cost to install engine analyzer (4 cyl)?
Old September 30th 06, 04:34 PM posted to rec.aviation.owning
houstondan
Default cost to install engine analyzer (4 cyl)?
care to expand on that a bit??
dan
Denny wrote:
On a low compression, low horsepower, carbureted engine, a fancy
analyzer is only going to waste your money and make you frustrated...
denny
Old September 30th 06, 07:58 PM posted to rec.aviation.owning
Guy Byars
If you are planning to use it to lean more agressively on a carburated
engine, then I agree, it will not work well for that. I put an EDM-700 on
my Skylane with an O-470R. I still find the best leaning procedure is to
lean until the engine is slightly rough, then richen it up 1/4 turn.
However, an analyizer is a great diagnostic tool. For example, if on runup
you notice one mag is slightly rough, a quick look at the analyzer help you
diagnose the problem. For example, if a single cylinder is not firing, the
analyzer will tell you EXACTLY which cylinder has the bad plug. Or if all
the cylinders are sick on one mag, then the analyizer will clearly show that
too. Also, earlier this year, I had a manifold leak, and saw that the
1-3-5 cylinders were a bit "off". So an inspection of that side of the
engine found a manifold leak.
Guy
"Denny" wrote in message
denny
Old October 2nd 06, 12:29 AM posted to rec.aviation.owning
Ray Andraka
denny
I disagree. It'll pay for itself the first time your engine hiccups.
Mine paid for itself within the first 20 hours it was installed. I had
a situation (new engine) where the engine would get rough at the top of
the climb as soon as you pulled the throttle back. The engine monitor
showed that the #1 cylinder was going cold when that happened, which
pointed exactly where to look for the problem.
A year later, I had one cylinder that was suddenly getting lean too
quickly. The monitor told me exaclty where to look for an intake leak,
which was found within 10 minutes of pulling off the cowl.
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
