#11
On Thu, 28 Sep 2006 22:50:58 +0200, Wolfgang Schwanke
wrote: Mxsmanic wrote in : Where on the Web can I learn more about flying traffic patterns? wikipedia is often a good start: http://en.wikipedia.org/wiki/Airfield_traffic_pattern Are these patterns of a standard size, or do they vary from one airport to another? (This is from a European perspective) There's a "default" pattern which is rectangular, and whose lengths are defined by the runway length and the fact that crosswind & base are supposed to be 1 NM long. Everything else is deduced from there. Here in the states my cross wind varies from about a city block to nearly a mile depending on what I'm flying and how bad I want to scare my passengers. Most airports have published pattern map though which every pilot is supposed to read before landing there. Often only one of two possible patterns is defined, or motor and glider traffic have separate ones. The height is defined, but the speed of the aircraft will determine how large the pattern. A light jet is going to make a one mile base seem pretty short. When I do a circle to land in the Deb holding one mile takes a lot of power and it's a pretty steep turn at low altitude. Generally passengers do not like that sort of landing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Stubby writes:
All you question will be answered if you buy a copy of FAR/AIM. "Federal Aviation Regulations / Airman's Information Manual" Thanks. I found something call the Aeronautical Information Manual, which looks like it might be the same thing (?). I had previously downloaded the Pilot's Handbook of Aeronautical Knowledge, but it didn't seem to cover these things. I have the Instrument Flying Handbook, also, although I assumed that the patterns under discussion here were specific to VFR (?). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Sylvain writes:
well, at least as far as things happen on this side of the pond, you'll find plenty to read he Pilot's Handbook of Aeronautical Knowledge FAA-H-8083-25 Revised 2003; http://www.faa.gov/library/manuals/a...ilot_handbook/ I have this one. Airplane Flying Handbook FAA-H-8083-3 Revised 1999; http://www.faa.gov/library/manuals/a...lane_handbook/ Found it, thanks. I try to find the PDF versions and download those, as they are easier and more convenient to read. I already had found the Pilot's Handbook and an Instrument Flying Handbook, but I tend to get them all confused. I've seen hard copy of one or two books in the pilot shop I've visited, but that's too expensive. The PDFs appear to contain exactly the same thing, for free. And there is plenty more where it comes from; for instance I understand that you are a simmer, so may be would you also be interested in reading a bit about instrument flying as well: Instrument Flying Handbook FAA-H-8083-15 Revised 2001; http://www.faa.gov/library/manuals/a...ying_handbook/ I have that one. Instrument Procedures Handbook FAA-H-8261-1 Revised 2004; http://www.faa.gov/library/manuals/a...ures_handbook/ Downloading that one now. And finally, lots of goodies to be found in the regulations (you might want to start with Chapters 1, 61 and 91 of the regulations, and read pretty much everything in the AIM): 2005 14 CFR (FAR) and AIM; http://www.faa.gov/ATpubs/AIM/ http://www.faa.gov/regulations_polic...a_regulations/ I've read some of this before, but not in depth. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Wolfgang Schwanke writes:
Most airports have published pattern map though which every pilot is supposed to read before landing there. Which documents are these? I looked at airnav.com, but I see only departure and arrival plates that do not appear to mention patterns. See and avoid, gazing out the window; the fact that everyone is supposed to be somewhere in the pattern helps you, because you know where to look for other planes at all. If airplanes were to be expected at any altitude or direction, it would be complete chaos and risk of collisions would rise; the pattern rule helps to avoid this. Calling out one's own position on the airfield's published frequency in regular intervals, and listening to other pilot's position reports also helps. Speed differences aren't really that bad. I have a hard time finding other traffic in the sim; I hope it is easier in real life. Of course, turning one's head doesn't work very well in simulation (PC simulation), but even when I look out the side windows I don't always see the traffic where ATC tells me to look for it. In theory you're supposed to enter/leave the pattern into/out of the downwind leg (the 45 degree rule mentioned on wikipedia is a US specific thing AFAIK). In practice pilots often do only the crosswind or base, and sometimes they even do a straight in landing (which is considered impolite when there are other pilots in the pattern; but when there's nobody around what the heck ..). So what prevents planes from colliding with each other when they are circling the airport so that they can enter the pattern at the right spot? Traditionally I've been aligning