Add LS-3 to the list; cockpit is nearly identical to the LS-4. I'm 6'3"
and there was more extension in the seatback and pedals in my LS-3. Though I'm thin (180 lbs.), the cockpit is wide. But pay attention to the parachute. That can make all the difference. Even the thinner chutes are often thicker behind the shoulders tapering as you go down from there. I need the exact opposite to get in my ASW 24 (i.e., reclining further helps). Also know that removing the seatback is a time-honored remedy for taller guys in gliders like the ASW 20. And sometimes there are other steps possible if it's close and the airplane is perfect in every other respect. My 24, for example, arrived from the factory without a backrest and it has the rudder pedals extended a few cm and an aftermarket instrument panel that has higher knee cutouts. Later ASW models are more accommodating. There have been many threads on this subject on this newsgroup. Go to groups.google.com advanced search page and search RAS using terms such as tall pilot, big cockpit, etc. Chip Bearden ASW 24 "JB" |
something I've not seen in all of the previous responses..
most of the foriegn built imported into the US gliders that I am familiar with have a 110kg per seat loading.. that is 242 lbs US. check the papers , w&b and max seat loading on anything you plan to buy BT "Jim" wrote in message news:ca0Wg.1916$La2.1639@fed1read08... I've been searching for a used sailplane for a month; most are proportioned for pilots not-so-large as me. Any recommendations for ships with commodious cockpit dimensions? Jim Hultman 6'3" 240 lb. Just call me 'Falstaffian". |
BT wrote:
something I've not seen in all of the previous responses.. most of the foriegn built imported into the US gliders that I am familiar with have a 110kg per seat loading.. that is 242 lbs US. check the papers , w&b and max seat loading on anything you plan to buy BT "Jim" wrote in message news:ca0Wg.1916$La2.1639@fed1read08... I've been searching for a used sailplane for a month; most are proportioned for pilots not-so-large as me. Any recommendations for ships with commodious cockpit dimensions? Jim Hultman 6'3" 240 lb. Just call me 'Falstaffian". Note that the 242lb is a seatbelt ultimate strength limit, not a weight and balance issue. A little lead in the tail can sort that out easily. Personally I doubt I would be interested in the difference between my seatbelt failing at 15G or 14G, but if you want to fly a certified ship... |
It may be the seatbelt or anchor point structural limit and may not be
the W/B limit. It's derived from the JAR22 miniumum maximum specification. Some airworthiness authorities do not recognize JAR22, however they often do specify operating within the stated operating manual/POH and placarded limits. Likewise, your insurance underwriter might have some specific compliance limitations. YMMV, Frank Whiteley Bruce Greef wrote: BT wrote: something I've not seen in all of the previous responses.. most of the foriegn built imported into the US gliders that I am familiar with have a 110kg per seat loading.. that is 242 lbs US. check the papers , w&b and max seat loading on anything you plan to buy BT "Jim" wrote in message news:ca0Wg.1916$La2.1639@fed1read08... I've been searching for a used sailplane for a month; most are proportioned for pilots not-so-large as me. Any recommendations for ships with commodious cockpit dimensions? Jim Hultman 6'3" 240 lb. Just call me 'Falstaffian". Note that the 242lb is a seatbelt ultimate strength limit, not a weight and balance issue. A little lead in the tail can sort that out easily. Personally I doubt I would be interested in the difference between my seatbelt failing at 15G or 14G, but if you want to fly a certified ship... |
Frank.. I agree.. my books say 242# per seat.. period.. impact integraty for
the required g-impact rating for certification.. put a 300# person in the seat.. you may be within W&B.. but not impact rating.. so long insurance BT "Frank Whiteley" wrote in message ups.com... It may be the seatbelt or anchor point structural limit and may not be the W/B limit. It's derived from the JAR22 miniumum maximum specification. Some airworthiness authorities do not recognize JAR22, however they often do specify operating within the stated operating manual/POH and placarded limits. Likewise, your insurance underwriter might have some specific compliance limitations. YMMV, Frank Whiteley Bruce Greef wrote: BT wrote: something I've not seen in all of the previous responses.. most of the foriegn built imported into the US gliders that I am familiar with have a 110kg per seat loading.. that is 242 lbs US. check the papers , w&b and max seat loading on anything you plan to buy BT "Jim" wrote in message news:ca0Wg.1916$La2.1639@fed1read08... I've been searching for a used sailplane for a month; most are proportioned for pilots not-so-large as me. Any recommendations for ships with commodious cockpit dimensions? Jim Hultman 6'3" 240 lb. Just call me 'Falstaffian". Note that the 242lb is a seatbelt ultimate strength limit, not a weight and balance issue. A little lead in the tail can sort that out easily. Personally I doubt I would be interested in the difference between my seatbelt failing at 15G or 14G, but if you want to fly a certified ship... |
BT wrote:
Frank.. I agree.. my books say 242# per seat.. period.. impact integraty for the required g-impact rating for certification.. put a 300# person in the seat.. you may be within W&B.. but not impact rating.. so long insurance BT "Frank Whiteley" wrote in message ups.com... It may be the seatbelt or anchor point structural limit and may not be the W/B limit. It's derived from the JAR22 miniumum maximum specification. Some airworthiness authorities do not recognize JAR22, however they often do specify operating within the stated operating manual/POH and placarded limits. Likewise, your insurance underwriter might have some specific compliance limitations. YMMV, Frank Whiteley Bruce Greef wrote: BT wrote: something I've not seen in all of the previous responses.. most of the foriegn built imported into the US gliders that I am familiar with have a 110kg per seat loading.. that is 242 lbs US. check the papers , w&b and max seat loading on anything you plan to buy BT "Jim" wrote in message news:ca0Wg.1916$La2.1639@fed1read08... I've been searching for a used sailplane for a month; most are proportioned for pilots not-so-large as me. Any recommendations for ships with commodious cockpit dimensions? Jim Hultman 6'3" 240 lb. Just call me 'Falstaffian". Note that the 242lb is a seatbelt ultimate strength limit, not a weight and balance issue. A little lead in the tail can sort that out easily. Personally I doubt I would be interested in the difference between my seatbelt failing at 15G or 14G, but if you want to fly a certified ship... Hmmm, you're within w&b, run into a downdraft, big sink, or rainshower perhaps just as you're getting back to the gliderport, come up short of the runway and break your bird. Being over 242 lbs. and therefore exceeding the rating for the seat/seatbelts contributes to the accident how???? I rather doubt that the insurance company would spend that much time looking for reasons not to pay. For what it's worth, I've pranged a glider and didn't get a single question from the insurance company beyond "give us a description of what happened". If they were that motivated to find discrepancies, I bet very few people would get payouts. Now, if it was a passenger that was hurt in the accident and he/she was over the seat rating, that would be a differnt case, particularly if there was a seat/seatbelt related failure during the prang. I don't see it happening in a single seater though. |
![]() I bet with all of the G forces when thermaling, it is easier to " dump your balast" in a "commodious sailplane"? John Sullivan |
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
HpH 304CZ as first sailplane | fcnorton | Soaring | 29 | March 31st 06 01:47 AM |
Duster Plans For Sale - BJ-1b fullsize sailplane plans | WoodHawk | Soaring | 0 | April 25th 05 04:37 AM |
Ultralight sailplane aerotow liability | Caracole | Soaring | 18 | April 1st 04 09:17 PM |
Electro-self-launching sailplane | clement | Soaring | 5 | September 12th 03 05:03 AM |
