G430 Display/Numbers or Pictures?
Old September 5th 06, 04:53 AM posted to rec.aviation.ifr
Peter R.
Default G430 Display/Numbers or Pictures?
Mitty wrote:
So ... Do you normally fly looking at Nav1 or at the map? Cruise?
Approaches? Why? And what is your experience level with the G430?
I toggle between NAV1 and Flight Plan 0 page, with FP0 set to show
cumulative time and distance. I find that FP0 aids in SA by giving me the
upcoming waypoints in time and distance, which I use especially on
approach.
Oh, and perhaps my answer should be stricken from your survey because in my
aircraft the GNS430 feeds a separate MX20 moving map, which I also scan
heavily on approach (in track up mode, of course).
Peter
Old September 5th 06, 05:00 AM posted to rec.aviation.ifr
Jose[_1_]
The CDI display
on Nav1 is pretty useless because it is not a real CDI.
I don't know what that means. When I use the CDI display (page 1 on the
nav screen) I find it quite effective.
Jose
The monkey turns the crank and thinks he's making the music.
Old September 5th 06, 01:17 PM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
Jose wrote:
The CDI display
Jose
That means you are not using the CDI to its full potential. A CDI gives
a _course_ to turn to, not a left/right indication. For that to work,
you need a full circle of numbers around the CDI.
If you have never encoutered this concept before, you should read this:
http://www.sarangan.org/aviation/art...or-article.pdf
Old September 5th 06, 02:29 PM posted to rec.aviation.ifr
Roy Smith
In article . com,
"Andrew Sarangan" wrote:
Jose wrote:
The CDI display
Jose
Andrew,
I just read your article. The big problem with it is that it equates
"heading" and "track". For example, you talk about an OBS set to 210, with
a centered needle and a "FROM" (downward-pointing arrow) indication and say:
"030 lies in the direction of the station. This is the heading we need to
fly to track the course towards the station."
I'll agree that turning to a heading of 030 is a reasonable first estimate
until you figure out the right WCA, but as written, the article is just
plain wrong.
I also take exception to the general tone of the article, which is that the
CDI is a wonderfully designed instrument and whole generations of pilots
and instructors are idiots for not using it the way it was intended to be
used. It certainly is a cleverly designed instrument -- it's the best that
the brightest minds of the aviation world could come up with using the
technology of 50 years ago. You say things like:
"Given the simplicity of this technique, it is somewhat mysterious why this
is seldom taught during flight training".
There's really only two possible answers. One is that we're all idiots,
the other is that it's not really as simple as you make out. You think
it's simple, but, you're a college professor with a PhD. How many of your
students have this level of education?
You say:
"There might be a lesson in this. Some things are better left the way they
are. The VOR system might be a 50-year old technology, but it is one of
the greatest inventions in aeronautical navigation. It is really too bad
that we wonąt have them for much longer"
I can't disagree more. People vote with their feet. The VOR/CDI combo WAS
indeed a great invention. It was better than the ADF because it presented
better information to the pilot. The VOR/HSI was an improvement on that,
for the same reason, but never really penetrated the GA market because of
the high cost. The moving map GPS is an even bigger step up in
presentation (although the UI's for programming them still pretty much
suck).
People's brains have evolved over thousands (millions?) of years to process
visual information. If we're going to have good interfaces to people's
brains, we need to present them with information in the way those brains
are used to processing it. 50,000 years ago, some ancestor of mine could
look at the tree he was walking towards and understand that if he wanted to
get to the tree, he needed to turn left. Given a choice between inventing
technology to match my 50,000 years of visual experience, or training my
brain to understand what a 50 year old electro-mechanical gizmo is telling
me, I'll go with the GPS moving map.
Old September 5th 06, 03:20 PM posted to rec.aviation.ifr
Jose[_1_]
Interesting article. I have come across this before, and yes, I wish it
were taught early in my flying career. However, the nav page of the 430
also gives a course to turn to. DTK.
Jose
Old September 5th 06, 05:48 PM posted to rec.aviation.ifr
Roy Smith wrote:
In article . com,
Jose wrote:
The CDI display
Jose
Andrew,
plain wrong.
