GPS AND MAP
Old September 10th 06, 09:25 PM posted to rec.aviation.ifr
Paul
Default GPS AND MAP
Hello ,
Recently I bought a PILATUS PC12 ,with the GPS KLN90B.
Is it possible to exchange the GPS against a GARMIN 500 and a MAP ,
as in standard Aircrafts of FS9.
Thanks in advance
Paul
Old September 10th 06, 11:30 PM posted to rec.aviation.ifr
Jim Macklin
Default GPS AND MAP
Exchanges are the realm of the seller. But any avionics can
be retro-fitted if you have the budget.
"Paul" wrote in message
| Hello ,
and a MAP ,
| Thanks in advance
| Paul
Old September 10th 06, 11:49 PM posted to rec.aviation.ifr
Doug[_1_]
Default GPS AND MAP
Dont discount the KLN90B. It will get you into all the approaches that
the 530 will.
Old September 11th 06, 07:32 PM posted to rec.aviation.ifr
Barney Rubble
Default GPS AND MAP
Yeah, but this guy just bought a PC-12, so money no object, let's have a
couple of 480's....
"Doug" wrote in message
the 530 will.
Old September 11th 06, 10:38 PM posted to rec.aviation.ifr
paul k. sanchez
Default GPS AND MAP
the 530 will.
Really? Including VOR/localizer approaches?
Old September 11th 06, 10:51 PM posted to rec.aviation.ifr
Mark Hansen
Default GPS AND MAP
On 09/11/06 14:38, paul k. sanchez wrote:
the 530 will.
Will the 530 allow you to fly a non-GPS overlay VOR/Loc approach
using the GPS? The 430 doesn't. It says something to the effect
that it can be used as a situational awareness tool only. Same as
the KLN94B, IIRC.
Of course, if the approach has a GPS overlay, then you can fly
the GPS overlay (again, using the GPS) but in that case, you're
not flying the underlying VOR/Loc approach.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old September 12th 06, 03:43 PM posted to rec.aviation.ifr
Frank Ch. Eigler
Default GPS AND MAP
that it can be used as a situational awareness tool only. [...]
That's only for GPS-based navigation. Flip the 430 or 530's CDI
switch to VLOC, tune in the NAV portion, and enjoy the approach.
- FChE
