the DG automaticly aligns
the correct magnetic heading. Checking the EFIS heading prior to take
off was not on our companies checklist.
Michelle P
Old September 2nd 06, 04:12 PM posted to rec.aviation.ifr
Sam Spade
Jim Carter wrote:
My question was more along the lines of new systems removing old safety
checks, but no one seems to be addressing that. Is there any physical
action that must be taken as an aircraft with and EFIS / EFMS moves into
position for takeoff to assure that the compass / gyro (or suitable
substitute) / display all agree on the runway heading? Could the modern
glass cockpits be setting us up for incidents or accidents because
insidious little actions we used to take with analog panels aren't
necessary any more?
Probably the best tool is a highly-detailed moving map presentation of
the airport diagram. Having said that, the pilot still has to know the
difference between "22" and "26."
Old September 2nd 06, 04:13 PM posted to rec.aviation.ifr
Sam Spade
Michelle P
It should not have to be on any company's checklist. Some things are
basic airmanship.
Old September 2nd 06, 04:19 PM posted to rec.aviation.ifr
Michelle P
Michelle P
basic airmanship.
Not after having the basic stuff trained out of them.....
Follow the check list, follow the checklist, follow the checklist........
get the idea?
Michelle P
Old September 2nd 06, 05:39 PM posted to rec.aviation.ifr
Beavis[_1_]
In article jchKg.2674$c07.2060@fed1read04,
basic airmanship.
No, they're equipment-specific procedures. Doing a mag check prior to
takeoff is not "basic airmanship" either, nor is realigning the DG every
15 minutes. They're specific procedures required by specific equipment,
and neither is relevant on a modern turbine-powered airplane.
Did you align the IRUs in your 152 before you started moving? Check the
landing gear doors as part of your walk-around? Of course not, because
they're not appropriate procedures for THAT AIRPLANE. See what I'm
getting at?
Old September 2nd 06, 05:58 PM posted to rec.aviation.ifr
Ron Natalie
weekend.
Why would the EFIS be any different than an HSI (or as Bob already
posted the 707 RMI). It still has a heading which ought to be
verified with some real reference (Whiskey compass or runway).
Of course it's easy to get complacent. Back when I had a regular
DG that had to be set, I cross checked it against the compass/runway
on takeoff as a matter of course (since it was almost assuredly wrong).
Now that I have a slaved HSI, it's almost always right so I could see
forgetting to check it. Of course, I also have GPS plotting my position
on the Jepp airport diagram page if the field has an instrument approach
so I probably was one up on these Conair guys.
Old September 2nd 06, 05:59 PM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Saturday, September 02, 2006 11:40 AM
Posted To: rec.aviation.ifr
Conversation: Can EFIS / EFMS lead to removing basic safety checks?
Subject: Can EFIS / EFMS lead to removing basic safety checks?
because
getting at?
I see what you saying about specific procedures for particular aircraft,
but shouldn't heading cross-checks be basic airmanship?
In the analog aircraft that entails manually setting the DG when
cross-checking with the runway and compass. Having not flown and EFIS /
EFMS equipped aircraft, my question was is there a similar cross-check
or has the system negated that necessity. It seems from the answers that
the heading cross-check is no longer manual or an actual checklist item,
so the system has eliminated that safety check.
Now the question becomes, would a checklist item have caught the
complacency if that is truly what the root cause of the LEX accident
turns out to be?
Old September 2nd 06, 06:01 PM posted to rec.aviation.ifr
Ron Natalie
I saw this demoed somewhere (but I don't remember where). It was pretty
cool. There was a row of read lights across the taxiway access to the
runway until cleared for takeoff.
This is used some places. After a spate of Runway Incursion accidents
(well like five years later, even the FAA's knee jerk reflexes are slow)
the FAA did all sorts of things from pilot education, ATC procedure
changes, charting, signage, ground radar, and lights to try to diminish
runway incursions.
It's amazing to me that sort of stuff SHOULD have applied equally to
the "WRONG RUNWAY" (how to you avoid incursions if you don't know which
runway you are turning onto?). Didn't seem to have worked.
Old September 2nd 06, 07:17 PM posted to rec.aviation.ifr
Michelle P
because
getting at?
turns out to be?
You would only check the EFIS heading if the Comparator smelled trouble
and triggered a warning. The computer cross checks the left and right
systems so the pilots do not have to.
Michelle P
Old September 2nd 06, 07:19 PM posted to rec.aviation.ifr
Sam Spade
Michelle P wrote:
Sam Spade wrote:
aligns the correct magnetic heading. Checking the EFIS heading prior
to take off was not on our companies checklist.
Michelle P
basic airmanship.
get the idea?
Michelle P
I think I do.~ I did it for 27 years. Placing the runway heading on a
steam gauge HSI was considered good form at my company, but certainly
not a checklist item.
