Landing on a sloping runway with different wind velocities
Old October 9th 06, 11:37 PM posted to rec.aviation.piloting
Peter Duniho
Default Landing on a sloping runway with different wind velocities
"Peter Duniho" wrote in message
More importantly, the change in acceleration or deceleration is linear,
while the difference in total speed change is exponential.
I should clarify what I mean, since the way I wrote it seems a little
confusing:
The changes themselves are both linear, but the *consequences* (in terms of
distance added or removed) is exponential when changing the speed.
Old October 10th 06, 01:46 AM posted to rec.aviation.piloting
Tony Cox
"Tony Cox" wrote in message
Rule of thumb responses are interesting, but better would be
a full mathematical treatment. Presumably, a proper treatment
would need to include touch-down speed too, and perhaps
gross weight as well.
I have occasionally thought about trying to treat the problem
mathematically, but so far haven't had enough motivation to do so. It's a
very complicated problem, mathematically speaking (assuming you're not
someone who does this sort of math on a daily basis, and I'm not). I
suspect that in addition to looking at touch-down speed and gross-weight,
along with runway slope and wind velocity, you would also have to include
some measure of braking performance (maybe this is somehow derivable from
the POH roll-out distances).
Me too (on motivation), and I'm supposedly qualified to work
it out for myself, but was wondering if anyone had done it before!
Thinking about it after posting, in practice I think it might get even
more complicated. Ever worked out how accurately you can "spot"
a landing? I think of myself as a pretty average sort of private pilot,
and I'd guess I can pick a touchdown point to around +- 200 feet
or so on a good day. But I know I can do much better (calm wind)
on an upslope runway than a downslope one -- I suppose it is because
with an approximate 6 degree descent path, after factoring in the
runway slope (lets say 2 degrees) any deviation in approach angle
gets magnified by 2 (6+2=8 degree intercept vs. 6-2=4 degrees).
So, the actual "rollout" distance isn't really the thing to look at --
one ought to factor in your own personal "uncertainty" in
touchdown point too and look for the minimum runway length
(rollout + anticipated touchdown point uncertainty) that you'll
use for landing. This would bias in favour of the uphill approach,
regardless of other factors. (Probably. Air speed affects
approach angle too!)
A 3 degree slope sounds pretty steep to me. Are you sure it's not 3%?
I'd like to be definitive, but my airport guide is in the plane,
and I don't seem to be able to find the info through google.
I *thought* it was 3 degrees (and I really ought to know,
having been based there 6 years), but I may be wrong. Anyway,
3% works out as 2 degrees. It's our crosswind runway at
61B (Boulder City, Nevada) if you have a book to hand.
Another local airport is 3.5 units (degrees or grade) at
Temple Bar (U30) which is a wonderful destination if you're
in the area. Wish I had my damn book!! Regardless, these
grades make a substantial difference to one's decision. The
runways, at 3500' or so, leave little room to be sloppy if you're
in a Mooney and landing when the DA is over 5000'.
As far as general rules of thumb go, the one I've heard is that 1% of slope
is worth about 10 knots of headwind *for a takeoff*. This is not
necessarily applicable to the landing case, which is what you're asking
about, but it's at least related. In this rule of thumb, take the runway
slope in percent, multiply that by 10, and if you've got a headwind less
than that, operating downslope is better for a takeoff (upslope for a
landing, if you apply the same rule of thumb).
I've heard that too, and Sedona airport (KSEZ) goes as far
as to mandate which runway to use depending on wind (I think
they have a slope of 1.5 *units*, but their runway is so long it
hardly makes a difference to us little guys).
I think the takeoff calculation ought to be more straightforward.
You can use the whole runway, for a start, and all one needs
to do is to work out how much acceleration you sacrifice by
running up the grade. Clearly, braking effects are irrelevant.
Still, it'd take a bit to figure the math.
Personally, that rule of thumb seems optimistic to me, but I don't have any
good justification for doubting it. Still, it's worth considering the fact
that a headwind or tailwind affects the takeoff or landing differently than
slope. That is, the wind speed affects the total velocity change required,
while the slope affects the acceleration available. Even if you take off
uphill but upwind, while the acceleration will be less, so may the runway
used since you need a lower total velocity change to reach takeoff speed.
Likewise, landing downhill but upwind, yes your deceleration is less but you
also need less reduction in speed to come to a stop.
To me, that suggests that if you're going to err, it's better to choose the
headwind over slope when in doubt, since a good headwind is beneficial to
the exponentially related parameter, while the slope is only beneficial to
the linearly related parameter.
I just feel more comfortable landing uphill. Perhaps its because
on approach you have a bigger target to hit!
That said, like I said I haven't taken the time to look at any of this in a
rigorous mathematical way, so I might have made a mistake in some
assumptions. Still, I have to say that the one time I ever took off
downwind but downslope, I sure used a lot more runway than I thought I was
going to.
Me too, with my mother on board as well. Quite a
wake-up call.
Old October 10th 06, 06:49 AM posted to rec.aviation.piloting
Peter Duniho
a landing?
I know what you're saying, but all of the landing calculations are subject
to the variations you're describing. I think the basic calculations ought
to be able to be done independent of those, and you can apply the same
wiggle-room at the end that you have to for the usual landing distance
calculations.
Well, 3 degrees is 50% steeper. That's a pretty big difference.
Interestingly, Airnav (which basically just republishes A/FD data) does
publish a runway gradient for Temple Bar, but not Boulder City. Though, it
does specifically warn against takeoffs from runway 33 at Boulder City due
to the gradient. Odd that they wouldn't publish the number.
