Anyone have a good reason why I shouldn't use 1/4" plumbing line
(fridge water line) for fuel lines? It seems to have great connectors. Also holds a lot more pressure than I'll be needing. Anyone use this yet? Lou |
In article .com,
"Lou" wrote: Anyone have a good reason why I shouldn't use 1/4" plumbing line (fridge water line) for fuel lines? It seems to have great connectors. Also holds a lot more pressure than I'll be needing. Anyone use this yet? Lou What size engine? Quarter inch line gives you a very limited fuel flow and can starve engines of more than 50 horses. Also, it is more susceptible to vapor lock than larger diameter lines. The normal size for GA fuel lines (up to 300 HP) is 3/8 inch. |
Well that certainly does help. I'll be using a Corvair conversion.
Lou |
![]() Lou wrote: Anyone have a good reason why I shouldn't use 1/4" plumbing line (fridge water line) for fuel lines? It seems to have great connectors. Also holds a lot more pressure than I'll be needing. Anyone use this yet? Lou If there would be any one part of an aircraft that I would build that should adhere to strict aviation practices, it would be the fuel system, especially the fuel line and it's fittings. My two cents. Neal |
Lou wrote:
Anyone have a good reason why I shouldn't use 1/4" plumbing line (fridge water line) for fuel lines? It seems to have great connectors. Also holds a lot more pressure than I'll be needing. Anyone use this yet? Lou NO!--even autos use 5/16" line---But I think You're talking PLASTIC-(spitooie)---- use a #-6 Stainless steel Teflon lined hose from firewall fwd.--& slip firesleeve over that!----my 4¢ worth. Jerry |
![]() On Sun, 01 Oct 2006 13:47:02 GMT, jerry wass wrote: NO!--even autos use 5/16" line---But I think You're talking PLASTIC-(spitooie)---- use a #-6 Stainless steel Teflon lined hose from firewall fwd.--& slip firesleeve over that!----my 4¢ worth. Jerry -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Speaking of AUTOS, Jerry.... Over 3 years ago, didn't you promise an auto conversion that was going to put out 10 gazillion horsepower utilizing a mere pocketful of cc's coupled to a miracle camshaft? Since Lycoming is still in business, what gives? ![]() - Barnyard BOb - |
![]() Lou wrote: Anyone have a good reason why I shouldn't use 1/4" plumbing line (fridge water line) for fuel lines? It seems to have great connectors. Also holds a lot more pressure than I'll be needing. Anyone use this yet? Lou Answer: Go to http://www.ntsb.gov and search homebuilt accidents and see how many are related to fuel issues. I have been on several accidents with fuel problems. Having 1/4 ID can be a problem because of flow and not pressure. Flow is what a engine requires and haveing 5/16 or 3/8 is a better option. The same goes for the vent lines. The more bends and connections causes flow reductions and having hight pressue will not solve this problem. Stache |
![]() Answer: Go to http://www.ntsb.gov and search homebuilt accidents and see how many are related to fuel issues. I have been on several accidents with fuel problems. Having 1/4 ID can be a problem because of flow and not pressure. Flow is what a engine requires and haveing 5/16 or 3/8 is a better option. The same goes for the vent lines. The more bends and connections causes flow reductions and having hight pressue will not solve this problem. Stache Thanks, I was considering 3/8" anyway but I thought it would be a good idea to ask. Also, I was going to go with aluminum. It's lightweight, flexable, and should be easy to get the connections. Lou |
I just started thinking about the fuel system for my project. I knew it was
3/8" but in what alloy? "Lou" wrote in message ups.com... Answer: Go to http://www.ntsb.gov and search homebuilt accidents and see how many are related to fuel issues. I have been on several accidents with fuel problems. Having 1/4 ID can be a problem because of flow and not pressure. Flow is what a engine requires and haveing 5/16 or 3/8 is a better option. The same goes for the vent lines. The more bends and connections causes flow reductions and having hight pressue will not solve this problem. Stache Thanks, I was considering 3/8" anyway but I thought it would be a good idea to ask. Also, I was going to go with aluminum. It's lightweight, flexable, and should be easy to get the connections. Lou |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Hurricane relief | Dave Stadt | Piloting | 94 | September 8th 05 07:02 PM |
"Out of fuel, out of hope: 'Help, I'm in the water'" | [email protected] | Piloting | 145 | May 3rd 05 11:21 PM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
