#11
There has got to be a MSFS usegroup that you can ask these questions on.
Not all MSFS aircraft react the same as a real airplane and most any real airplane will drop the nose without aft stick pressure when rolled into a turn. BT "Mxsmanic" wrote in message ... After constantly struggling with a heavy nose in several aircraft it occurred to me that having a fat pilot in front and nothing else was moving the CG forward. I put some weight in back and moved the CG further back over the wings, and handling improved greatly. Is there a way (other than consulting a manual each time) to determine exactly where over the wing is the best place for the CG? MSFS is kind enough to show me a diagram with the current CG marked, but I don't know how far back I should try to place it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
... Steve Foley writes: NO. Pilots must calculate weight and balance prior to each flight. And they all do this methodically? I'm not sure what you mean by methodically. There is a specific method used to calculate W&B, so they should be using the prescribed method. If you mean do they always do this, I can only speak for myself. I have a pre-calculated one for myself with full fuel, myself with fuel to tabs (partial tanks) and myself and a 170lb person in the front right seat, both with full fuel and tabs. Anything else I need to recalculate. |
Mxsmanic,
And they all do this methodically? Those that you don't find in your mile-high piles of accident reports, yes. -- Thomas Borchert (EDDH) |
... After constantly struggling with a heavy nose in several aircraft it occurred to me that having a fat pilot in front and nothing else was moving the CG forward. I put some weight in back and moved the CG further back over the wings, and handling improved greatly. Is there a way (other than consulting a manual each time) to determine exactly where over the wing is the best place for the CG? MSFS is kind enough to show me a diagram with the current CG marked, but I don't know how far back I should try to place it. The best place for the CG along the ROLL axis is somewhere near the middle. Moving weight from front to back won't make a difference in this case. In real life, you do have to consult the manual and do the math if you are flying with a load you haven't already calculated to get the CG in range from front to back. Also, in real life there is a difference between having the CG too far forward and not using the trim properly. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
"Steve Foley" wrote in news:R4xRg.213422
: "Judah" wrote in message . .. Mxsmanic wrote in : Does MSFS let you set the weight of the pilot? That's kinda neat. I wish I could do the same in real life! The FAA says I weight 170 lbs. Who am I to argue? I think I remember when I weighed 170lbs. I was in 7th grade. |
Mxsmanic wrote in
: One thing I wonder is this: If I'm alone in the aircraft, in the left seat at the front, can I put an counterbalancing weight in the rear seat on the right, or would putting weight in a diagonally opposed position make the aircraft unstable? If it works, it would be easier to balance things; I could throw some sandbags in the right rear corner of the aircraft to balance my weight. It's not unheard of for a pilot to counterbalance weight in the plane if necessary, especially in some models that are noseheavy, let's say because of a three-blade prop. CG refers to forward/aft. I don't believe that weight & balance for left & right side of a plane is of major concern, even on the big planes... This is all basic flight training stuff. I would recommend the book "Stick and Rudder" as a good starting place. I looked for it at the pilot's store Thursday, but I couldn't find it. It's hard to find English specialty books here. You can probably find it on EBay or half.com... |
alt.games.microsoft.flight-sim
He's already over there. Mxsmanic, ask these questions over there. I guarantee you'll get the answers you're looking for over there. Crash Lander -- I'm not always right, But I'm never wrong! "BTIZ" wrote in message news:JgzRg.962$xI4.75@fed1read11... There has got to be a MSFS usegroup that you can ask these questions on. Not all MSFS aircraft react the same as a real airplane and most any real airplane will drop the nose without aft stick pressure when rolled into a turn. BT "Mxsmanic" wrote in message ... After constantly struggling with a heavy nose in several aircraft it occurred to me that having a fat pilot in front and nothing else was moving the CG forward. I put some weight in back and moved the CG further back over the wings, and handling improved greatly. Is there a way (other than consulting a manual each time) to determine exactly where over the wing is the best place for the CG? MSFS is kind enough to show me a diagram with the current CG marked, but I don't know how far back I should try to place it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Using the roll axis to define CG location is not the classical way it
is done, however when weight is added up front or in back, it does move the CG along the roll axis, since the axis about which the aircraft rolls runs generally from nose to tail. The classic way is to state the CG is at a location along the MAC (mean aerodynamic chord), usually stated as percent of MAC. Bud Capt. Geoffrey Thorpe wrote: "Mxsmanic" wrote in message ... After constantly struggling with a heavy nose in several aircraft it occurred to me that having a fat pilot in front and nothing else was moving the CG forward. I put some weight in back and moved the CG further back over the wings, and handling improved greatly. Is there a way (other than consulting a manual each time) to determine exactly where over the wing is the best place for the CG? MSFS is kind enough to show me a diagram with the current CG marked, but I don't know how far back I should try to place it. The best place for the CG along the ROLL axis is somewhere near the middle. Moving weight from front to back won't make a difference in this case. In real life, you do have to consult the manual and do the math if you are flying with a load you haven't already calculated to get the CG in range from front to back. Also, in real life there is a difference between having the CG too far forward and not using the trim properly. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Steve Foley writes:
If you mean do they always do this, I can only speak for myself. I have a pre-calculated one for myself with full fuel, myself with fuel to tabs (partial tanks) and myself and a 170lb person in the front right seat, both with full fuel and tabs. Anything else I need to recalculate. So if someone tosses a bag in the back, or if the person next to you weighs more or less than 170 lbs, you redo the calculations? -- Transpose mxsmanic and gmail to reach me by e-mail. |
BTIZ writes:
and most any real airplane will drop the nose without aft stick pressure when rolled into a turn. I don't recall mentioning turns. -- Transpose mxsmanic and gmail to reach me by e-mail. |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