with the assigned runway from quite a distance away, so that I'm already coming straight in by the time I'm close to the airport. If I have to enter a complicated pattern each time I approach, it's going to make things a lot more difficult. The sim's ATC always approves me for a straight-in approach, but perhaps that is because I prefer to use ILS approaches. I've gotten instructions for "right downwind" and stuff like that occasionally, but I haven't paid much attention to them up to now ("now" meaning since I've bought a joystick). Full patterns are normally only flown when training take-offs and landings. If I had a big airport nearby I'd look for them. The airports here are way outside town, however. A single nautical mile seems really short for the legs if there are jets in the pattern. Even a tiny plane could cover that in less than 30 seconds. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Roger (K8RI) writes:
Here in the states my cross wind varies from about a city block to nearly a mile depending on what I'm flying and how bad I want to scare my passengers. Doesn't everyone in the pattern have to fly legs of the same length? A light jet is going to make a one mile base seem pretty short. If the jet flies longer legs than you do, doesn't that mean that you have traffic merging into your path at several points in the pattern, particularly on final? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Stubby wrote:
All you question will be answered if you buy a copy of FAR/AIM. "Federal Aviation Regulations / Airman's Information Manual" In other words, READ THE ****IN' MANUAL !!! |
Mxsmanic wrote:
If the jet flies longer legs than you do, doesn't that mean that you have traffic merging into your path at several points in the pattern, particularly on final? that's the fun of it :-) it all boils down to see and avoid; I have flown in an uncontrolled field with two crossing runways, often used simultaneously (well, not quite simultaneously but close) where everything operates from gliders to jets, warbirds, ultralights, sky divers, you name it. It never gets boring :-) --Sylvain |
Sylvain writes:
that's the fun of it :-) it all boils down to see and avoid ... I don't know that I'd consider avoiding an accident fun; but I suppose it prevents one from dozing off. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Recently, Mxsmanic posted:
Roger (K8RI) writes: Here in the states my cross wind varies from about a city block to nearly a mile depending on what I'm flying and how bad I want to scare my passengers. Doesn't everyone in the pattern have to fly legs of the same length? No. A light jet is going to make a one mile base seem pretty short. If the jet flies longer legs than you do, doesn't that mean that you have traffic merging into your path at several points in the pattern, particularly on final? No. Neil |
T o d d P a t t i s t writes:
It is, but not a lot easier until you get closer. But getting closer is a Bad Thing, isn't it? This made me think of something else: How many pilots carry binoculars with them in the cockpit? Seems like they might be useful in some circumstances, although obviously flying with one hand on the yoke and another on the binoculars might not always be practical. It would ease looking for traffic, and would make it easier to identify landmarks below from a greater distance for VFR flight. Patterns are defined only loosely. Different speeds are used by different aircraft or the same aircraft at different times. Turn locations, turn rate, distance of the legs from the runway all vary by aircraft and from time to time. The general idea for non-towered airports is to let the aircraft space themselves and be able to merge together safely. A pattern is not even technically required, but most pilots fly one. I guess you can space from traffic in front of you or on either side, but what about traffic behind you? It seems that aircraft have rather large blind spots as visibility goes. Also, if you're a big jet and you have a tiny prop aircraft in front of you, what if you can't slow down enough to avoid overtaking him? Altitude of the pattern, which may be different for high speed aircraft or jets. Direction of turns - left or right. Sometimes there are published noise abatement procedures, wind speed/direction or runway slope comments that affect the direction or positioning of the pattern. Does noise abatement apply to everyone, or just jets? (I think I asked this elsewhere, but I don't recall seeing a reply.) This stuff is in the airport facility directory. Places like airnav.com and landings.com also have this info. Can I download the airport directory in PDF? -- Transpose mxsmanic and gmail to reach me by e-mail. |
| Thread Tools | |
| Display Modes | |
| The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 02:15 AM |
| Flying on the Cheap - Instruments | [email protected] | Home Built | 24 | February 27th 06 03:30 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 02:54 AM |
| Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 09:48 PM |
