Fine scratches on wing gel coat
Old October 3rd 06, 10:39 PM posted to rec.aviation.soaring
Default Fine scratches on wing gel coat
Jack wrote:
Tim Mara wrote:
absolutely NOT........RainX causes rain to form tiny droplets which are then
blown off by wind......you want no droplets at all...ever..
tim
"Jack" wrote in message
et...
Bob Caldwell wrote:
The bigger issue is with flying in rain. The highly polished, waxed
finish will bead up with water droplets. The rougher surface will
shed water without forming the really draggy (is that a word?)
droplets. Same as if you waxed your windshield in your car, water
beads up instead of sheeting off. So if and when you have to blast
through that virga line the drop in performance will not be as
severe.
So, should we be using RainEx on our wings?
But many do wax the wings -- and so get BIG drops -- do they not.
Is the only answer to stay out of the rain and/or simply clean your
wings with pure water, but never apply any protective finish?
Jack
Re Wax- Some airfoils don't want to be polished and waxed. The Wortman
FX 67-150/170 series is an example of this. These like a little(400grit
at 45 degrees) roughness. When my PIK climb started to drop off, I'd
give it a bit of a scuff. I washed with dish soap and wiped dry
without a lot of rinsing. Soap wetted out rain and it tolarated rain
much better. Otherwise, when the rain drop hits the canopy- put the
gear down.
hard to keep looking nice when doing this though.
UH
Old October 4th 06, 08:28 PM posted to rec.aviation.soaring
Hank's experience echoes mine. I kept my LS-3 (same airfoil as PIK-20B;
also Mosquito, Nimbus 2, etc.) at 400 grit most of the time and it did
seem to make a difference in the rain. Keeping it clean was no problem.
Water worked for most things. And for stubborn bugs, just sand them
off.
Chip Bearden
ASW 24 "JB"
Osan’s 51st Fighter Wing to get its own coin Otis Willie Military Aviation 0 April 5th 04 10:44 PM
Announcing THE book on airshow flying Dudley Henriques Piloting 11 January 9th 04 07:33 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
