#11
Jose wrote in message . com...
So that's the entire ride: departure, hold, two approaches, one of which is a precision approach. Three emergencies, one of which includes an engine out approach if in a multi-engine aircraft. No partial panel, no steep turns, nothing like that in Canada. Did you already hold an instrument rating for a single? Jose No, I didn't. This was my first ever check ride for the IFR. Class 1 here in Canada. I'm not sure what the equivalent is elsewhere. Class 1 = multi engine, non center line thrust; 2 = multi, center line thrust; 3 = single engine. Makes me wonder why you'd limit yourself to a center line thrust aircraft only, since there really aren't many of those. Besides the Cessna 336/337 and some weird WWII German aircraft, I can't think of any others. --Kevin |
here in Canada. I'm not sure what the equivalent is elsewhere. Class 1 = multi engine, non center line thrust; 2 = multi, center line thrust; 3 = single engine. Usually (in the US) one gets a pilot certificate for single engine (usually land) airplanes, then the instrument rating (in a single), and then pursues a multi rating. Nothing I know of says it can't be done backwards though. If you get your instrument rating in a single, and then get a license for a twin, I don't know whether you need a separate instrument (add-on) checkride for the multi. I can't find it in the regs, though something in the back of my mind makes it familiar. Makes me wonder why you'd limit yourself to a center line thrust aircraft only, since there really aren't many of those. Besides the Cessna 336/337 and some weird WWII German aircraft, I can't think of any others. I was told that the C336/7 was created so that a person with a single engine rating could fly a twin engine airplane (since there would be no critical engine, and no adverse yaw, and no blueline). However, the FAA decided that not only did you have to have a multi-engine rating =and= a type rating for that particular aircraft. However they made it possible to get a multi rating that would be limited to centerline thrust if you wanted. Advantages would accrue to those who wanted it just to fly the C336/7 (owners, for example) and so didn't need all the training in adverse yaw and such (and to keep it all current) Jose -- for Email, make the obvious change in the address |
On Sat, 06 Nov 2004 04:03:53 GMT, Jose
wrote: Usually (in the US) one gets a pilot certificate for single engine (usually land) airplanes, then the instrument rating (in a single), and then pursues a multi rating. Nothing I know of says it can't be done backwards though. It can be done backwards. I know someone who did all multi (except private) and then single. If you get your instrument rating in a single, and then get a license for a twin, I don't know whether you need a separate instrument (add-on) checkride for the multi. I can't find it in the regs, though something in the back of my mind makes it familiar. The PTS mandates if you are IFR rated in singles and go for a multi add-on you are required to demonstrate IFR profficiency during the checkride. You used to be able to forgo the IFR stuff and get a VFR only restriction, but now the only way to do that is add a multi to a cert that does not have Instrument privs. HTH. z |
Jose wrote
Usually (in the US) one gets a pilot certificate for single engine I was told that the C336/7 was created so that a person with a single engine rating could fly a twin engine airplane (since there would be no critical engine, and no adverse yaw, and no blueline). However, the FAA decided that not only did you have to have a multi-engine rating =and= a type rating for that particular aircraft. An Aircraft Type Rating is required only if the C-336/337 weighs over 12,500 pounds.....not very likely. Now...the possibility exists that you have written a very poorly composed paragraph. Bob Moore |
Kevin,
Besides the Cessna 336/337 and some weird WWII German aircraft, I can't think of any others. Adam 500. -- Thomas Borchert (EDDH) |
over 12,500 pounds.....not very likely. Now...the possibility exists that you have written a very poorly composed paragraph. It is more likely that I used the wrong words. One does require an endorsement or some kind of special approval to fly the centerline thrust Cessna, even with a multi ticket. I called it a type rating; perhaps the FAA calls it something else, in the same sense that it does not issue "licenses". As for a poorly composed paragraph, the last sentense is the result of an imcomplete edit. Not only do you have to have a multi, you also have to have a [something] is what I meant. Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
Jose wrote
One does require an endorsement or some kind of special approval to fly the centerline thrust Cessna, even with a multi ticket. Wanna Bet? Bob Moore |
zatatime wrote in message . ..
It can be done backwards. I know someone who did all multi (except private) and then single. Snip Not even germain to the topic, but amusing. I fly with a guy in my glider club who is rated for: Glider, two engines, three engines, four engines (I think) and eight engines. Military B-52's and Delta. Well, and gliders. No single engine rating at all. Odd, huh? Jim |
approval to fly the centerline thrust Cessna, even with a multi ticket. Wanna Bet? No. I'll infer that I was mistaken. Since I don't fly those things I have no reason to =know=, I'm just responding with what I was taught in ground school &$ years ago. ![]() Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
First IFR flight after checkride | Wizard of Draws | Instrument Flight Rules | 44 | August 31st 04 05:26 AM |
IFR Checkride Checklist | BTIZ | Instrument Flight Rules | 0 | April 18th 04 12:06 AM |
Passed my IFR checkride today. | pbreed@netburner.com | Instrument Flight Rules | 5 | February 8th 04 07:04 AM |
Passed checkride... yay! | papenfussDIESPAM@juneauDOTmeDOTvt.edu | Instrument Flight Rules | 3 | October 1st 03 10:55 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
