#11
"Tom Conner" wrote:
"Skylune" wrote in message alkaboutaviation.com... Now that I have again provided the amount of annual funding deriving from GA fuel taxes (including AV GAS and Jet A), compare that to 2005 capital grants to airports by looking at the ACTUAL 2005 DATA below. (Note that these figures DO NOT include the $150K annual operating subsidy that many GA airports receive.) DAMN: the subsidies are enormous, as every informed person knows.... http://www.faa.gov/airports_airtraff...rants_2005.pdf What are the definitions for the acronyms in the "Service Level" column? The local GA airports that received grants are listed as "R" in this column. R is probably "reliever" which is the status of my airport. Ron Lee |
DAMN: the subsidies are enormous, as every informed person knows.... If this is the basis of your information, then every MIS-informed person knows.... http://www.faa.gov/airports_airtraff...rants_2005.pdf |
Now, I am assuming the majority of pilots can do simple addition.
Conservatively, take the grants that are clearly for GA airports only, and compare that to the number (about $180mm) in combined AVgas and Jet A gas tax receipts. Then, tell me the GA is not subsidized. Tell me the Bureau of Transportation statistics is wrong about GA being subsidized (in that case, maybe AMTRAK isn't subsidized either). Or, try and change the topic to economic benefits (I can argue that too: those studies are rigged), supposed national benefits (true only for remote areas of the country), etc. Better yet, quote the Destroyer, who laughingly claims that the Highway trust fund is "going broke" (completely false, as fed gas taxes exceed amount of outlays, even with all the pork in the ground transportation projects) while the AV trust fund is doing well. |
![]() "Steve Foley" wrote in message news:ivBOg.7$_k1.3@trndny01... Why is Westover Airforce Base listed as GA? Westover Air Reserve Base, aka Westover Metropolitan Airport, hasn't been an Air Force Base since 1974. |
![]() "Ron Lee" wrote in message ... R is probably "reliever" which is the status of my airport. And what does a "reliever" provide relief for? |
Yes. Be conservative. Add up only the grants to airports listed as GA
(knowing that R and P categories also use GA, sometimes exclusively GA), then compare to the amount of AV gas taxes. Guess which number is MUCH larger. (Of course the grants to large passenger airports like O'Hare is large -- don't include those numbers). |
![]() "Skylune" wrote in message lkaboutaviation.com... Now, I am assuming the majority of pilots can do simple addition. Conservatively, take the grants that are clearly for GA airports only, and compare that to the number (about $180mm) in combined AVgas and Jet A gas tax receipts. But it isn't clear what grants are for GA airports only. |
![]() "Skylune" wrote in message lkaboutaviation.com... Yes. Be conservative. Add up only the grants to airports listed as GA But some of those have air carrier service. (knowing that R and P categories also use GA, sometimes exclusively GA), then compare to the amount of AV gas taxes. What are the R and P categories? |
compare that to the number (about $180mm) in combined AVgas and Jet A gas tax receipts. There's your fallacy. One should not take "grants that are clearly for GA airports only" but "grants that are clearly for GA only". There's a difference. Or, take "grants that do not benefit the airlines". Jose -- There are more ways to skin a cat than there are cats. for Email, make the obvious change in the address. |
No amount of actual data or reasoning will ever convince private pilots
that the paltry couple of hundred million dollars generated by AV gas taxes per year doesn't cover the cost of the grants and FAA services absorbed by GA. For a group that likes to consider itself technical and scientific-minded, this is astonishing. (Well, actually not, based on the other nonsense put out by some GA groups on safety, cost, convenience, etc.) |
The MYTT (Massive Yet Tiny) Engine | Harbin | Home Built | 19 | June 4th 06 07:06 PM |
fuel subsidies for Angle Flight pilots | sashley | Piloting | 17 | September 11th 05 09:25 AM |
Spark plug question: Massive electrode or fine wire? | Peter R. | Owning | 9 | February 4th 05 02:03 AM |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
Massive Israeli Flyover, Possible Trouble Nov 21 | robert arndt | Military Aviation | 8 | November 20th 03 04:05 AM |