Anyway, the published number has a very specific FAA definition, but it is
essentially just a percent grade. So if you've got a published number for
Boulder City that's called runway gradient, that's most likely what it is.
However you cut it, a 3% grade is certainly significant. Didn't mean to
imply otherwise. It's just that 3 degrees would have been even more
dramatic.
Driggs, Idaho is also 1.4%, and at 7300 feet seems quite long. But between
the 6200' airport elevation and the slope, both takeoffs and landings can be
interesting, especially done downwind. Sedona is lower at 4800', but the
runway is only 5100' and the gradient steeper at 1.9%. I'll bet things can
get interesting there too. I think even a little guy would want to take
care there.
Well, the landing distance calculation would make the same assumptions about
touchdown point and speed that one would make for normal landing distance
calculations as well. I agree that in general, takeoff calculations ought
to be more reliably repeatable than landing calculations, but that's not
unique to the question of sloped runways. So as a starting point, I'd say
one ought to just make those same assumptions and acknowledge that there's
some inherent error in being able to replicate the theoretical numbers.
Well, the steeper the hill, the safer you ought to feel. But there's
uphill, and then there's UPHILL. Distance to stop increases with the
square of your airspeed, so even a little extra speed translates into a lot
of extra landing distance. The difference between landing with a headwind
and landing with a tailwind is proportional to *twice* the wind speed (since
it's added as a tailwind and subtracted as a headwind). If your landing
speed is 60 knots and you've got a 10 knot wind, that's almost a DOUBLING of
landing distance comparing headwind to tailwind (70 knots is 40% faster than
50 knots, giving you a 96% increase in stopping distance).
You'd need a pretty good hill to halve that doubled landing distance to get
back to breaking even.
Pete
Old October 10th 06, 07:57 PM posted to rec.aviation.piloting
Grumman-581[_3_]
One of the problems with landing downhill is that as you are flaring, the
ground is also dropping out from underneath you and as such, your flare ends
up taking longer... I remember once landing on a downhill runway and it
seemed to take so long to touch down after I flared that I was starting to
wonder if I would *ever* land... Landing at an unfamiliar airport at night
with a downhill runway is also an interesting experience the first time it
happens to you...
Old October 9th 06, 11:28 PM posted to rec.aviation.piloting
Doug[_1_]
Uphill or down, land into the wind seems to work best. Same goes with
Seaplanes and rivers, land into the wind. But....sometimes with
obstructions and whatnot it's not safe to land at all. Find another
field.
Old October 10th 06, 12:11 AM posted to rec.aviation.piloting
Ben Jackson
There's a good trick question. Should you always land uphill at a sloping
seaplane base?
Ben Jackson AD7GD
http://www.ben.com/
Old October 10th 06, 02:18 AM posted to rec.aviation.piloting
Jose[_1_]
seaplane base?
Yes. Unless you're flying a barrel, in which case the tradition is to
land downhill.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old October 9th 06, 11:36 PM posted to rec.aviation.piloting
Neil Gould
Recently, Tony Cox posted:
Here's a problem which seems to have a non-trivial solution.
At least, I've not been able to find a definitive answer to it, but
what do I know??
Suppose one wishes to land at an airport with a runway
that slopes at X degrees. The wind -- assumed to be directly
aligned with the runway -- is Y knots from the "high" end of
the runway.
Clearly, if Y is positive, one should try to land in the
"up-slope" direction to minimize one's ground roll. One
will be landing "up" and into a headwind. But what if
Y is negative? Clearly, if Y is just a few knots neg, one would
still land "up-slope", because the braking effect of rolling
out up-hill more than compensates for the higher landing
speed due to the tail wind.
If Y is negative and more substantial, which way should
one land? At some point, it makes sense to switch to the
other end of the runway -- landing downhill -- to take advantage
of the (now) headwind. But how does one establish which way
to land, assuming no clues from other traffic in the pattern? The
aim is to select a direction, given X and Y, which would result
in the smaller ground roll.
Its more than an academic question for me. My home airport
has a 3 degree runway, and some local airports are even
steeper.
Having done that (Jaffrey Airport, NH), all I can suggest is that you go
with the head wind, whichever way that is. My first approach was to land
going "uphill", but on final the wind shifted to a tailwind and it made
things pretty dicey. So, I went around and landed downhill. The roll-out
was a quite bit longer than I'm accustomed to, but other than that it was
uneventful. When I left a couple of days later, the wind favored taking
off "uphill", and that was an experience, as well. It gave the folks at
the ice cream stand about 500' off the departure end something to gawk at.
Neil
Old October 10th 06, 03:13 AM posted to rec.aviation.piloting
Jerry
I have an 1800 ft grass strip that has a 3% grade. There is a 50 to 75 ft
obstruction off the high end of the runway and no obstructions off the end
of the low end of the runway. Slope and obstruction is more important than
wind. I will not land downwing unless the headwind exceeds 15 knots. The
deceleration uphill and acceleration downhill is more significant than the
usual winds. Below 200 ft on approach, you have to be committed to land.
Unless you have a very high power to weight you cannot do a go around.
Jerry in NC
what do I know??
the runway.
steeper.
Old October 10th 06, 04:04 AM posted to rec.aviation.piloting
Kyle Boatright
"Jerry" wrote in message
Jerry in NC
You get the big brass ones award. I don't have the stomach for a strip
where I have to commit so early.
In a no wind situation, what is your uphill landing roll on your strip
versus a level strip?
Same question for your downhill takeoff roll.
And, what do you fly?
Thanks for the info..
KB
Why not to land downwind [email protected] Piloting 23 September 6th 06 03:01 PM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
Pilot deviations and a new FAA reality Chip Jones Piloting 125 October 15th 04 07:42 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
