ATP wants a single engine add on
Old September 19th 06, 03:40 AM posted to rec.aviation.piloting
Emily[_1_]
Default ATP wants a single engine add on
Sylvain wrote:
Emily wrote:
I'm guessing that when he got his ATP, he should have surrendered his
commercial but didn't for some reason.
one pretty good reason not to surrender a certificate when you upgrade
it, is if said certificate has a rating which you do not want to give
up and which is not covered by the new certificate.
Yes, but he had a commercial multi limited to centerline thrust and got
an unrestricted ATP multi. That doesn't make any sense. Why keep a
centerline thrust restriction?
Old September 19th 06, 04:06 AM posted to rec.aviation.piloting
Robert M. Gary
Emily wrote:
Jim Macklin wrote:
He's opted out (or he's lying about being a pilot, but I've seen him
walk off a commercial jet in uniform and with ID, so I'm guessing he's
opted out).
I've also run into situations where the pilot has a very unfortunate
first name. I had a student once who's first name turned out to be
Sherly, he went by "John".
However, I believe (I need to double check) that you'll need to verify
his passport before training per TSA.
-Robert
Old September 19th 06, 04:26 AM posted to rec.aviation.piloting
Jim Macklin
61.31 plus 61.39
c) A person is not required to comply with the provisions of
paragraph (a)(6) of this section if that person:
(1) Holds a foreign-pilot license issued by a contracting
State to the Convention on International Civil Aviation that
authorizes at least the pilot privileges of the airman
certificate sought;
(2) Is applying for a type rating only, or a class rating
with an associated type rating; or
(3) Is applying for an airline transport pilot certificate
or an additional rating to an airline transport pilot
certificate in an aircraft that does not require an aircraft
type rating practical test.
(d) If all increments of the practical test for a
certificate or rating are not completed on one date, all
remaining increments of the test must be satisfactorily
completed not more than 60 calendar days after the date on
which the applicant began the test.
(e) If all increments of the practical test for a
certificate or a rating are not satisfactorily completed
within 60 calendar days after the date on which the
applicant began the test, the applicant must retake the
entire practical test, including those increments
satisfactorily completed.
[Doc. No. 25910, 62 FR 16298, Apr. 4, 1997; Amdt. 61-103, 62
FR 40897, July 30, 1997, as amended by Amdt. 61-104, 63 FR
20286, Apr. 23, 1998]
ande 61.63.
To add a SEL or SES rating as an ATP is much easier.
"Emily" wrote in message
| Jim Macklin wrote:
| The CLT multi-commercial should have been surrendered,
do
| they both have the same number and name. Have you
checked
| on the FAA web site for his official ratings?
I've seen him
guessing he's
| opted out).
surrendered his
| commercial but didn't for some reason. I have a feeling
it has to do
| with his military experience.
| So let me get this straight, if he adds on to the
commercial (which I
| don't think he can do, since he shouldn't have one) it
requires the
| training and signoffs, but if he adds on to the ATP, it
doesn't? Can
| you point in me in the right direction for added on ATP
ratings?
Old September 19th 06, 04:35 AM posted to rec.aviation.piloting
Emily[_1_]
So per this, he doesn't have to do a practical test. What DOES he have
to do?
You know, I'm doing this the wrong way. HE should be figuring this out.
Old September 19th 06, 05:06 AM posted to rec.aviation.piloting
Jose[_1_]
Well, yes, but you have to know too.
Jose
There are more ways to skin a cat than there are cats.
Old September 19th 06, 06:07 AM posted to rec.aviation.piloting
Jim Macklin
He doesn't need a written test or a sign-off from a CFI, but
he must pass the practical [flight test}] for an ATP.
certificate
aircraft
DOES he have
| to do?
figuring this out.
Old September 19th 06, 06:22 AM posted to rec.aviation.piloting
Jim Macklin
You have to read all of the regulations, I just posted the
one section that allows skipping some of the paperwork on an
additional rating.
"Jim Macklin" wrote
in message news:%rJPg.23058$SZ3.20912@dukeread04...
| 61.31 plus 61.39
of
that
| certificate sought;
aircraft
62
| ande 61.63.
| do
| checked
| I've seen him
| guessing he's
|| opted out).
| surrendered his
| it has to do
| commercial (which I
| requires the
| doesn't? Can
| ratings?
Old September 19th 06, 12:35 PM posted to rec.aviation.piloting
B A R R Y[_1_]
Emily wrote:
Jim Macklin wrote:
The CLT multi-commercial should have been surrendered, do they both
have the same number and name. Have you checked on the FAA web site
opted out).
Maybe he's a flight attendant? Remember "The Simpsons"? G
FWIW, certificates are public information and very easy to check via the
FAA web site.
Old September 19th 06, 12:43 PM posted to rec.aviation.piloting
Allen[_1_]
From what I have seen the ratings are all on one card. My ATP is for
multi-engine and it says on it "commercial privileges - SEL". When I
received my new card in the mail my old commercial card that I had
surrendered was with it also. The FAA thought I might like it back since it
was an original issue and I had been packing it for 18 years. They did
punch a hole in it though.
Allen
Old September 19th 06, 01:34 PM posted to rec.aviation.piloting
Emily[_1_]
opted out).
FAA web site.
You can opt out of the database. I didn't realize people didn't know that.
Looking to rent/share a six-seat single engine in NYC area [email protected] Owning 0 February 8th 05 01:01 PM
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 07:13 PM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