You say:
suck).
You are right that I did not address the wind correction aspect.
However, that is not too difficult; just take a heading on the side of
the needle. I did not want to confuse the concept by adding too many
variables.
I think you are being way too sensitive to be insulted by this article.
My intention was to tell pilots that there is an alternate method
instead of the traditional left/right interpretation. I am not trying
to sell any product or service. I am simply passing on some useful
information that I have had the good fortune to learn from others. If
you don't like it, I will give you a full refund :-)
I did my instrument rating using the left/right interpretation and I
found it to be very confusing. In fact I busted my IR checkride because
I turned left instead of right on a VOR holding entry. Then I read an
article that illustrated this technique and life has never been the
same. It is wonderfully useful when being vectored for a localizer or
VOR approach.
I never said moving map was not useful. I use it all the time on my GNS
430. What I meant by "somethings are better left the way they are" was
"the VOR+CDI is better left the way they are instead of trying to mimic
the CDI with an electronic bar scale". I did not mean that VOR is
superior to GPS. If it came across that way, I apologize. That would be
absolutely crazy. I am a big fan of GPS, and I have been messing with
GPS in aviation for at least 10 years. I will be one of the first to
vote with my feet when it comes to GPS.
Actually, it is not that mysterious why more instructors don't teach
this technique. It is just that they are not aware of this method.
Simply pointing that out should not be an insult. I am sure I don't
teach some things that I don't know about, and I am sure you do the
same.
Old September 6th 06, 02:51 AM posted to rec.aviation.ifr
Roy Smith
I didn't mean to imply that I was insulted. My apologies if it sounded
that way.
I did not mean that VOR is superior to GPS. If it came across that way,
I apologize.
Well, it sounds like we're even :-)
That would be absolutely crazy. I am a big fan of GPS, and I have been
messing with GPS in aviation for at least 10 years. I will be one of the
first to vote with my feet when it comes to GPS.
What I don't understand about GPS is why some of them have synthetic HSIs.
One of the new features in the GNS-480 vs. the CNX-80, for example, was the
addition of a "NAV" page, which shows a picture of an quasi-HSI (quasi
because the numbers are showing track, not heading). What's the point?
You've already got a far, superior representation in the moving map. The
position of the aircraft icon relative to the purple line shows your course
deviation, and the *orientation* of the icon shows whether you're getting
better or worse. Displacement AND trend in one picture.
Old September 6th 06, 03:34 AM posted to rec.aviation.ifr
Jose[_1_]
What's the point?
The moving map is not as precise a navigation aid. At least I find
that, when I use the synthetic CDI my track is much more precise then
when I use the moving map.
Jose
Old September 6th 06, 05:07 AM posted to rec.aviation.ifr
karl gruber[_1_]
"track up" gives you more useful information.
Karl
"Curator" N185KG
"Mitty" wrote in message
On 9/4/2006 1:46 PM, Bill wrote the following:
The visual type guys always want the map and track
up too.
Track up drives me nuts! :-) It's on my checklist to make sure the thing
is north up before I take off.
Old September 6th 06, 02:22 PM posted to rec.aviation.ifr
Roy Smith
I'm a track-up kind of guy too, it just seems to make more sense. I don't
particularly care where things are relative to some essentially arbitrary
coordinate system, I care where they are relative to me.
The big question is "which way do I have to turn when I reach the next
fix?" With head-up, it's right there in front of you. With north-up, you
have to mentally orient yourself first. Just one more place to screw up.
I need your process pictures [email protected] Soaring 1 February 3rd 06 05:58 PM
What camera for pictures from a glider cockpit? Eric Greenwell Soaring 34 December 10th 05 06:19 AM
Oshkosh Pictures Marv Home Built 2 August 2nd 05 01:14 AM
Glider Humor Pictures Wanted John DeRosa Sky Soaring Chicago IL Soaring 5 October 14th 03 09:42 PM
Pictures taken at World Aerobatic Championships last week in Florida Dave Swartz Aerobatics 0 July 11th 03 03:11 AM
