Customizing Sectionals
Old October 8th 06, 03:01 PM posted to rec.aviation.soaring
Default Customizing Sectionals
I had to edit the comments manually so the freqs, headings and runway
dimensions would all display in GNII.
One "problem" I've noted with SeeYou is that it sometimes offers to
delete nearby waypoints even when there really are two points you may
want to keep; e.g., two airports within a mile or so, or two different
sets of coordinates for the same airport caused by the FAA and
organizers' data being slightly different. That's another reason why I
went the Excel/text editor route. I assumed it was better (i.e,. easier
for me) to edit externally and then use SeeYou to export/upload in the
proper format.
Chip Bearden
ASW 24 "JB"
Old October 9th 06, 08:40 AM posted to rec.aviation.soaring
Matt Herron Jr.
I purchased a copy of Global Mapper, and as an experiment, I am
offering custom made charts for licensed customers of GlidePlan. Just
send me an email from this page:
(http://www.glideplan.com/download/Experimental.html). Resulting maps
will be posted for download at the above link. In this way, hopefully
we can get around the limitations of single sectional flight planning.
As a first example, I have included a map that covers the area from
CedarVille down to Bakersfield CA, and Sacramento East to Tonopah,
which will account for most of the reachable destinations out of the
Reno area.
Old October 9th 06, 03:42 PM posted to rec.aviation.soaring
Paul Remde
Hi Eric,
You are correct of course. The radio frequency data was not exported -
which is a bummer. I requested that SeeYou add the ability to select what
data is put into the export file's comment field but no luck so far. The
data is in SeeYou. I believe it is possible to get the radio frequency into
the file using some creative column copying in Excel, but I haven't tried it
yet.
Even so, it is very easy to create a waypoint file for any area of the USA
with very current airport data using SeeYou or StrePla.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
news:W90Wg.1696$WD1.1000@trndny04...
Eric Greenwell wrote:
Doug Haluza wrote:
John Liebacher has made the FAA airport database available at:
http://soaring.aerobatics.ws/TP/FAA
If you have SeeYou, you can load this database, then overlay your
turnpoints, and reject nearby duplicates. This will update the airport
data in your exiting turnpoint database, plus give you landout airports
for the whole country. You can then trim this down as much as you like.
You may not need SeeYou, as John may have a version for GNII. The SeeYou
version does include the frequencies, runway width, fuel availability
(for motorgliders, of course). Some formats have smaller
comment/description fields and may not have all info.
I just tried exporting to a Cambridge DAT format, and the radio
frequencies are not exported, though the runway width and fuel show up in
the comments field.
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
Old October 9th 06, 11:54 PM posted to rec.aviation.soaring
Andy[_1_]
Paul Remde wrote:
Hi,
If you open the SeeYou version or the US Airport Database in SeeYou, or the
StrePla version in StrePla, you can then export waypoint files for use in
Glide Navigator II or transfer waypoints to a Garmin (I think). I create
Glide Navigator II files using SeeYou often. It works great.
I don't have StrePla or SeeYou.
Sectionals Simulators 1 July 21st 06 12:45 AM
Purchased sectionals i dont need ( do you need them?) Troy Towner Aviation Marketplace 0 June 12th 04 10:20 PM
class C and B comms on sectionals? Magnus Piloting 31 April 27th 04 09:49 PM
AVIATIONTOOLBOX: Christmas sectionals are here and rsync-able. Kyler Laird General Aviation 4 January 1st 04 05:11 AM
Old Iowa City Sectionals on line! Jay Honeck Piloting 4 December 17th 03 09:59 PM
