#11
![]() "Mortimer Schnerd, RN" wrote: Two folks flew into instrument conditions and tried to fly back out without success. Aircraft parts are scattered over a one mile radius. How hard do you have to work to break up a 150 in flight? I don't believe I've ever heard of its happening before. Anyone know of another case? -- Dan C-172RG at BFM |
Dan Luke wrote:
"Mortimer Schnerd, RN" wrote: Two folks flew into instrument conditions and tried to fly back out without success. Aircraft parts are scattered over a one mile radius. How hard do you have to work to break up a 150 in flight? I was recently reading the "AOPA Pilot" article about C150 Aerobat aerobatic training. Can any Cessna fans point out the differences between the basic 150/152 & Aerobat versions? Do they have different G restrictions? Or are the Aerobat upgrades mainly pilot escape related, etc... Thanks! |
Dan Luke wrote:
"Mortimer Schnerd, RN" wrote: Two folks flew into instrument conditions and tried to fly back out without success. Aircraft parts are scattered over a one mile radius. How hard do you have to work to break up a 150 in flight? I don't believe I've ever heard of its happening before. Anyone know of another case? I've never heard of one but who knows? In this case, a graveyard spiral until the wings came off? It only takes a few seconds to go from stall speed to redline if you're pointed downhill with the power still on. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
![]() B A R R Y wrote: Dan Luke wrote: I was recently reading the "AOPA Pilot" article about C150 Aerobat aerobatic training. Can any Cessna fans point out the differences between the basic 150/152 & Aerobat versions? Do they have different G restrictions? Or are the Aerobat upgrades mainly pilot escape related, etc... As I recall, there is a bit of horizontal stabilizer reinforcement and not much else. Acrobatic or not, it's hard to imagine it being overly difficult to pull the wings off in a spiral. And not too difficult to get in one in those conditions. |
The Aerobat has much larger struts and wing attach points.
Karl "Maule Driver" wrote in message ... B A R R Y wrote: Dan Luke wrote: I was recently reading the "AOPA Pilot" article about C150 Aerobat aerobatic training. Can any Cessna fans point out the differences between the basic 150/152 & Aerobat versions? Do they have different G restrictions? Or are the Aerobat upgrades mainly pilot escape related, etc... As I recall, there is a bit of horizontal stabilizer reinforcement and not much else. Acrobatic or not, it's hard to imagine it being overly difficult to pull the wings off in a spiral. And not too difficult to get in one in those conditions. |
Thomas Borchert wrote:
Larry, Tragic indeed. Hmm. If indeed it was VFR into IMC and the pilot had obtained his certificate only two months prior, that's not the only word that comes to mind. And I would have some questions for the CFI. Speaking as a CFI who once had a student that she dumped for doing idiotic stuff, it's not always the CFI's fault. |
The 150/152 were certified in the normal/utility category which, as I
recall, carries a G rating of 3.8/4.4 positive and 1.52/1.76 negative. The 150 Aerobat was certified in the aerobatic category which carries a +6 -3 G rating. Jim "Maule Driver" wrote in message ... As I recall, there is a bit of horizontal stabilizer reinforcement and not much else. |
![]() "Maule Driver" wrote in message ... As I recall, there is a bit of horizontal stabilizer reinforcement and not much else. On Wed, 6 Sep 2006 11:37:07 -0700, "RST Engineering" wrote in : The 150/152 were certified in the normal/utility category which, as I recall, carries a G rating of 3.8/4.4 positive and 1.52/1.76 negative. The 150 Aerobat was certified in the aerobatic category which carries a +6 -3 G rating. But, was Vne increased? |
![]() Larry Dighera wrote: "Maule Driver" wrote in message ... As I recall, there is a bit of horizontal stabilizer reinforcement and not much else. On Wed, 6 Sep 2006 11:37:07 -0700, "RST Engineering" wrote in : The 150/152 were certified in the normal/utility category which, as I recall, carries a G rating of 3.8/4.4 positive and 1.52/1.76 negative. The 150 Aerobat was certified in the aerobatic category which carries a +6 -3 G rating. But, was Vne increased? Those limits apply to properly maintained airplanes, not those that have been neglected, abused or otherwise poorly treated. I've seen serious corrosion in 150 wings that would have weakened them; the insides of struts can corrode from condensation; The stabilizer spars can be cracked by pushing down on the tail to swing the nose around during ground handling (though the 172 is more prone to that). A failed stab allows the airplane go instantly go over onto its back and the wings fail downward a la Bonanza or 210. Who knows; maybe there was hardware missing. I once came across a 172 that had no nuts on the lower strut attach bolts, and those bolts were working their way out. There are some real horror stories out there. But I would still suspect loss of control and a hard pull-up when the ground appeared. The usual scenario in the Bonanza/210 crash. Dan |
Must of been scary in that plane.
Britain breaks with the US over Iran | John Dallman | Naval Aviation | 5 | March 23rd 06 02:36 AM |
Steve Fosset -- Breaks record, but loses generator &declares an Emergency | Jay Somerset | Piloting | 1 | February 11th 06 07:13 PM |
(Humor) Tomcat breaks the sound barrier. | [email protected] | Naval Aviation | 3 | August 31st 05 02:28 PM |
Parajumper breaks legs??? | jerry wass | Home Built | 32 | April 29th 05 06:59 AM |
SpaceShipOne Breaks Sound Barrier | Mutts | Piloting | 0 | December 18th 03 01:56 AM |
