90% of the planes in the air have under-inflated tires. Seems to be
systemic. That's because 90% of all GA aircraft are stuck with stupid, 1930s-technology inner tubes. Of all the dumb things in aviation, that seems to be one of the dumbest. Mary and I fill our tires every 14 days, and it's a pain in the butt. If I had a tire like that on my car, it would be classified as a "slow leak" and be repaired or replaced. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
"Jay Honeck" wrote: Of all the dumb things in aviation, that seems to be one of the dumbest. Mary and I fill our tires every 14 days, and it's a pain in the butt. Be thankful that you have a hangar where you can do that work. For those of us on a tie-down, it's even more of a pain. -- Bob Noel Looking for a sig the lawyers will hate |
A Lieberma wrote: Bob Noel wrote in news:ihatessppaamm- : Be thankful that you have a hangar where you can do that work. For those of us on a tie-down, it's even more of a pain. Good quality bicycle tire pump makes short order of this "chore" and I am in a tie-down area. well, one neat thing about a hangar is that checking the tire pressure is a fine rainy day activity. And it's generally out of the wind. Plus, for folks like Jay whose airplane has wheel pants, r/r of the pants (wheel pants that is) is easier in a hangar than on the flight line. -- Bob Noel Looking for a sig the lawyers will hate |
![]() Jay Honeck wrote: Mary and I fill our tires every 14 days, and it's a pain in the butt. I over inflate 5 psi. Just to streatch things out to a month. Getting under the wing and taking off that little hub cap, yech. John |
The Visitor wrote in
: Jay Honeck wrote: Mary and I fill our tires every 14 days, and it's a pain in the butt. I over inflate 5 psi. Just to streatch things out to a month. Getting under the wing and taking off that little hub cap, yech. John Has anyone tried the Sporty's hub caps which have the little door to permit you to check the pressure and/or add air without removing them? -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
On Wed, 04 Oct 2006 19:43:01 GMT, Marty Shapiro
wrote: The Visitor wrote in : Jay Honeck wrote: Mary and I fill our tires every 14 days, and it's a pain in the butt. I over inflate 5 psi. Just to streatch things out to a month. Getting under the wing and taking off that little hub cap, yech. John Has anyone tried the Sporty's hub caps which have the little door to permit you to check the pressure and/or add air without removing them? I keep asking...Why go to all this extra work when for the same or less money and effort you can replace the old leaky ones with good innertubes? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Marty Shapiro wrote: Has anyone tried the Sporty's hub caps which have the little door to permit you to check the pressure and/or add air without removing them? I had them on my 182 and now have them on my Bo. Makes the gear looker neater. |
On 3 Oct 2006 21:16:37 -0700, "Jay Honeck" wrote:
90% of the planes in the air have under-inflated tires. Seems to be systemic. That's because 90% of all GA aircraft are stuck with stupid, 1930s-technology inner tubes. Of all the dumb things in aviation, that seems to be one of the dumbest. Mary and I fill our tires every 14 days, and it's a pain in the butt. As I've said before, spend the money for the new "low leak" innertubes. They are well worth the money and the time to install. If I had a tire like that on my car, it would be classified as a "slow leak" and be repaired or replaced. You can do the same with the ones on the airplane albeit the tubes are a bit more than the ones for cars. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger (K8RI)" wrote in message ... On 3 Oct 2006 21:16:37 -0700, "Jay Honeck" wrote: 90% of the planes in the air have under-inflated tires. Seems to be systemic. That's because 90% of all GA aircraft are stuck with stupid, 1930s-technology inner tubes. Of all the dumb things in aviation, that seems to be one of the dumbest. Mary and I fill our tires every 14 days, and it's a pain in the butt. As I've said before, spend the money for the new "low leak" innertubes. They are well worth the money and the time to install. I have them and they are a vast improvement and they came free (that's what the ad said anyway) with the tires from Desser. If I had a tire like that on my car, it would be classified as a "slow leak" and be repaired or replaced. You can do the same with the ones on the airplane albeit the tubes are a bit more than the ones for cars. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
Why are TE probes so long? | Duane Eisenbeiss | Soaring | 36 | May 9th 04 06:58 AM |
Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 07:56 AM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
