#11
On Mon, 04 Sep 2006 16:52:27 GMT, "Viperdoc"
wrote: snip Then, in a routine post flight, I tried the strobes- no luck. The tail flash tube looks a little blackened- does anyone know if the wing tip units will continue to work if the tail tube is dead? Or, does this sound like a power supply issue? All of this is getting to sound expensive as well as being a pain- any advice or commiseration would be appreciated. BTW the plane is a B-55 Baron. TIA If you've still got a Grimes power supply installed-unless you've going to have somebody that's handy with with a soldering iron repair it-consider switching to a Whelen. Going the "approved" repair route, getting a Grimes PS repaired can tend to be pricey and problematic. When a Whelen PS quits (unless things have changed recently) Whelen will either fix it relatively inexpensively or will sell you one a new one at a serious discount. With regard to swapping a Grimes to a Whelen, it's typically a simple log entry http://whelen.com/aviation/pmasupplements/pmasup33.pdf TC |
![]() "Ross Richardson" wrote in ... When I had the prepurchase inspection done on my plane I got an insurance rider on the plane and the owner approved me to fly it to my mechanic. The distance was not too far, thank goodness. Worked fine. Turned the rider into an insurance policy when I bought the plane. How did you ASSURE the owner that the plane would come back to his airport if your A&P report was unfavorable. This seems to be the "fear factor" of allowing the inspection off site for every owner. I've heard of pi$$ing contests of "It wasn't like that when I gave you the plane, your mechanic must have broke it", and such. |
Mike Isaksen wrote:
"Ross Richardson" wrote in ... When I had the prepurchase inspection done on my plane I got an insurance rider on the plane and the owner approved me to fly it to my mechanic. The distance was not too far, thank goodness. Worked fine. Turned the rider into an insurance policy when I bought the plane. How did you ASSURE the owner that the plane would come back to his airport if your A&P report was unfavorable. This seems to be the "fear factor" of allowing the inspection off site for every owner. I've heard of pi$$ing contests of "It wasn't like that when I gave you the plane, your mechanic must have broke it", and such. I had known the owner for some time and he was also a member of our EAA chapter. Plus, I am a good and trustworthy person...... -- Regards, Ross C-172F 180HP KSWI |
I looked at a Baron from an airport around an hour away. I sent them a
deposit check to cover expenses, since they claimed the plane was in great shape and completely as advertised. The agreement was that if I purchased the plane they would use the money to pay for return transport of the pilot, but would refund completely if the plane did not meet their claims. My mechanic did a pre-buy, and told the pilot that it was nearly unairworthy, and clearly unsafe to fly- basically junk, with a lot of stuff pencil whipped in the logs. It took a while, but after around a month I got my money back after some threatening phone calls and using the lawyer word a few times. We took the same approach to my current Baron, and the seller and his pilot were real gentlemen, as well as honest. The plane has been a gem since then, and a pleasure to fly. It seems there are real extremes- but the bottom line is "caveat emptor" (I think) |
In looking for commiseration among aviation-interested friends locally, I
believe I accidentally scared two of them away for ever owning their own aircraft. Dang, Peter -- you're experience even scared *me* -- and I've been through a couple of rough stretches with maintenance... :-( -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Dang, Peter -- you're experience even scared *me* -- and I've been through a couple of rough stretches with maintenance... Too late to be scared; you are already hooked. ![]() -- Peter |
Thanks for the tips. The motor and drive transistors were all shot. The
motor is tiny compared to what I expected, and even more so considering the expense. The strobe power supply is shot as well. I will check tonight, but if it is the original Grimes, I plan on replacing it with a Whelen. You and Jay saw my wingtip strobe cover that cracked due to hangar rash-$450 (plus $150 for the aftermarket one I purchased from an outfit that promised they were the same as a Bonanza lens, which was incorrect. He never returned any phone calls or email messages either, after the fact) So, after a long stretch of maintenance free flying, I am up to around $3,000. And, my insurance bill just arrived yesterday- but I was anticipating this expense at least. This is beginning to get as expensive as golfing at some posh country club! |
I know where you're coming from.... I swallowed insurance, annual
inspection, and OSH during the same 2 week period. Sorry about the after market lens. The more airplane parts I buy, the easier it is for me to see how each of our flying-mobiles is hand made and hardly anything fits right out of the box, especially after market parts. When after market parts are all that are available or priced significantly less, I try to go into those little adventures with my eyes wide open. Unfortunately sometimes it's our wallets that end up being opened. Jim "Viperdoc" wrote in message ... Thanks for the tips. The motor and drive transistors were all shot. The motor is tiny compared to what I expected, and even more so considering the expense. The strobe power supply is shot as well. I will check tonight, but if it is the original Grimes, I plan on replacing it with a Whelen. You and Jay saw my wingtip strobe cover that cracked due to hangar rash-$450 (plus $150 for the aftermarket one I purchased from an outfit that promised they were the same as a Bonanza lens, which was incorrect. He never returned any phone calls or email messages either, after the fact) So, after a long stretch of maintenance free flying, I am up to around $3,000. And, my insurance bill just arrived yesterday- but I was anticipating this expense at least. This is beginning to get as expensive as golfing at some posh country club! |
Early issues of Wingfoot Lighter-Than-Air Society Bulletin on eBay | laquille | Aviation Marketplace | 0 | July 3rd 06 07:01 PM |
Article: GPS Vehicle Tracking System Issues for the Buyer | Johann Blake | Military Aviation | 0 | January 16th 04 11:26 AM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
Red Baron vs. Rickenbacker? | Gregorso | Military Aviation | 28 | October 13th 03 07:26 PM |
ISO back issues Combat Aircraft magazine | mark e digby | Military Aviation | 0 | August 12th 03 05:39 PM |
